Upgrade to Premium
Arctic Cat: M Series 2005-Current, all models in the M-series chassis
Reply
  #1
Old 04-10-2018, 04:35 PM
Bergy12 Bergy12 is offline
Currently: Not set.
Basic Member
Bergy12 is an unknown quantity at this point
Default M7
Hi guys I just got a 2006 m7
It runs fine for a few minutes but when it starts to warm up it wont idol below 2500rpm.
Also when I open it and let-off quick it quits or cuts out for a second.
Any suggestions?
Thanks!!
Rate this post: Yes | No
  #2
Old 04-10-2018, 04:52 PM
kiliki kiliki is offline
Currently: Not set.
kiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond repute
Garage
Default
spray carb cleaner around the intake carb boots and seals for air leaks, if no air leaks replace the temp sending unit.
The Following User Says Thank You to kiliki For This Useful Post:
Bergy12 (04-10-2018)
  #3
Old 04-10-2018, 06:29 PM
Currently: Not set.
Basic Member
Default
K thanks I'll give it a try
  #4
Old 04-11-2018, 12:58 PM
Currently: Not set.
Basic Member
Default M7 running weird
My m7 is acting weird, for the first minute or so it runs fine but when if gets up to temp it won't idol below 2500 it just stays their until I go again then it starts cutting out when I let off.
I took the muffler off when I was looking for problems and found that it is bone dry inside, is that a problem? When I cleaned the power valves it was oily. I'm wondering if I put them in backwards could that be my problem?
If it is could somebody send me a picture of how they are supposed to be.
Thanks!
  #5
Old 04-12-2018, 03:39 PM
Readymedic's Avatar
Readymedic Readymedic is offline
Currently: How is 18/19 lookn'??
Readymedic has a reputation beyond reputeReadymedic has a reputation beyond reputeReadymedic has a reputation beyond reputeReadymedic has a reputation beyond reputeReadymedic has a reputation beyond reputeReadymedic has a reputation beyond reputeReadymedic has a reputation beyond reputeReadymedic has a reputation beyond reputeReadymedic has a reputation beyond reputeReadymedic has a reputation beyond reputeReadymedic has a reputation beyond repute
Default
Check the routing of the throttle cable. If it is pulled, it will idle higher, by pulling on the throttle body.
  #6
Old 04-23-2018, 11:34 AM
mbcat mbcat is offline
Currently: Not set.
Basic Member
mbcat has a reputation beyond reputembcat has a reputation beyond reputembcat has a reputation beyond reputembcat has a reputation beyond reputembcat has a reputation beyond reputembcat has a reputation beyond reputembcat has a reputation beyond reputembcat has a reputation beyond reputembcat has a reputation beyond reputembcat has a reputation beyond reputembcat has a reputation beyond repute
Default
Thanks!
Definitely your throttle cable. It's binding & throttle freeze up sensor is kickin in
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
no new posts
