Upgrade to Premium
Reply
  #1
Old 12-27-2017, 05:54 PM
HANDSOME HANDSOME is offline
Currently: Not set.
HANDSOME has a reputation beyond reputeHANDSOME has a reputation beyond reputeHANDSOME has a reputation beyond reputeHANDSOME has a reputation beyond reputeHANDSOME has a reputation beyond reputeHANDSOME has a reputation beyond reputeHANDSOME has a reputation beyond reputeHANDSOME has a reputation beyond reputeHANDSOME has a reputation beyond reputeHANDSOME has a reputation beyond reputeHANDSOME has a reputation beyond repute
Default rebuild for an e tec
When should a person refreshen the top end for a 2014 800 ? The sled runs awesome but its close to 4000 km.
Rate this post: Yes | No
  #2
Old 12-28-2017, 12:10 PM
cubby's Avatar
cubby cubby is offline
Currently: Riding Atv's till the snow comes back
cubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond repute
Default
At 2500 miles and nothing wrong with it just run it. The owners manual says not even to change the plugs till 5000 miles. If your not having any problems just go with it no need to waste your money IMO
__________________
2016 T3 154"
2007 XRS 800 151" engine built by SHR
2013 Polaris 850xp
2015 Polaris 1000xp
2016 Polaris 170 RZR
Hold it pinned till you feel bad
The Following User Says Thank You to cubby For This Useful Post:
HANDSOME (02-25-2018)
  #3
Old 12-28-2017, 12:16 PM
treeboy treeboy is online now
Currently: Not set.
Basic Member
treeboy has a reputation beyond reputetreeboy has a reputation beyond reputetreeboy has a reputation beyond reputetreeboy has a reputation beyond reputetreeboy has a reputation beyond reputetreeboy has a reputation beyond reputetreeboy has a reputation beyond reputetreeboy has a reputation beyond reputetreeboy has a reputation beyond reputetreeboy has a reputation beyond reputetreeboy has a reputation beyond repute
Default
Do a cold and hot compression test, but I know of some people going a easy 10,000kms before a rebuild myself included.
The Following User Says Thank You to treeboy For This Useful Post:
  #4
Old 12-29-2017, 08:27 AM
Rick E Rick E is offline
Currently: Not set.
Basic Member
Rick E has a reputation beyond reputeRick E has a reputation beyond reputeRick E has a reputation beyond reputeRick E has a reputation beyond reputeRick E has a reputation beyond reputeRick E has a reputation beyond reputeRick E has a reputation beyond reputeRick E has a reputation beyond reputeRick E has a reputation beyond reputeRick E has a reputation beyond reputeRick E has a reputation beyond repute
Default
Quote:
What are your cylinder pressure readings (aka compression numbers).
It is best to use a gauge with the connecting hose/fitting, and be sure to cycle each cylinder through several strokes for each reading.
  #5
Old 01-03-2018, 01:11 PM
bnorth bnorth is offline
Currently: Slednuck
Basic Member
bnorth has a reputation beyond reputebnorth has a reputation beyond reputebnorth has a reputation beyond reputebnorth has a reputation beyond reputebnorth has a reputation beyond reputebnorth has a reputation beyond reputebnorth has a reputation beyond reputebnorth has a reputation beyond reputebnorth has a reputation beyond reputebnorth has a reputation beyond reputebnorth has a reputation beyond repute
Default
A dealer I trust says if you're riding it hard by 4000-4500km the piston skirts will be starting to collapse. Be honest with yourself about how hard you ride it though. More importantly IMO check the crank runout. Compression numbers on the etec don't mean much.
