Upgrade to Premium
Yamaha: 2-stroke Includes all Yamaha 2-strokes, Viper, Mountain Max, etc
Reply
  #1
Old 12-12-2010, 05:33 PM
BaunsyC BaunsyC is offline
Currently: Not set.
Basic Member
BaunsyC is an unknown quantity at this point
Default 00' mm 700 primary clutch question
I am being re-introduced to snowmobiling and have been given a 00' mm 700 with a grenaded primary clutch. My question is what is the best option for replacement. I have read that the p-85 will work. is there and specific year or sled that it would come off of that would be best? What about a comet clutch? same question what do I have to look for to make sure that it will work. I understand about the weights and the springs having to be set up for my sled I am much more concerned with fitting on the sled without modifications to the sled? Thanks for your help.
Rate this post: Yes | No
  #2
Old 12-12-2010, 06:21 PM
SRXSRULE SRXSRULE is online now
Currently: Not set.
SRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond repute
Default
With out a doubt.....Get another yamaha clutch to put back on it. They use the same clutch from about 1996-2011 on almost ever modle. Just pick up a used one off e-bay or on here and put the correct spring and weights in it for your area.
These clutches hold up just fine on 200-300hp turbo 4-strokes. The only time they fail is when they have the wrong set-up in them, are overheated from belt slipping and cause stress cracks.
The primary on my Apex has 6800 miles on it and is in great condition. Eric
The Following User Says Thank You to SRXSRULE For This Useful Post:
Ford428CJ (12-12-2010)
  #3
Old 12-12-2010, 07:06 PM
TRUEBLUEMAX TRUEBLUEMAX is offline
Currently: Just got the 16 Cat LE Yahoo!!
TRUEBLUEMAX has a reputation beyond reputeTRUEBLUEMAX has a reputation beyond reputeTRUEBLUEMAX has a reputation beyond reputeTRUEBLUEMAX has a reputation beyond reputeTRUEBLUEMAX has a reputation beyond reputeTRUEBLUEMAX has a reputation beyond reputeTRUEBLUEMAX has a reputation beyond reputeTRUEBLUEMAX has a reputation beyond reputeTRUEBLUEMAX has a reputation beyond reputeTRUEBLUEMAX has a reputation beyond reputeTRUEBLUEMAX has a reputation beyond repute
Default
I would agree get a stock clutch if you can salvage the weights or at least see what you had in it that would make it easy to set up the clutch.
  #4
Old 12-12-2010, 07:07 PM
Ford428CJ's Avatar
Ford428CJ Ford428CJ is offline
Currently: FE FREAK!!!
Ford428CJ has a reputation beyond reputeFord428CJ has a reputation beyond reputeFord428CJ has a reputation beyond reputeFord428CJ has a reputation beyond reputeFord428CJ has a reputation beyond reputeFord428CJ has a reputation beyond reputeFord428CJ has a reputation beyond reputeFord428CJ has a reputation beyond reputeFord428CJ has a reputation beyond reputeFord428CJ has a reputation beyond reputeFord428CJ has a reputation beyond repute
Default
What are the models??? I'm just wondering is all.... Thanks for the help
__________________
Wes Adams, Mr.Triple
Gotta have a Triple in the crowd!
http://www.hillsideauto.org/
www.facebook.com/HillsideAuto1
http://www.amsoil.com/index.aspx?zo=1987784
  #5
Old 12-12-2010, 07:37 PM
Currently: Not set.
Basic Member
Default
Unfortunately the only thing salvagable is the main spring the rollers and weights are broken or just missing. I have to start from scratch. I have been looking at the other clutches because the seem to be less expensive than the yamaha clutch.
  #6
Old 12-12-2010, 08:08 PM
Givemeaboost's Avatar
Givemeaboost Givemeaboost is online now
Currently: Not set.
Givemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond repute
Default
Stay with the Yamaha clutch. I've got over 9000 miles on my original clutch without rebuilding it. Just blow it out with compressed air after every ride.
Ken...
__________________
03 rx1 mtn with homebuilt turbo , 159 finger track , Rev tank and seat. 01 Mountain Max
  #7
Old 12-12-2010, 10:21 PM
Ford428CJ's Avatar
Default
I just went through my Yammi clutch. I weighed them out (fly weights) and they are 45g a piece. And it has a Black spring with a white dot (might be Bender but I'm not sure) Works great. My MM has Bender pipes on it. Stock gearing, 141" track.
Hope that helps ya for a starting point!
__________________
  #8
Old 12-13-2010, 07:36 PM
twincam88 twincam88 is offline
Currently: Hope 240 is enough?!
twincam88 has a reputation beyond reputetwincam88 has a reputation beyond reputetwincam88 has a reputation beyond reputetwincam88 has a reputation beyond reputetwincam88 has a reputation beyond reputetwincam88 has a reputation beyond reputetwincam88 has a reputation beyond reputetwincam88 has a reputation beyond reputetwincam88 has a reputation beyond reputetwincam88 has a reputation beyond reputetwincam88 has a reputation beyond repute
Garage
Default
pay the extra cash for a yamaha clutch. check with wreckers. where are you located?
  #9
Old 12-13-2010, 08:11 PM
Currently: Not set.
Default
I just looked on e-bay, there are dozens of them on there between 250-350. Eric
  #10
Old 12-13-2010, 09:52 PM
Currently: Not set.
Basic Member
  #11
Old 12-13-2010, 10:57 PM
Currently: Not set.
Basic Member
Click Here to Register
  #12
Old 12-13-2010, 11:31 PM
sledmaniak sledmaniak is offline
Currently: waiting for extended winter
sledmaniak has a reputation beyond reputesledmaniak has a reputation beyond reputesledmaniak has a reputation beyond reputesledmaniak has a reputation beyond reputesledmaniak has a reputation beyond reputesledmaniak has a reputation beyond reputesledmaniak has a reputation beyond reputesledmaniak has a reputation beyond reputesledmaniak has a reputation beyond reputesledmaniak has a reputation beyond reputesledmaniak has a reputation beyond repute
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread — 98 MM 700 Clutch Question Thread Starter — Rock Valley Rider Forum — Yamaha: 2-stroke Replies — 2 Last Post — 11-23-2010 04:53 PM
Thread — 00 MM 700 Mod Thread Starter — thierracing Forum — Yamaha: 2-stroke Replies — 5 Last Post — 11-18-2010 11:47 PM
Thread — Primary Clutch Bolt Torque - 32 mm crank Thread Starter — High Velocity Forum — Polaris: 900 Replies — 17 Last Post — 11-16-2010 12:06 AM
Thread — wtb 97 yamaha mm 700 primary clutch Thread Starter — mtmtnrider Forum — WTB (Swapmeet) Replies — 4 Last Post — 05-02-2008 10:40 PM
Thread — WTB Primary Clutch for 98 Yamaha MM Thread Starter — Sledsniper Forum — Clutch/Drive Train/Belt (Swapmeet) Replies — 2 Last Post — 12-19-2007 03:32 PM
no new posts
