I have 06 900 RMK Dragon with about 2800 miles on it. If I hold the throttle at 6500 rpm, it has a intermittent engine cut out. When I say intermittent, I mean as long as you stay right around 6500 rpm the engine keeps cutting in and out quickly. If you push the throttle in more it will power right through the cutting out problem and run very strong. I have the complete SLP update. Billet head, pipe, can, air box and torque arm ect... with the SLP flash installed. Could it be the airbox sensor? I heard that it should be located on the bottom of the air box. Mine is located on the top left side. Any ideas?
