O
It appears my 09XP runs better at 7900 while my 08XP runs best at 8150. With all thing o the sled being equal. Anyone else have an 800R that runs best at 7900 ?
OT
OT
OT
ditto on the clicker position, always have had more track speed on position 1 or 2 with rpms be of lesser importance,on zx and rev sleds starting to think that about the 09 xp as well.
That probally has more to do with the primary shifting better due to the ramp being not as steep. If you get a setup that shifts hard and runs at target RPM and loads the motor it works even better. Most the reason everyone feels the run better at lower RPM is becuause the primary is shifting better. Most of the setup just rev and don't bite when at target 8150, the motor makes more HP at 8150, the key is getting the motor loaded and primary shifting hard at that RPM.
okay ,if your target rpm is 8200 ish but your sled makes power from 7850 to 8300 ,within a few ponies ,the sweet spot is a lot wider than 150 revs. power valves open at what rpm ? somewhere around 7400 . intresting stuff
