Had some crazy things going on with my 15' summit t3. This morning started sled and would not rev up at all just bog or limp mode. Hooked up the Candoo and this is where it gets weird, The Tps is reading the rave valve volts and position and the rave monitoring system on candoo is reading the TPS position and volts. Would the ECU cause this as I tested the rave sensor and am getting 5V and signal wire is producing correct readings as well as the TPS reading 5V and reading correct signal voltage. I have no idea what else could be causing this crazy stuff. Please Help if you have run into a problem like this. The ecu is not throwing any codes on the candoo what so ever.
