Upgrade to Premium
Arctic Cat: M Series 2005-Current, all models in the M-series chassis
Reply
  #1
Old 10-01-2018, 07:48 PM
Hardass's Avatar
Hardass Hardass is offline
Currently: Not set.
Hardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond repute
Default Ho cylinders on non ho???
have a set of ho cylinders head and valves for m8 can this be put on a 09 in a 09 chassis or is there more to it like ecu fly wheel you know what will it take
__________________
M 1000 modded but no turbo no way Uh well maybe
Rate this post: Yes | No
  #2
Old 10-06-2018, 12:20 PM
M8CAT M8CAT is online now
Currently: Not set.
M8CAT is an unknown quantity at this point
Default
You will need a new y-pipe as well but other then that bolts on and works good!
  #3
Old 10-08-2018, 09:50 PM
Hardass's Avatar
Currently: Not set.
Default
but can i run all the 09 stuff with that head y pipe a valves and cylinder is that it no ecu ?
__________________
  #4
Old 10-12-2018, 11:13 AM
Thunder101 Thunder101 is offline
Currently: making room in the garage :)
Thunder101 has a reputation beyond reputeThunder101 has a reputation beyond reputeThunder101 has a reputation beyond reputeThunder101 has a reputation beyond reputeThunder101 has a reputation beyond reputeThunder101 has a reputation beyond reputeThunder101 has a reputation beyond reputeThunder101 has a reputation beyond reputeThunder101 has a reputation beyond reputeThunder101 has a reputation beyond reputeThunder101 has a reputation beyond repute
Default
Yes you can run the HO cylinders on the 09.
Things to know:
exhaust studs are a bit farther apart
you will need the HO exhaust valves
depending on how rich your 09 is you may need a fuel controller.
The Following User Says Thank You to Thunder101 For This Useful Post:
matt159 (10-12-2018)
  #5
Old 12-28-2018, 09:40 PM
Hardass's Avatar
Currently: Not set.
Default
we have turned up the fp all is good
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — WTB 80HO core cylinders or 827 cylinders Thread Starter — rheinss10 Forum — WTB (Swapmeet) Replies — 3 Last Post — 01-25-2014 11:53 PM
Thread — ZRT cylinders/ZR 700 cylinders Thread Starter — firecat99 Forum — Engine/Engine Parts (Swapmeet) Replies — 2 Last Post — 06-25-2012 09:33 PM
Thread — WTB Polaris 800 cylinders & VES 700 cylinders Thread Starter — Turbobusa Forum — Engine/Engine Parts (Swapmeet) Replies — 3 Last Post — 07-06-2009 11:33 PM
Thread — Trade AC 900 ported cylinders for 900 stock cylinders Thread Starter — lightcat900 Forum — Engine/Engine Parts (Swapmeet) Replies — 2 Last Post — 11-06-2008 06:44 PM
Thread — Cylinders, cylinders & more cylinders Thread Starter — junkman Forum — Engine/Engine Parts (Swapmeet) Replies — 0 Last Post — 10-17-2008 07:58 PM
no new posts
