Upgrade to Premium
Polaris: Pro-Ride 2010 and up, all models in the Pro-Ride chassis
Reply
  #1
Old 03-18-2018, 08:18 PM
nate18 nate18 is online now
Currently: Not set.
nate18 has a reputation beyond reputenate18 has a reputation beyond reputenate18 has a reputation beyond reputenate18 has a reputation beyond reputenate18 has a reputation beyond reputenate18 has a reputation beyond reputenate18 has a reputation beyond reputenate18 has a reputation beyond reputenate18 has a reputation beyond reputenate18 has a reputation beyond reputenate18 has a reputation beyond repute
Default Options for broke case???
860 went down...looks like a piece of case broke off(perhaps due to detonation????) and got up in cylinder??? Can case be fixed if this is all that is wrong??? Thanks for any thoughts.
ID:	294569   Click image for larger version
ID:	294570   Click image for larger version
Rate this post: Yes | No
  #2
Old 03-18-2018, 08:36 PM
Octanee Octanee is online now
Currently: Not set.
Octanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond repute
Default
Real bummer, you will have to split the case and inspect it. How does your connecting rod bearing feel? Perhaps it smacked it? Odds low that the casting just fractured off but you never know.
If it looks like it just broke off... And no cracks, I'd personally throw a weld bead on it and re use.
  #3
Old 03-18-2018, 08:45 PM
XCaSSAULT XCaSSAULT is offline
Currently: Go Wild!
Basic Member
XCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond repute
Default
Det wouldn’t cause a piece of case to break off. Prolly a piece of piston and or cylinder skirt broke off and went through case. Take mono block off and have a look. Let us know
  #4
Old 03-18-2018, 11:56 PM
Sheetmetalfab's Avatar
Sheetmetalfab Sheetmetalfab is online now
Currently: Getting the R6 snowbike ready......
Sheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond repute
Default
Send the whole thing to indy dan.
He can salvage the cases (weld and line bore)
Or look for another shortblock.
Fyi detonation takes out piston skirts and rod bearings.
Siezed rod bearing (or losing pieces of one) hammers pistons.
Looks like some pieces processed through your bottom and top end.
__________________
Try again
  #5
Old 03-19-2018, 09:22 AM
revrider07 revrider07 is offline
Currently: 850 modder
revrider07 has a reputation beyond reputerevrider07 has a reputation beyond reputerevrider07 has a reputation beyond reputerevrider07 has a reputation beyond reputerevrider07 has a reputation beyond reputerevrider07 has a reputation beyond reputerevrider07 has a reputation beyond reputerevrider07 has a reputation beyond reputerevrider07 has a reputation beyond reputerevrider07 has a reputation beyond reputerevrider07 has a reputation beyond repute
Default
Indy Dan if keeping it or local welder if selling.
  #6
Old 05-15-2018, 09:13 AM
sledtahoe sledtahoe is offline
Currently: waiting for the big dump!
Basic Member
sledtahoe has a reputation beyond reputesledtahoe has a reputation beyond reputesledtahoe has a reputation beyond reputesledtahoe has a reputation beyond reputesledtahoe has a reputation beyond reputesledtahoe has a reputation beyond reputesledtahoe has a reputation beyond reputesledtahoe has a reputation beyond reputesledtahoe has a reputation beyond reputesledtahoe has a reputation beyond reputesledtahoe has a reputation beyond repute
Talking case
mine only broke cases crank was fine Indy dan is the man
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — What options are there for a chain case / belt drive guard plate? Thread Starter — dude Forum — Polaris: AXYS Replies — 15 Last Post — 11-21-2015 02:18 PM
Thread — TS case guard options Thread Starter — FriscoProx Forum — Snow bikes Replies — 9 Last Post — 05-13-2015 07:00 AM
Thread — Nitro Chain Case bottom Gear bolt broke! Why? Thread Starter — Artic Cat Forum — Yamaha: Boosted Sleds (Turbo or Supercharged) Replies — 12 Last Post — 11-18-2010 02:44 PM
Thread — Options for Chain Case Lube Thread Starter — RFIRE4 Forum — Polaris: IQ Replies — 6 Last Post — 11-17-2009 06:45 PM
Thread — HELP!!! Bolt broke off in drive shaft in chain case Thread Starter — Throttle-Up Forum — Polaris Replies — 14 Last Post — 11-01-2008 11:54 AM
