Upgrade to Premium
Polaris: Pro-Ride 2010 and up, all models in the Pro-Ride chassis
Reply
  #1
Old 09-11-2011, 04:04 PM
mountainhorse's Avatar
mountainhorse mountainhorse is offline
Currently: CONTEMPLATING: "Laughter is gods hand on a troubled world.".
mountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond repute
Cool OIL RATIO DISCUSSION ON THE 800 CFI MOTORS
I thought I'd start a new thread on this topic rather than leaving it buried in another thread...
The discussion is about fuel/oil ratios in our sleds...not the brand of OIL. I really don't want to turn this into a "Cheerleader" thread for your favorite brand of oil..
The discussion is not about better oils and the theories about better quality oils. There are certainly lots of good brands out there and that would be a topic for another thread.
This is NOT a thread about using a better / cheaper / cleaner etc etc oil... that is a personal choice that many people seem to be very emotional about.
And also not a "bash" thread on Polaris branded oils.
Use what you use... that is YOUR choice/right.
I think that the VES Gold "Plus" was introduced and specified by Polaris with the intent to reduce emissions and a requirement for the EPA certification on this engine package.
The factory, I will speculate, has many factors in the the decision to choose an oil and the ratio at which they set the pump...buffered with cost and engine longevity for the end user. I believe that to sell the sled... the OEM Must also have to sell oil for that sled that meets EPA regs when used in the engine package as certified.
IMO..on the new engines... you should adjust the oil pump a bit richer than specified by the factory.
I will speculate that the factory cannot recommend this to the dealers as more oil will raise the emissions of the sled... something that the factory would be limited in this capacity by their EPA certification process. I will also speculate, simply put, the factory cannot make any recommendations (because of EPA compliance regulation) to consumers or the dealer network to alter any of the adjustments that could increase emissions of the engine. And that a dealer cannot officially instruct the consumer to make any adjustments.... That would include decreasing the fuel : oil ratio (for example going from 50:1 and increasing the oiling of the engine to say... 45:1 or 40:1)
If your choice of good quality oil is slightly increased in volume... I believe that wear on the motor will be decreased to some degree.
Now don't get me wrong... there is a point at which more oil will decrease the performance of the engine... at what point that will happen is the question... and what is the balance of performance vs longevity.
At what point will a lower fuel : oil ratio noticeably affect performance is beyond my scope of experience... But, IMO, a little bit more oil is not going to hurt your performance.
Would a 40:1 ratio with today's synth oils, give any noticeable decrease the power output or change the operational character of the engine?
Would that 40:1 ratio help the pistons and bearings live longer?
For example, how much decreased performance is realized when, on a motor that is broken in and past the break in timer on the ECU, you add some premix to the tank??
HMMM.. more to ponder.
I'd like to hear from our readers that have something to add to this... Polaris techs and "average Joes" with intellegent input on this topic...I've also asked some people "In the know" to chime in here.. It will be interesting to see how this thread plays out.
__________________
Signature:
Rate this post: Yes | No
The Following 11 Users Say Thank You to mountainhorse For This Useful Post:
94fordguy (09-11-2011), Backcountry addiction (01-21-2014), Bagger (09-12-2011), diamonddave (09-12-2011), NapaMatt (09-11-2011), poliguy (09-12-2011), Rev Kev (09-12-2011), rmkray (11-23-2011), Snodawg (09-11-2011), Vinnee (12-10-2011), WisSledder2 (09-11-2011)
  #2
Old 09-11-2011, 04:20 PM
Eli Eli is offline
Currently: Pondering if I can ride a snowbike....
Eli has a reputation beyond reputeEli has a reputation beyond reputeEli has a reputation beyond reputeEli has a reputation beyond reputeEli has a reputation beyond reputeEli has a reputation beyond reputeEli has a reputation beyond reputeEli has a reputation beyond reputeEli has a reputation beyond reputeEli has a reputation beyond reputeEli has a reputation beyond repute
Default
I run 32:1 premix. I saw an article that showed no decrease in performance down to around 16:1, if I remember correctly. 32:1 is an easy mix at any gallonage-4oz/gal.
The Following 2 Users Say Thank You to Eli For This Useful Post:
mountainhorse (09-11-2011), NapaMatt (09-11-2011)
  #3
Old 09-11-2011, 04:27 PM
Default
ELI... are you talking about running this on a 800 CFI motor equipped with the factory oil injection pump?
Can you dig up that article that you saw?
__________________
Signature:
  #4
Old 09-11-2011, 04:43 PM
NapaMatt's Avatar
NapaMatt NapaMatt is online now
Currently: Stocking shelves, Need Parts??
