Regarding the CAI (Cutler cold air intake) Are you guy's plumbing in to the factory plenum?
Wasatchcomm, does the filter come off to open the hood? A picture of the plumbing with the hood off would be awesome if you get a chance.
I'm thinking of doing something like this but my biggest worry is ripping my prefilter on branches every ride (my M8 came equipped with the factory tree-magnet.) I'm thinking of laying the filter down, pointing towards the rear bumper, and them making a deflector to protect it from branches. Off the top of my head, I'm thinking part of a cone to keep branches from catching on it. Anyone want to help me brainstorm on this?
Hey I just did the same thing to my Cutler Stage 1 kit except mine came up a little closer to my knee. Was just wondering if once you did this, did you have to adjust your fuel mapping???
rusty,,
on your kit,
did you notice an improvement with the cold intake vs the under hood intake?
I think this intake would probably fit other kits with compressor side facing forward. Im sure you would have to make slight changes to make it fit others besides twisted. Very clean install, went together perfectly, everything lined up great. Black 90 in avatar pic goes into duct at the end with large hole in it.
I did headlight delete on mine and put pre filter and mesh on other end of duct work in the head light area. I did not try this but I think with this intake you probably could still run your headlights still if you wanted (with extra venting in dash). The duct that goes into aluminum sheet on underside of hood sticks in about an inch or so, the lights would be just above that. Then just put pre filter around the 90 on turbo.
Cool! Is Cutler's C.A.I. similar to this twisted set-up?
good info here, i just installed a cold air snorkel on the etec, it jumped me up 400rpm and was a complete different sled, will never use the underhood air again
now what i would like to know, is what gauges or what type of install are you guys using to get your charge air temps, are you using a heat gun, or actual gauge
want to keep a eye on charge temps, just not sure on the how to
install pictures http://www.snowestonline.com/forum/showthread.php?t=291837
