Upgrade to Premium
Arctic Cat: M Series 2005-Current, all models in the M-series chassis
Reply
  #1
Old 04-25-2018, 09:15 PM
skidooboy's Avatar
skidooboy skidooboy is offline
Currently: titanium plate tester
skidooboy has a reputation beyond reputeskidooboy has a reputation beyond reputeskidooboy has a reputation beyond reputeskidooboy has a reputation beyond reputeskidooboy has a reputation beyond reputeskidooboy has a reputation beyond reputeskidooboy has a reputation beyond reputeskidooboy has a reputation beyond reputeskidooboy has a reputation beyond reputeskidooboy has a reputation beyond reputeskidooboy has a reputation beyond repute
Default oil reservoir change
we have 2 2009 m8 (non ho motors), both suffered from the egging of the filler cap. swapped both to rk tek's cap, and danos insert. the wifes sled melted the gauge/sender area so bad, the sender wont fit back in. had heat tape, and pipe wrap around the sender to prevent this, and it still melted (albeit 9 years of riding). it definitely needs a new tank now.
I did the searches but, came up empty. how hard is it to swap the tanks for a new one?
with the updated 2010-11 hood, shields, covers, sender, and tank... can you upgrade the 2008-09 to the newer 10-11 stuff?
seems the 10-11 tank, sender is cheaper than the older model. wondering if the sender harness from the 09 would plug into the 10-11 sender?
was planning on more heat tape, and the shield on the hood that comes on the 10-11 m's.
help is appreciated. if someone has a link to a install video, I would be grateful. Ski
riding northern ontario's back country
Rate this post: Yes | No
  #2
Old 04-26-2018, 07:25 PM
Coldfinger's Avatar
Coldfinger Coldfinger is offline
Currently: Not set.
Coldfinger has a reputation beyond reputeColdfinger has a reputation beyond reputeColdfinger has a reputation beyond reputeColdfinger has a reputation beyond reputeColdfinger has a reputation beyond reputeColdfinger has a reputation beyond reputeColdfinger has a reputation beyond reputeColdfinger has a reputation beyond reputeColdfinger has a reputation beyond reputeColdfinger has a reputation beyond reputeColdfinger has a reputation beyond repute
Default
Country Cat, I believe, has some service manuals you can download and they might explain what’s involved.
When I changed from oem can to slp, the underhood temps really went down as evidenced by the lack of heat coming out of the vent holes I drilled above the speedo. Used to do a great job defogging goggles and warming them up and now it still works but not nearly as well. 2010 m8.
Also, I tried the oil tank neck insert and didnt like the limited amount of threads to screw the cap onto. Unless I was very careful, the cap would deform and jump threads. I wanted something to keep the cap round so i placed a wrap of duct tape around the cap and then placed a hose clamp around the cap and took the insert out. Works perfect! I have not measured it, but if a piece of pvc pipe or something like that would fit snugly over cap, that would be even better.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Low oil sending unit plug into oil reservoir is loose. Thread Starter — redneckj Forum — Polaris: IQ Replies — 0 Last Post — 01-03-2016 08:45 PM
Thread — Oil Change/Filter Change on the Pro-Climb 1100T Thread Starter — Hilly Forum — Arctic Cat: 1100 ProClimb Replies — 3 Last Post — 01-18-2012 01:21 PM
Thread — Bypass oil reservoir and mix oil??? Thread Starter — 99rmksled Forum — Polaris: GEN 2 Replies — 1 Last Post — 12-18-2010 04:12 PM
Thread — M1000 oil reservoir change Thread Starter — Treebender Forum — Arctic Cat Replies — 7 Last Post — 12-14-2008 05:59 PM
Thread — oil reservoir on m8 Thread Starter — chousercat Forum — Arctic Cat Replies — 3 Last Post — 11-12-2008 09:56 PM
no new posts