NapaMatt has a reputation beyond reputeNapaMatt has a reputation beyond reputeNapaMatt has a reputation beyond reputeNapaMatt has a reputation beyond reputeNapaMatt has a reputation beyond reputeNapaMatt has a reputation beyond reputeNapaMatt has a reputation beyond reputeNapaMatt has a reputation beyond reputeNapaMatt has a reputation beyond reputeNapaMatt has a reputation beyond reputeNapaMatt has a reputation beyond repute
Garage
Default
Also Some thing to keep in mind.. When adding more oil..
Isn't Kinda going Leaner... More Oil.. Same Gas.. . In the same Burn Chamber.. ?????
Also.. For the steady throttle guys.. Bumping up the oil pump is nice security..
But the ones that ride it like they stole it Kind. Throttle is to the bars! And moving.. not keeping it at one speed.
Keeping on key.. here..
Yes, Could use a little more oil.. But not much.. this Oil is getting$$$$$$$$$$$$$$$$.. I think i went through 6 Gals in 1600 Miles.. When i think that way... That's a season of riding for $330 in oil $650 in Fuel
__________________
FOR SALE... SLP Pipe Set For Pro RMK 800... PM. Me for Details BRAND NEW 2013 ASSAULT PIGGY BACK FRONT SHOCKS FOR SALE!! $$650!!! Gas Tank From a 07 Switchback/ Seat Red and Black No tears. Plus fuel lines.
http://www.napaonline.com/
Theye Supply 1-507-533-6610
Auto Parts, Snowmobile, ATV, Truck and Trailer.. and
Shop Local!!
The Following User Says Thank You to NapaMatt For This Useful Post:
  #5
Old 09-11-2011, 05:03 PM
Eli Eli is offline
Default
I'm looking on the net for it....it was an older test.
The Following User Says Thank You to Eli For This Useful Post:
  #6
Old 09-11-2011, 05:08 PM
Eli Eli is offline
Default
http://www.bridgestonemotorcycle.com...oilpremix6.pdf
Here is one, not the exact one I was thinking of......
The Following 3 Users Say Thank You to Eli For This Useful Post:
Creek Chub (09-11-2011), mountainhorse (09-11-2011), sledcaddie (09-16-2011)
  #7
Old 09-11-2011, 05:12 PM
Eli Eli is offline
Default
Here is a quote on a three-wheeler forum regarding oil.....
Pre-mix ratios and power production
I have run Dyno tests on this subject. We used a Dynojet dynamometer, and used a fresh, broken in top-end for each test. We used specially calibrated jets to ensure the fuel flow was identical with each different ratio, and warmed the engine at 3000 rpm for 3 minutes before each run. Our tests were performed in the rpm range of 2500 to 9000 rpm, with the power peak of our test bike (a modifed '86 YZ 250, mine) occuring at 8750 rpm. We tested at 76 degrees F, at 65% relative humidity. We started at 10:1, and went to 100:1. Our results showed that a two-stroke engine makes its best power at 18:1. Any more oil than that, and the engine ran poorly, because we didn't have any jets rich enough to compensate for that much oil in the fuel, and the burn-characteristics of the fuel with that much oil tended to be poor. The power loss from 18:1 to 32:1 was approximately 2 percent. The loss from 18:1 to 50:1 was nearly 9 percent. On a modern 250, that can be as much as 4 horsepower. The loss from 18:1 to 100:1 was nearly 18 percent. The reason for the difference in output is simple. More oil provides a better seal between the ring and the cylinder wall.
Now, I realize that 18:1 is impractical unless you ride your engine all-out, keeping it pinned at all times. But running reasonable ratios no less than 32:1 will produce more power, and give your engine better protection, thus making it perform better for longer.
As a side note, I no longer run 26:1, I now run 32:1. I'm not a young man any more, and I just can't push as hard as I used to, so I don't need as much oil now. 32:1 is enough oil to do what is needed for me now, since I'm getting slow..
  #8
Old 09-11-2011, 05:35 PM
Default
I wonder what the thermal content, in BTU's/Lb (or the metric equiv)... of a given gasoline and a given oil is mixed at say 4 different ratios... 50:1 , 40:1 , 30:1 , 20:1
Ring seal is not something that I considered...but the bore size, stroke, ring velocity/acceleration and thickness.. bore material, ring material would also have an effect on the output. So for this conversation... we'll keep it to the Stock CFi 800 engine so we don't get side-tracked.
