im have been getting pretty heavy into sledding here in the past few years, buying a new piece of clothing ever year (its spendy so i need to take my time) and now i am wondering, what do you all wear for base layers and such? i ride in anywhere from -10 to 40 degree weather, and where just a long sleeve t shirt a car hart hoodie and my polaris coat. my jeans with some bids over top. the bottom layer does not bug me, however if there is somehting better i would like to know. the biggest thing is the hoodie i wear keeps me warm, but its so bulky it limits my ability to move my body around 100%. what should i get to wear under my coat?
There have some really good suggestions for base layers. I'm happy to be a poster boy for Klim. :humble: Their stuff has always worked flawlessly for me. This came after years of frustration with other brands. Is it the only way to stay warm and dry? No, they just make it really easy for you. The Aggressor is their base layer. Simple functional moisture wicking under garments. Then they make some options for mid layers. The Inferno is probably the most common. Lightweight comfortable fleece. This is the most I would ever need even in 20 below. I ride similar conditions to yourself, but am very warm blooded. I have yet to even wear this riding. :noidea:Very comfortable to wear around the house or hotel though. If you are very cold blooded they also have an Everest line of mid layers. Heavier fleece material, but very comfortable and still easy to move around in.
Again, most of the manufactures and outdoor companies make similar products to suit your needs. Klim just makes it easy. Under armour is a very good suggestion. As stated earlier the important part is that the material is
moisture wicking.
Standard t-shirts and hoodies are typically poor choices for back country riding. You are layering up from experience that you get cold. The more you layer, the more quickly you start to sweat. The moisture stays next to your body and especially your core causing you to get cold and stay cold. So you are bulky and cold.
Jeans aren't the best idea these days either for the same reasons. I'm not sure what brand of bibs you have? Again, I am a big advocate of Klim because they use Gore-Tex. It is very hard to beat this material. Waterproof and breathable. Meaning it will keep water and moisture out and if you start to sweat it will displace the moisture to the outside. I personally have a hard time justifying a different brand when the others are so closely priced these days. They are good products depending on your requirements, but I have yet to see anything perform better than good ol Gore Tex. Progress is being made with similar materials. From my experience however, they still aren't at the level of performance and durability, but there are options. If you are considering bibs, I would take a good look at the Klim Extreme bib. Probably the best bang for the buck in a Gore Tex bib.
That has been my experience. Hope that helps. I know some people really like the HMK line too. I just have never used it. In the end it doesn't matter what brand you buy. It just has to work for
you.
