Can anyone identify this connector?
I
izzni
736
513
Vadnais Heights
This the connector that plugs into the back of the gauge. Can anyone identify the manufacturer and/or series of it? It's a 24 position one.
Here's the pins in the back of the gauge:
I
izzni
736
513
Vadnais Heights
Is there a prize for the correct answer?
A free data logger that will record at least RPM, Speed, Engine Temp, Fuel, and Voltage Level. It will display the data on any android phone or tablet. It will be mailed to whoever identifies it first at the end of June.
lt reward enough? :)
LoudHandle
3,900
2,775
Valdez, AK
Am I the winner? Lucky recipient?
I just ordered a few, let me find the invoice. I'll update this post momentarily. I believe I sourced them thru Mouser.
Delphi, Micro-Pack, 100W Series; The part numbers / links are the exact parts to make / fit the Polaris PRO MFD.
Connector, Strain relief (Gray outer housing, with side exit port)(Delphi #12129811, Mouser #829-12129811) (1 Each)
http://www.mouser.com/Search/ProductDetail.aspx?R=12129811virtualkey63000000virtualkey829-12129811
Connector, Guide (White Inner housing)(Delphi #12129225-B, Mouser #829-12129225-B) (1 Each)
http://www.mouser.com/Search/Produc...5-Bvirtualkey63000000virtualkey829-12129225-B
Connector, Seal (Green, Silicone)(Delphi #12110403-B, Mouser #829-12110403-B) (1 Each)
http://www.mouser.com/Search/Produc...3-Bvirtualkey63000000virtualkey829-12110403-B
Connector, Pin Retainer Lock, (Black, Polycarbonate)(Delphi #12129183-B, Mouser #829-12129183-B) (1 Each)
http://www.mouser.com/Search/Produc...3-Bvirtualkey63000000virtualkey829-12129183-B
Pins, Gold Plated (Delphi #12129750, Mouser #829-12129750) (10 Each)
http://www.mouser.com/Search/ProductDetail.aspx?R=12129750-Lvirtualkey59690000virtualkey829-12129750
Cavity Plug (Blue, for unused pin ports) (Delphi #12129557, Mouser #829-12129557) (14 Each)
http://www.mouser.com/Search/ProductDetail.aspx?R=12129557virtualkey63000000virtualkey829-12129557
Connector, Safety Lock, (Red) Optional; (Delphi #12110299-B, Mouser #829-12110299-B) (Optional, 1 Each)
http://www.mouser.com/Search/Produc...9-Bvirtualkey63000000virtualkey829-12110299-B
Hawkster
8,122
6,380
AK
Is it a a 24 male & female Cadran ?