  #6
Old 01-03-2018, 03:15 PM
Goinboardin's Avatar
Goinboardin Goinboardin is offline
Currently: ..current
Goinboardin has a reputation beyond reputeGoinboardin has a reputation beyond reputeGoinboardin has a reputation beyond reputeGoinboardin has a reputation beyond reputeGoinboardin has a reputation beyond reputeGoinboardin has a reputation beyond reputeGoinboardin has a reputation beyond reputeGoinboardin has a reputation beyond reputeGoinboardin has a reputation beyond reputeGoinboardin has a reputation beyond reputeGoinboardin has a reputation beyond repute
Default
Quote:
My stock pistons were at the wear spec for skirt collapse at ~3500 miles. I put aftermarket dual ring cast replacement pistons in. ~1800 miles and they were a touch more collapsed than the OEM set. I probably advanced as a rider and put the aftermarket parts through more abuse, so not exactly a fair comparison. Neither sets ever failed, just reached service limits.
Running Wossner this season. With a fresh & trued crank, original had 0.0045" pto runout and bluing on the big end of the mag rod.
__________________
2013 XM 800 153
The Following User Says Thank You to Goinboardin For This Useful Post:
Blk88GT (01-05-2018)
  #7
Old 01-15-2018, 03:43 PM
big_red1a big_red1a is offline
Currently: Not set.
big_red1a has a reputation beyond reputebig_red1a has a reputation beyond reputebig_red1a has a reputation beyond reputebig_red1a has a reputation beyond reputebig_red1a has a reputation beyond reputebig_red1a has a reputation beyond reputebig_red1a has a reputation beyond reputebig_red1a has a reputation beyond reputebig_red1a has a reputation beyond reputebig_red1a has a reputation beyond reputebig_red1a has a reputation beyond repute
Default
[QUOTE=With a fresh & trued crank, original had 0.0045" pto runout and bluing on the big end of the mag rod.[/QUOTE]
I was told by dealer ski-doo spec was .003-.006" mine is currently .005"
  #8
Old 01-15-2018, 05:52 PM
Default
Quote:
Sounds like a misunderstanding or bad info from dealer. Right out of the service manual, deflection limit is 0.0024" on the PTO stub, 0.002" MAG. I would be thinking about fixing it.
Name:	engine specs 800etec.png
__________________
2013 XM 800 153
Blk88GT (01-16-2018)
  #9
Old 03-24-2018, 11:06 PM
snowmanx's Avatar
snowmanx snowmanx is offline
Currently: Excited about taking the M1000T for a rip!!
snowmanx has a reputation beyond reputesnowmanx has a reputation beyond reputesnowmanx has a reputation beyond reputesnowmanx has a reputation beyond reputesnowmanx has a reputation beyond reputesnowmanx has a reputation beyond reputesnowmanx has a reputation beyond reputesnowmanx has a reputation beyond reputesnowmanx has a reputation beyond reputesnowmanx has a reputation beyond reputesnowmanx has a reputation beyond repute
Default
Quote:
I know what the specs say, but EVERY crank I have ever checked was at .004 to .005 out. I have never seen astock crank in specs.
I just run them an i haven't had a crank failure.
Just my observation.
__________________
If you're not just a little scared, you're not high enough!!!!
Custom Vanamburg TM1000
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — FOR SALE: BIKEMAN CAN:BLACK 2011-16 E-TEC 800 OR E-TEC 600 POWDER LITE MUFFLER Thread Starter — MT_life Forum — Pipes/Cans (Swapmeet) Replies — 1 Last Post — 11-21-2016 04:25 PM
Thread — To rebuild or not to rebuild...that is the question Thread Starter — Snowcatrob Forum — Polaris: 900 Replies — 1 Last Post — 01-11-2016 06:35 AM
Thread — To rebuild or not to rebuild - 06 Rev 800HO Thread Starter — phillybean Forum — Ski-Doo: REV Sleds Replies — 15 Last Post — 12-23-2013 10:53 AM
Thread — new 2011 doo y pipes, 1 e tec, 1 p tec Thread Starter — lightening800 Forum — Engine/Engine Parts (Swapmeet) Replies — 0 Last Post — 05-15-2011 11:59 PM
Thread — rebuild of RXP 4 tec project Thread Starter — astro Forum — Member Sled Builds Replies — 14 Last Post — 01-27-2011 10:03 PM
no new posts
