Upgrade to Premium
Arctic Cat: Proclimb M 2012 and beyond
Reply
  #1
Old 04-26-2018, 05:48 PM
Wheeeezy9 Wheeeezy9 is offline
Currently: Not set.
Basic Member
Wheeeezy9 has a reputation beyond reputeWheeeezy9 has a reputation beyond reputeWheeeezy9 has a reputation beyond reputeWheeeezy9 has a reputation beyond reputeWheeeezy9 has a reputation beyond reputeWheeeezy9 has a reputation beyond reputeWheeeezy9 has a reputation beyond reputeWheeeezy9 has a reputation beyond reputeWheeeezy9 has a reputation beyond reputeWheeeezy9 has a reputation beyond reputeWheeeezy9 has a reputation beyond repute
Default 15 m8000 chain case oil change/removal
Hi!! I am in the process of doing some off season maintenance/ inspection ... I looked up and found a link to cat country service manaual .. how to remove the chain case cover ect...it looks like I have to remove ( partially ) my skid plate to get to bottom bolts of the chain case ... is this correct ? Just want to make sure before I tear into it? Any advice / tips would be appreciated! Thanks
Rate this post: Yes | No
  #2
Old 04-26-2018, 05:52 PM
kiliki kiliki is online now
Currently: Not set.
kiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond repute
Garage
Default
Just take a drill and drill two holes right over the front of them about 3/8 if the holes aren't already not there
  #3
Old 04-26-2018, 06:11 PM
Currently: Not set.
Basic Member
Default
? How do you remove those bottom bolts ?
  #4
Old 04-26-2018, 06:13 PM
Currently: Not set.
Garage
Default
Drill a hole through the plastic cover.
  #5
Old 04-26-2018, 06:17 PM
Currently: Not set.
Basic Member
Default
Ok ...I understand ! Thanks for the help!
  #6
Old 04-26-2018, 07:56 PM
XCaSSAULT's Avatar
XCaSSAULT XCaSSAULT is online now
Currently: Go MN Wild!
XCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond repute
Default
On my 15 there is two holes underneath right in line with the torx head bolts. Just enough room there to get the bit in there.
As for the torx heads...make damn sure u got the right size and get it in there flush and square before turning. I got all except 2 I had to notch for flat head cause they stripped. Then I went to hardware store and got stainless hex heads and threw away the damn torx
  #7
Old 04-27-2018, 09:12 AM
boondocker97 boondocker97 is offline
Currently: working for the man
boondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond repute
Default
I'd probably drill holes in the skid plate like kiliki said. They say to remove it so you can use the holes in the stock guard to access the bolts.
Side note: if you change out the torx bolts, you'll need some of the OEM ones around still if you ever have to change the chain case backer or do a MC drop and roll. The factory torx bolts have threads shaped to roll their own threads in the new parts. Results in stronger threads than tapping.
__________________
Current Sleds:
2014-2018ish BDX Pro-Lite 900, 2005 M7 with upgrades - Ol' Reliable, 1974 Cheetah
Still in the Family:
2009 M1300, 2001 Mountain Cat 800 LE, 1972 Kitty Cat
Gone but not Forgotten:
1999 Powder Special 600 LE, 1998 Powder Special 600, 1993 EXT 550, 1980 JAG 340
  #8
Old 04-27-2018, 11:44 AM
Currently: Not set.
Basic Member
Default
Good advice guys ... much appreciated... gonna hopefully tackle it this weekend... always hate those bottom bolts of the chain case cover.
  #9
Old 04-27-2018, 01:08 PM
dgiles dgiles is offline
Currently: Not set.
Basic Member
dgiles has a reputation beyond reputedgiles has a reputation beyond reputedgiles has a reputation beyond reputedgiles has a reputation beyond reputedgiles has a reputation beyond reputedgiles has a reputation beyond reputedgiles has a reputation beyond reputedgiles has a reputation beyond reputedgiles has a reputation beyond reputedgiles has a reputation beyond reputedgiles has a reputation beyond repute
Default
If you sled is stock, there is no drilling required. There already are holes aligned with these two bolts.
Also, easiest way is to remove the one torx holding the bottom side panel to the footwell brace. this will allow the side panel to flex outwards to get various lengths of torx to take out all the bolts. I use a ratchet with a few different extensions.
  #10
Old 04-27-2018, 01:34 PM
Currently: Not set.
Basic Member
  #11
Old 04-27-2018, 03:11 PM
Currently: Not set.
Basic Member
Click Here to Register
  #12
Old 04-27-2018, 06:21 PM
Currently: Not set.
Garage
  #13
Old 04-27-2018, 09:52 PM
Currently: Not set.
Garage
  #14
Old 04-28-2018, 02:35 AM
Currently: Not set.
Basic Member
  #15
Old 04-28-2018, 02:37 AM
Currently: Not set.
Basic Member
  #16
Old 04-28-2018, 05:05 PM
Currently: Not set.
Basic Member
  #17
Old 04-28-2018, 05:55 PM
Currently: Not set.
Garage
  #18
Old 04-28-2018, 07:01 PM
Currently: Not set.
Basic Member
  #19
Old 04-28-2018, 07:48 PM
XCaSSAULT's Avatar
  #20
Old 04-29-2018, 09:23 PM
Vern Vern is offline
Currently: '14 m8 SP 153-hyvos,dmnd-s, jaws
Vern has a reputation beyond reputeVern has a reputation beyond reputeVern has a reputation beyond reputeVern has a reputation beyond reputeVern has a reputation beyond reputeVern has a reputation beyond reputeVern has a reputation beyond reputeVern has a reputation beyond reputeVern has a reputation beyond reputeVern has a reputation beyond reputeVern has a reputation beyond repute
Garage
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Chain case removal Thread Starter — BigRedRider Forum — Arctic Cat: Proclimb M Replies — 2 Last Post — 02-21-2018 02:35 PM
Thread — 2013 change chain case oil? Thread Starter — Catrider144 Forum — Arctic Cat: Proclimb M Replies — 6 Last Post — 01-15-2015 10:54 AM
Thread — Chain Case Oil Change Rev XM Video Thread Starter — Norona Forum — Ski-Doo: XM Sleds Replies — 0 Last Post — 12-31-2012 01:47 PM
Thread — Can I keep the oil in chain case during gear change? Thread Starter — cpa Forum — Arctic Cat: Proclimb M Replies — 8 Last Post — 02-21-2012 11:35 AM
Thread — Summit 800 2003 Chain Case Oil Change Thread Starter — Dag19 Forum — Ski-Doo: ZX Sleds Replies — 12 Last Post — 12-28-2009 11:24 PM
no new posts
