I
What does stock pull for belly busters at that elevation, 66g or 68g?
I was told it that the 858 would pull 6g more than stock. So I tried clutching it for that. Wouldn't pull it, not even close. I am currently running mtx 74g empty(originally had it loaded with 5g but removed) with a slp blue/pink spring and only turning 8100rpm at 3-4K elevation. My wifes 13 pro stock pulls 71g mtx with 2g in the heel stock same rpm at same elevation. This is what chaps me. Sorry for the de-rail.
Stock sled will pull 66g belly busters to 5k elevation. With the 860 the sled is over revving Belly Buster 70's to above 5,000 ft but starts under revving 10-72's at about 4500 ft. This is with a 62/42 helix. It will probably end up with 10-72's with a little tip weight ground out of them. Which is still very impressive. It pulls almost as hard as my 872.
