Upgrade to Premium
Arctic Cat: M Series 2005-Current, all models in the M-series chassis
Reply
  #1
Old 03-26-2018, 07:37 PM
ratherbehunting ratherbehunting is offline
Currently: Not set.
Basic Member
ratherbehunting is an unknown quantity at this point
Default M8 Turbo Stutters
I've got a 2010 M8 162"
I installed a Cutler stage 3 turbo
Had no success with the Attitude controller
Running a Redline controller for the secondary injectors
Using the stock ECU with a Power Commander V and Autotune for the primaries.
The build runs very strong except it has a stutter that starts about 3750 RPM, maxs at 4000 and goes away around 4250 RPM.
Clutch engages at 3500 RPM.
I run 70% AV gas and 30% 94 with no detontation.
This stuttering appears to get worse with altitude which makes me think its rich.
I changed the Air/Fuel ratios from 13.5 to 15 and it ran much better but still stutters at altitude (5,000 ft plus).
I've been watching my pyrometers and we are not going over temp in that RPM range.
NGK BR9 plugs look coffee and cream. Turbo side pyro reads over 100C cooler than the clutch side at times. Others times very similar. Clutch side plugs very slightly lighter than the turbo side.
Any suggestions?
Go to 16/1 AF?
My map jumps to 12.5/1 under boost which occurs at about 4500 RPM. I thought the A/F map would be kind of linear from 16/1 to 12.5/1 but it's looking like more of a step from 15 (16)/1 to 12.5/1.
Anybody got experience with this?
Thanks In Advance!
Rate this post: Yes | No
  #2
Old 03-28-2018, 11:58 AM
jim jim is offline
Currently: Keyboard highmarking at its best.
jim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond repute
Default
Is it constant or intermittent?
I had a similar issue with my boondocker set-up with underhood intake. The hot air would send it into a rich bog-out that it sometimes would not recover from...same RPM range. Once I went to a cold air intake, I never had the problem again and the throttle response and overall power and all improved. Runs consistent day after day. And I can run less octane without detonation. Boondocker pump gas set-up, FYI.
  #3
Old 04-10-2018, 08:47 AM
Hardass's Avatar
Hardass Hardass is offline
Currently: Not set.
Hardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond repute
Default
Any suggestions?
Go to 16/1 AF?
Thanks In Advance!
Ecu and two different tuners holy cow what was wrong with the attitude? just curious as you have a lot going on there
__________________
M 1000 modded but no turbo no way Uh well maybe
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Video: Turbo Dragon, Turbo M7, Turbo Rx-1, Turbo Apex Thread Starter — xlr8r Forum — Mountain/Deep Powder Replies — 26 Last Post — 01-03-2012 08:53 AM
Thread — FYI...INFO ON 2012 SILBER TURBO PRO RMK TURBO KITS Thread Starter — mountainhorse Forum — Polaris: TURBO Replies — 31 Last Post — 09-17-2011 11:16 AM
Thread — 07 rev stutters Thread Starter — markoo Forum — Ski-Doo: REV Sleds Replies — 1 Last Post — 02-03-2011 11:02 AM
Thread — DEEP POWDER VIDS - Turbo Apex, Turbo Nytro, Turbo Rx-1 Thread Starter — xlr8r Forum — Mountain/Deep Powder Replies — 77 Last Post — 03-27-2008 06:36 PM
no new posts
