Stock can for 06 switch
D
Nov 2, 2008
79
14
8
46
Will a stock can fit on a htg pipe? I'm not concerned about weight, just need to get rid of the twin stingers for trail riding.
Also, is the y pipe to main pipe donut is the same as stock size?
Lastly, what springs are available for the y pipe to pipe? The shortest I could find hardly put any pressure holding the two together. The gap is probably 1.25" but standard are too long, and the shortest I can find at the hardware store are too long also. What else is out there for options,l?
Thanks all
Dman
guidoxpress
5,105
1,506
Wasilla, AK from MT
Yes the muffler will work with that pipe.
ALL pipe uses stock donuts.
If the springs are stretched I would replace them. If they are tight, stick a screwdriver in the small spring tabs on the pipe and y-pipe and SLOWLY bend them outward creating a wider gap for the spring. It will cause it to pull harder together ;)
