Upgrade to Premium
Arctic Cat: Proclimb M 2012 and beyond
Reply
  #1
Old 02-23-2018, 06:14 PM
BBP BBP is offline
Currently: Not set.
Basic Member
BBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond repute
Default BDX/SSI Titanium Jackshaft
Anyone break one yet, are they stronger than the stock 14 shaft? I just broke my stock 14 shaft right behind the chaincase bearing & thinking of installing the Ti shaft. The Ti shaft is the 15 design & says it requires the 15 bearing. What's the difference between the 14-15 shafts & bearing? I'm running the MVM belt drive which came with a new bearing & a special bushing. Will the 15 Ti shaft bolt right in to the MVM bearing or will I need a different bearing &/or a different bushing?
Rate this post: Yes | No
  #2
Old 02-27-2018, 11:26 AM
boondocker97 boondocker97 is offline
Currently: working for the man
boondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond repute
Default
Curious on real world feedback on these too.
__________________
Current Sleds:
2014-2018ish BDX Pro-Lite 900, 2005 M7 with upgrades - Ol' Reliable, 1974 Cheetah
Still in the Family:
2009 M1300, 2001 Mountain Cat 800 LE, 1972 Kitty Cat
Gone but not Forgotten:
1999 Powder Special 600 LE, 1998 Powder Special 600, 1993 EXT 550, 1980 JAG 340
  #3
Old 02-27-2018, 05:40 PM
BBP BBP is offline
Currently: Not set.
Basic Member
Default
I talked to MVM today. According to them, the 15 shaft will fit into the bearing they supplied with the belt drive, without using the bushing. So, the 15 shaft must be substantially thicker in area where the bushing goes, which is also right where my 14 shaft broke. I'm thinking the 15 style Ti shaft should be plenty strong.
  #4
Old 02-27-2018, 11:01 PM
Default
TKI said the 2015 and 2016+ chain case bearings are the same too. He had heard that there's more twist in the Ti jackshafts. Twist is ok to me, but bending and getting the secondary out of line under power is not favorable to me. I don't see how you can have one and not the other.
__________________
Current Sleds:
  #5
Old 03-11-2018, 01:56 PM
BD-Xtreme's Avatar
BD-Xtreme BD-Xtreme is offline
Currently: Not set.
BD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond repute
Default Ti Jackshaft
We haven't had any Titanium shafts break ever.
They are light and strong! And in stock. Will fit 2012-15 models.
They have the snap ring grooves on them like stock, and also threaded on the end, so you can use it on a belt drive or just like stock.
12-14 models need to use the 2015 style bearing. We have in stock as well, they are only $14.95 each for the bearing.
The Following 2 Users Say Thank You to BD-Xtreme For This Useful Post:
BBP (03-20-2018), boondocker97 (03-11-2018)
  #6
Old 07-25-2018, 06:40 AM
officer farva officer farva is offline
Currently: Not set.
Basic Member
officer farva has a reputation beyond reputeofficer farva has a reputation beyond reputeofficer farva has a reputation beyond reputeofficer farva has a reputation beyond reputeofficer farva has a reputation beyond reputeofficer farva has a reputation beyond reputeofficer farva has a reputation beyond reputeofficer farva has a reputation beyond reputeofficer farva has a reputation beyond reputeofficer farva has a reputation beyond reputeofficer farva has a reputation beyond repute
Default
I've got about 1800 miles now at 185hp on my titanium jack shaft from bdx. No issues and absolutely love it! also have it tied to a tki belt drive. Shaft is tapped so you can just throw the upper gear on and the cup washer and go! Highly recommend it if you have a stock jackshaft or plan on running a belt drive!
The Following User Says Thank You to officer farva For This Useful Post:
BD-Xtreme (07-26-2018)
  #7
Old 07-25-2018, 10:09 AM
jim jim is online now
Currently: Keyboard highmarking at its best.
jim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond repute
Default
Yep. But there is more to it.
To compare materials; assume 1000 ft/lbs torque applied to a 1.5 inch diameter shaft that is 2 feet long.
Carbon Steel: 2.4 degrees twist at end of shaft
Titanium: 4.5 degrees twist at end of shaft
However, titanium has several advantages. Weight, obviously (56% the weight of steel); corrosion (Ti doesn't corrode...and corrosion will pit the surface and create/start small cracks that lead to failure in steel); fatigue life (Ti can be stressed over and over, usually at higher forces, and spring back without failure).
So, yeah, Ti will move a bit more but it doesn't really age/wear-out and it will be more reliable over time because you won't get corrosion cause cracks that grow and shear. And sometimes having a bit more "give" in a material is a great thing...a driveshaft and the shock loading it sees is the perfect application IMO. And one last thought...because the Ti gives a bit more, it will be kinder and transmit less stress back into to everything attached to it like bearings, gears/cogs, chassis, etc. Nerd out.
The Following 5 Users Say Thank You to jim For This Useful Post:
BD-Xtreme (07-26-2018), Edgecustomperformance21 (11-07-2018), ndfb35 (07-25-2018), officer farva (07-28-2018), sno*jet (07-27-2018)
  #8
Old 07-29-2018, 10:02 PM
sno*jet sno*jet is online now
Currently: Not set.
sno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond repute
Default
so why no ti shaft for 16+ cats?
  #9
Old 07-31-2018, 06:23 PM
Default
Quote:
Probably gets more expensive to start with that large diameter shaft and then machine it all the way out. Both on raw material as well as machining costs. Ti might not be as good for a bearing surface for the Team BOSS secondary that is on the 2016+ sleds. Lot smaller benefit/dollar compared to the hollow 2018+ Cat oem shafts.
__________________
Current Sleds:
  #10
Old 08-05-2018, 11:26 AM
BD-Xtreme's Avatar
Currently: Not set.
The Following User Says Thank You to BD-Xtreme For This Useful Post:
sno*jet (08-05-2018)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — BDX/SSI Titanium Mufflers now polished and... Thread Starter — BD-Xtreme Forum — Polaris: AXYS Replies — 3 Last Post — 02-07-2018 11:39 PM
Thread — BDX/SSI TITANIUM AND STAINLESS MUFFLER AND Y PIPE COMBO SALE Thread Starter — Speed Shop Inc. Forum — Ski-Doo: XP Sleds Replies — 0 Last Post — 11-07-2017 12:18 PM
Thread — BDX/SSI TITANIUM AND STAINLESS MUFFLER AND Y PIPE COMBO SALE Thread Starter — Speed Shop Inc. Forum — Ski-Doo: XM Sleds Replies — 0 Last Post — 11-07-2017 12:09 PM
Thread — BDX/SSI Titanium jackshaft installing problems Thread Starter — Passelat Forum — Arctic Cat: Proclimb M Replies — 21 Last Post — 02-12-2017 12:44 PM
Thread — BDX/ SSI Titanium Pipe Thread Starter — TimG Forum — Polaris: AXYS Replies — 14 Last Post — 02-01-2016 10:52 AM
no new posts
