Note: this_feature_currently_may_not_be_available_in_some_browsers
Yes I had the same question with the last 1/4". Just push them in. Also for the low rpm.after I did my reeds I had to have my tps set for some reason. Would start and then die, unless I gave it gas. After tps was set.all was good.
Funny how things come up on the 'net.
I put my 3R's in after 1.5 rides (during the warm spell). Only thing I did at the time. fired it up and idled 200ish lower than normal and in reverse would make the lights flicker badly.
Just a few weeks before this I installed new injectors because of a mistake on my part. Part of the process for me was to check TPS voltage while running with PCV installed and 'putor (this has been my base check for me since '13 and is reference for me). It was the same at that time as '13 so good enough.
First thing I checked (after all the normal stuff) on the lower idle thing was the TPS in the same manner as a few weeks previous and it was still the same.??? So, even though I'm sure a tweek would have changed it I decided not to.
Instead, I leaned out, on the PCV at 0% and 2% at idle. (+1 to -3 on mine) and idle came up. I blip blipped it and tweeked abit more out just above idle and it sounded better (that's and ear thing I trust) than it had before with stock reeds (second set and also showing signs of wear at the tips).
I took the PCV off and reinstalled the boony box, set the 0 to 10% to -3 below 2500 and have left it there with stable idle since.
To continue to the present, this summer I parked the SLP pipe set and installed a Aaen pipe and can and modified the can abit for personal fit so this is an apples to oranges comparison.
On the first rides (stock reeds) it felt a bit lean in spots so I added in field to be safe but I wouldn't call it tuning.
When I got back out with the 3R's it was very rich in the mid, heavy throttle. Had me concerned but I tweeked and I mean quite a bit. I've dropped 10 to 14% in much of the mid and still feel a bit more can be removed. Work in progress.
This has made me think about it more than once. I think the 3R's are a stiffer reed but that's just my opinion.
It feels like it with the finger first off. Secondly past has shown stiffer reeds give better flow in the higher rpm with a sacrifice at lower rpm flow (this doesn't necessarily mean less power if fuel is correct) and DTR showed this when they tested them.
Thirdly (and the one that relaxed me lol) one thing that stuck in my mind from the DTR review was when Mr. DTR said they "removed the heavy fuel flow in the midrange wide open throttle positions" when tested with the '13 'putor. It's shown on their dyno chart too.
I've never thought my '13 was rich there by any means and have run for a couple of seasons with a fair bit of fuel added there for my set-up. Now with the 3R's I'm reducing fuel in that area too on my sled and I like a richer set-up than most.
Just thought I'd add my 2 cents.
SMF
No two modified sleds are the same so remember apples to oranges but that's weird in itself.
I've always assumed using the idle adj. screw is a no no on this system. Reason for that thought is procedure. Base setting, then idle setting and final WFO checks for TPS voltage. Seems to me if you change the idle screw you have to start all over, including sync to PCV or boony box.
My sled came set very very slightly below recommended voltage. Was told this would make me lean all the way through with the map provided so I just used a slightly richer map, all the way through, and been good (why I used to be a +1 at idle before).
I would think if you opened the throttle valves more with the idle screw it would richen your map all the way through (because TPS voltage is now higher at idle and all the way through) on it's own (opposite of what I had to do).
On my sled at about -6 it started to indicate to lean at idle (bong de bong de bong lol) and -7 dropped a bit in rpm and started to hang high in rpm with a blip. At the other end, by the time I was at +5 my gauge would go out and the sled would eventually die from being too rich.
The small changes you do at low throttle, low rpm (like idle) has a greater effect than other positions because your injector is activated for so little time. The Poo's injector position allows a little less fuel use compared to throttle body injection and doesn't get much chance to puddle in the crankcase.
I'm more familiar fooling around with Cat's (throttle body injection) lol. If you take a Cat to +6 or7 at idle it will die almost instantly and you will be pulling with the throttle wide open to get it started. Take it the other way and you will never get it started without applying the right amount of thumb.
I tend to agree with you that the 3r's are not an eye opener when it comes to the seat of the pants. It would be hard to feel that slight extra HP anyway but the dyno shows,,,, and it all adds up in the end, right lol.
I like to do things one at a time so I waited to install the 3R's. I'm surprised what I had to do but it is running very well. I think the biggest benefit to me will be fuel mileage lol and I maybe feel a bit more crispy now.
So.
According to my supplier.
Vforce is testing some faulty reeds and there seems to be some sets that are good and others that are having problems.
There is around 5-7 sets i know of having the same issues.
My bolts are tight and the flange is tight also.
So are they gonna replace faulty ones
