Upgrade to Premium
Arctic Cat: Powder Special and older 2000 and older, all models in the Powder Special chassis and older chassis models
Reply
  #1
Old 03-23-2018, 08:28 PM
meckert meckert is offline
Currently: Not set.
Basic Member
meckert is an unknown quantity at this point
Default 97 zr580efi batteryless fuel pump
got a 97 zr580 efi batteryless and fuel pump problems. Stator ohms are all good cold and warm and fuel pump ohms at 2.0 at connector going to ecu. then at the pump connector after ecu its getting 14-17 dc volts when pulling sled over. Then when I plug the fuel pump back into connector voltage drops to 3.5 dc volts when pulling sled over and wont run pump to start sled. hook a battery directly to pump and sled runs fine at idle and throttling sled. with sled running off battery I get 17.1 steady volts at the connector for fuel pump from the ecu. would anybody possible know what my problem is or how to test to see whats going on? thank you
Rate this post: Yes | No
  #2
Old 11-12-2018, 06:35 AM
rhino6601 rhino6601 is online now
Currently: Not set.
Basic Member
rhino6601 has a brilliant futurerhino6601 has a brilliant futurerhino6601 has a brilliant futurerhino6601 has a brilliant futurerhino6601 has a brilliant futurerhino6601 has a brilliant futurerhino6601 has a brilliant futurerhino6601 has a brilliant futurerhino6601 has a brilliant futurerhino6601 has a brilliant futurerhino6601 has a brilliant future
Default
replace the stator...under load it shorts out.i have had this problem several times on these old cats
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Where can I get a fuel pump and could a weak fuel pump be affecting performance alot Thread Starter — cumminshp Forum — Arctic Cat: M Series Replies — 15 Last Post — 11-29-2012 03:01 PM
Thread — Fuel pump and oil pump wiring? Thread Starter — BigAir Forum — Arctic Cat: TURBO Replies — 5 Last Post — 02-27-2012 11:02 PM
Thread — 2007 Skidoo fuel tank w/fuel pump 600 SDI Thread Starter — aktrucker Forum — Carb/Airbox/Reeds (Swapmeet) Replies — 1 Last Post — 12-11-2011 01:15 PM
Thread — Fuel tank + Fuel Pump + Fuel Filter for 2006 900 RMK Thread Starter — Dogmeat Forum — Chassis/Tunnel (Swapmeet) Replies — 0 Last Post — 12-06-2010 07:48 PM
Thread — WTB AC: Fuel Pump, Oil Pump, Lower A-Arm Thread Starter — cokingcat Forum — Engine/Engine Parts (Swapmeet) Replies — 0 Last Post — 12-16-2008 12:38 AM
no new posts