More oil for ring sealing might balance out less thermal content of an oil/fuel mix. HMMM...
__________________
Signature:
The Following 2 Users Say Thank You to mountainhorse For This Useful Post:
NapaMatt (09-11-2011), sledcaddie (09-16-2011)
  #9
Old 09-11-2011, 05:39 PM
Creek Chub's Avatar
Creek Chub Creek Chub is offline
Currently: Ready to pull the Trigger
Creek Chub has a reputation beyond reputeCreek Chub has a reputation beyond reputeCreek Chub has a reputation beyond reputeCreek Chub has a reputation beyond reputeCreek Chub has a reputation beyond reputeCreek Chub has a reputation beyond reputeCreek Chub has a reputation beyond reputeCreek Chub has a reputation beyond reputeCreek Chub has a reputation beyond reputeCreek Chub has a reputation beyond reputeCreek Chub has a reputation beyond repute
Question
Eli,
1. On the 800 CFI is it possible for me (my Mechanic)to set the oil pump delivery ratio to 32:1?
2. Is there a specific setting on the oil pump for this ratio I can have my mechanic set it to or is it hit or miss?
  #10
Old 09-11-2011, 05:48 PM
NapaMatt's Avatar
Garage
  #11
Old 09-11-2011, 05:51 PM
Click Here to Register
The Following 4 Users Say Thank You to mountainhorse For This Useful Post:
94fordguy (09-11-2011), Bagger (09-12-2011), Creek Chub (09-11-2011), Matte Murder (09-11-2011)
  #12
Old 09-11-2011, 06:00 PM
byeatts byeatts is offline
Currently: Not set.
byeatts has a reputation beyond reputebyeatts has a reputation beyond reputebyeatts has a reputation beyond reputebyeatts has a reputation beyond reputebyeatts has a reputation beyond reputebyeatts has a reputation beyond reputebyeatts has a reputation beyond reputebyeatts has a reputation beyond reputebyeatts has a reputation beyond reputebyeatts has a reputation beyond reputebyeatts has a reputation beyond repute
The Following User Says Thank You to byeatts For This Useful Post:
  #13
Old 09-11-2011, 06:03 PM
Currently: Not set.
  #14
Old 09-11-2011, 06:05 PM
richracer1's Avatar
richracer1 richracer1 is online now
Currently: Gone Boosted
richracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond repute
The Following 2 Users Say Thank You to richracer1 For This Useful Post:
  #15
Old 09-11-2011, 07:55 PM
  #16
Old 09-11-2011, 08:01 PM
The Following 3 Users Say Thank You to mountainhorse For This Useful Post:
Creek Chub (09-11-2011), NapaMatt (09-11-2011), Norway (09-12-2011)
  #17
Old 09-11-2011, 09:09 PM
FTXMOTORSPORTS's Avatar
FTXMOTORSPORTS FTXMOTORSPORTS is offline
Currently: workin' for a livin'
FTXMOTORSPORTS has a reputation beyond reputeFTXMOTORSPORTS has a reputation beyond reputeFTXMOTORSPORTS has a reputation beyond reputeFTXMOTORSPORTS has a reputation beyond reputeFTXMOTORSPORTS has a reputation beyond reputeFTXMOTORSPORTS has a reputation beyond reputeFTXMOTORSPORTS has a reputation beyond reputeFTXMOTORSPORTS has a reputation beyond reputeFTXMOTORSPORTS has a reputation beyond reputeFTXMOTORSPORTS has a reputation beyond reputeFTXMOTORSPORTS has a reputation beyond repute
The Following 29 Users Say Thank You to FTXMOTORSPORTS For This Useful Post:
05 tmk 900 (01-25-2013), 94fordguy (12-04-2011), akrevrider (09-11-2011), allpowersports (09-12-2011), AMSOILR (01-19-2014), Bagger (09-12-2011), Bossman (12-02-2012), bubba94 (12-01-2012), Creek Chub (09-12-2011), diamonddave (09-14-2011), E-Zmoke 4:20 (08-05-2012), Eli (09-11-2011), enis750 (12-04-2011), Idahodoo (01-15-2012), Matte Murder (09-11-2011), MORSNO (09-11-2011), mountainhorse (09-11-2011), NapaMatt (09-12-2011), Norway (09-12-2011), oldxlt (01-19-2012), Oregonsledder (09-11-2011), rmk2112 (01-11-2012), rmk727 (09-12-2011), rwt (12-06-2011), Ski-Dont89 (09-11-2011), skippy (10-12-2011), tweeds (01-19-2014), victorsledneck (12-04-2011), Vinnee (12-10-2011)
  #18
Old 09-11-2011, 09:15 PM
2XM3's Avatar
2XM3 2XM3 is online now
Currently: 2016 axys
2XM3 has a reputation beyond repute2XM3 has a reputation beyond repute2XM3 has a reputation beyond repute2XM3 has a reputation beyond repute2XM3 has a reputation beyond repute2XM3 has a reputation beyond repute2XM3 has a reputation beyond repute2XM3 has a reputation beyond repute2XM3 has a reputation beyond repute2XM3 has a reputation beyond repute2XM3 has a reputation beyond repute
  #19
Old 09-11-2011, 10:41 PM
Matte Murder Matte Murder is online now
Currently: Almost riding season for me!.
