Technical info pro rmk rear suspension width
fgauvin7
92
116
33
Hi, I'm on a projet and I want to use a pro rmk 155 rear skid
the reason of the post is, I need to know the outside width of the swing arm on a pro suspension (see picture). If someone have one of theses suspension or even just a swing arm laying around and be nice enough to take the measurement for me, I would apreciate a lot.
Just take it as precise as you can, with this I should be able to incorporate the dimension in my CAD model.
thanks a lot
(If possible, the front and rear swing arm to ensure they are the same width.)
fgauvin7
92
116
33
Thanks for your reply, I dont seem to find it where you are pointing me (part #17)... here is a screen shot. Maybe I'm looking at the wrong place also
thanks in advance
sledhed
1,751
435
Lolo, Montana
Hmph. I saw it there I swear. I was comparing the front and rear inner shafts between Pro suspension and IQ Raw suspension, the shafts were the same size but I had to convert from metric to standard to make sure since the Pro is metric. The bolts are different, metric on Pro, standard on Dragon. Let me check out where I saw that...
Ok, looking at the 2012 800 Pro RMK microfiche it has the dimensions of item 7 which (I will check) is the same shaft front and rear. Here is the URL I am using (local dealer for me):
HERE
Pics attached.
Rear shaft part number and dimensions: 5137223 SHAFT-19.05 X 391.414
Front shaft part number and dimensions: 5137223 SHAFT-19.05 X 391.414
SNWMBL
375
125
AK
I have 2015 arms in front of me. The front and rear cross shafts are the same at 15.4375" wide.
fgauvin7
92
116
33
Thanks a lot to both of you! Exactly the information that I wanted!
G
geo
2,170
2,336
Kamloops B.C.
Just ASSuming something from the pictures in your posts.
I installed a Pro skid into a M7. Best thing we've done to the old antique. Needed the assault rails to make it an easier install though.
fgauvin7
92
116
33
Thanks Geo, but it is not for the cat, I'm on a custom project and I build everything in CAD before building it. I dont have all the parts in hand already so I try to find all the information to draw it as accurate as possible. Over the time I will try to find and grab good deal on the parts that I need.
thanks
Jul 24, 2013
I need to get some information about the front torque arms as well.
I have been looking at the part numbers and the 2012 Pro front torque arm is part number 154272-329 and the 2014 (which I have) is 1543026-329.
I have busted up my 2014 arm and am looking at replacing it with a 2012. The difference I see from the parts fiche is the inside diameter of the 2012 is 19.05 (.75) vs the 2014 which takes a .8 shaft.
The reason im looking at changing this is I could easily put a .75 solid steel rod in the 2012 for better support as this is the 2nd time I have busted the front torque arm. The .80 rod would be harder to find and might even be a machined item. I don't have access to a lathe so I am doing this with the tools I have available.
A couple questions about this. Could somebody measure the inside and outside diameters of the upper tube from a 2012 and from a 2014 for me? I would like to know if the 2014 tube is a larger outside diameter than the 2012 or what was done when the larger shaft was used in the newer models.
Whats you thought on this mod?
