OP explains it well in his first post to start the tread.
Always wear a tether. Even in the backyard
Not to laugh at your misfortune, but must have been quite the show.
Ever seen Ferris Bueller?
If you're referring to the OP he did say the tether came out so I would assume he was wearing it.
On a slight tangent... has any OEM or aftermarket provider ever considered a "power off brake"? When the tether comes out it would pull electrical power. Loss of electrical power causes the device to apply the brake via spring. We use this type of device on some drive systems I work on and the hydraulic disc brake is a great application for it.
It seems to me the track momentum can really carry a slide quite some distance after the motor cuts out. Not to mention that a power off brake would prevent a lot ghost rides into the trees for some otherwise benign fall-offs.
This sounds good but brings problems. First is on a steep downhill slope the sled will usually roll and cause more damage due to the locked track and therefore an, antilock braking system is required. That system would be way too heavy as a battery is required along with much hardware. When the motor is off and the belt is dragging through the clutch there is at least some resistance to slow the sled. With the sled off hopefully you will not get ejected and ride it out.