Matte Murder has a reputation beyond reputeMatte Murder has a reputation beyond reputeMatte Murder has a reputation beyond reputeMatte Murder has a reputation beyond reputeMatte Murder has a reputation beyond reputeMatte Murder has a reputation beyond reputeMatte Murder has a reputation beyond reputeMatte Murder has a reputation beyond reputeMatte Murder has a reputation beyond reputeMatte Murder has a reputation beyond reputeMatte Murder has a reputation beyond repute
  #20
Old 09-12-2011, 04:20 AM
  #21
Old 09-12-2011, 06:20 AM
rmk727's Avatar
rmk727 rmk727 is offline
Currently: Turbo sucked, pro rmk 155
rmk727 has a reputation beyond reputermk727 has a reputation beyond reputermk727 has a reputation beyond reputermk727 has a reputation beyond reputermk727 has a reputation beyond reputermk727 has a reputation beyond reputermk727 has a reputation beyond reputermk727 has a reputation beyond reputermk727 has a reputation beyond reputermk727 has a reputation beyond reputermk727 has a reputation beyond repute
  #22
Old 09-12-2011, 07:21 AM
2XM3's Avatar
  #23
Old 09-12-2011, 09:48 AM
The Following 10 Users Say Thank You to FTXMOTORSPORTS For This Useful Post:
Bagger (09-12-2011), Creek Chub (09-12-2011), diamonddave (09-14-2011), E-Zmoke 4:20 (08-05-2012), enis750 (12-04-2011), NapaMatt (09-12-2011), Norway (09-12-2011), Ryanlilly (09-16-2011), skippy (10-12-2011), Vinnee (12-10-2011)
  #24
Old 09-12-2011, 10:37 AM
RMK-King's Avatar
RMK-King RMK-King is online now
Currently: Not set.
RMK-King has a reputation beyond reputeRMK-King has a reputation beyond reputeRMK-King has a reputation beyond reputeRMK-King has a reputation beyond reputeRMK-King has a reputation beyond reputeRMK-King has a reputation beyond reputeRMK-King has a reputation beyond reputeRMK-King has a reputation beyond reputeRMK-King has a reputation beyond reputeRMK-King has a reputation beyond reputeRMK-King has a reputation beyond repute
  #25
Old 09-12-2011, 10:55 AM
trestlecreek trestlecreek is online now
Currently: Not set.
trestlecreek has a reputation beyond reputetrestlecreek has a reputation beyond reputetrestlecreek has a reputation beyond reputetrestlecreek has a reputation beyond reputetrestlecreek has a reputation beyond reputetrestlecreek has a reputation beyond reputetrestlecreek has a reputation beyond reputetrestlecreek has a reputation beyond reputetrestlecreek has a reputation beyond reputetrestlecreek has a reputation beyond reputetrestlecreek has a reputation beyond repute
The Following User Says Thank You to trestlecreek For This Useful Post:
mountainhorse (09-12-2011)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — help with fuel to oil ratio? thanks Thread Starter — troyburt Forum — Arctic Cat: M Series Replies — 1 Last Post — 01-10-2011 10:50 AM
Thread — My new Pro R oil line is empty where it comes out of the oil tank. ??? Thread Starter — snow4me Forum — Polaris: Pro-Ride Replies — 8 Last Post — 11-18-2010 10:13 AM
Thread — what is your oil ratio Thread Starter — pura vida Forum — Polaris Replies — 3 Last Post — 02-09-2009 04:50 PM
Thread — How do you get your oil ratio... Thread Starter — sledstormed Forum — Arctic Cat Replies — 13 Last Post — 01-06-2009 11:39 PM
Thread — what is your oil ratio Thread Starter — pura vida Forum — Polaris Replies — 9 Last Post — 01-31-2008 04:25 PM
no new posts
