Thanks for the KMOD suggestion however I plan to continue working with the stock suspension.
In general, other than a turbo, I find aftermarket parts do NOT provide a good return on investment. Most upgrades are nothing but eye candy or jewelery. I not saying the KMOD is in that category however I'm sure there are more cost effective options that have a far superior return.
Someone must have cost effective options that work with the stock suspension? Rear suspension coupling blocks would make sense.
Thanks!
I have never had a return as good as what the kmod gives on a turbo.
Get off the crack pipe, I actually know the difference and the a turbo without a kmod just as well be half a turbo or less, not only does the kmod do more than you ever imagine, it holds real value and AT LEAST doubles the value of the turbo when it come to total control and full use of power.
I have not found a single product that was worth so much in this application.
I'm not saying you can't find a way to do something that will work, you very well may, but you have no idea, the kmod is so cheap for what you get and the value it adds the ability and full potential of the turbo.
