Upgrade to Premium
Arctic Cat: M Series 2005-2011, all models in the M-series chassis
Reply
  #1
Old 01-26-2010, 12:07 AM
bgreen776's Avatar
bgreen776 bgreen776 is offline
Currently: gimping around
bgreen776 has a reputation beyond reputebgreen776 has a reputation beyond reputebgreen776 has a reputation beyond reputebgreen776 has a reputation beyond reputebgreen776 has a reputation beyond reputebgreen776 has a reputation beyond reputebgreen776 has a reputation beyond reputebgreen776 has a reputation beyond reputebgreen776 has a reputation beyond reputebgreen776 has a reputation beyond reputebgreen776 has a reputation beyond repute
Thumbs up How I installed my BDX oil delete kit
I pulled the engine, split the cases, and milled a few pockets with a 1/2" end mill to collect oil. Then drilled a 3/16" hole to direct oil onto the gear that drives the water pump shaft, and another to direct oil behind the bushing in the oil delete kit. You could do all this work with a die grinder and a hand drill. I'll let the pictures speak for themselves.
ID:	96254   Click image for larger version
ID:	96255   Click image for larger version
__________________
Go time!
Rate this post: Yes | No
The Following 2 Users Say Thank You to bgreen776 For This Useful Post:
AaronBND (01-26-2010), tahomaniac (12-18-2015)
  #2
Old 01-26-2010, 12:20 AM
AaronBND's Avatar
AaronBND AaronBND is offline
Currently: Not set.
AaronBND has a reputation beyond reputeAaronBND has a reputation beyond reputeAaronBND has a reputation beyond reputeAaronBND has a reputation beyond reputeAaronBND has a reputation beyond reputeAaronBND has a reputation beyond reputeAaronBND has a reputation beyond reputeAaronBND has a reputation beyond reputeAaronBND has a reputation beyond reputeAaronBND has a reputation beyond reputeAaronBND has a reputation beyond repute
Default
Not to bust any chops here, but I don't understand? What is this oil hole in the picture going to do, or did you drill through the oil delete too? That would make sense if you did I guess. Also, what happens to the fuel getting sent into that sealed cavity with the oil? The crank bearings seal that compartment from premix getting in or out. That's why guys grease the waterpump shaft through the zerk they put in the bottom.
Aaron
The Following User Says Thank You to AaronBND For This Useful Post:
Deepsnowisthewaytogo (12-05-2010)
  #3
Old 01-26-2010, 12:26 AM
bgreen776's Avatar
Default
More pictures here.
__________________
Go time!
  #4
Old 01-26-2010, 12:29 AM
AaronBND's Avatar
Currently: Not set.
Default
Ok, so it looks like you went through the oil delete piece too. That will work, but I still don't understand how the fuel gets burnt going into this cavity? Thanks for the pics.
Aaron
  #5
Old 01-26-2010, 12:37 AM
bgreen776's Avatar
Default
The hole you circled goes through the lower case, through delete kit, into the cavity behind the oilite bushing. This receives oil slung off the crank gear. The crank gear receives oil from the hole drilled in the upper case.
__________________
Go time!
  #6
Old 01-26-2010, 12:42 AM
bgreen776's Avatar
Default
My take on it is that the oil/gas mixture will swirl around and exchange out through the bearings. There is no seal there. The snopro engines have a very similar port/drilling set up in the upper case to what I have done, but they dont have the hole through the bdx kit.
__________________
Go time!
The Following User Says Thank You to bgreen776 For This Useful Post:
  #7
Old 01-26-2010, 12:50 AM
bgreen776's Avatar
Default
Guys are greasing through the threaded hole in the bottom of the case, or are they greasing through the front of the delete kit, through a hole they drilled and tapped themselves? It doesn't make any sense to me to grease through the hole in the bottom of the case, but if it works, it works.
__________________
Go time!
  #8
Old 01-26-2010, 09:03 AM
AaronBND's Avatar
Currently: Not set.
Default
They are greasing through the hole in the bottom of the case right under the waterpump gear to lube the waterpump/crank gear teeth. Supposedly the oilite bushing in that BDX oil delete doesn't need oil. Here is a post from another thread:
Researching and putting a lot of thought into doing the BDX oil delete kit myself a few weeks ago, I honestly think you had trouble because we need to mix a stronger premix than BDX recommends. Maybe like 32:1 instead of 40:1. Looking at the pictures below of a M1000 case, you will see that the center section where the waterpump shaft is, is completely sealed off by the inner crank bearing seals. In the second picture, I also marked where the oil ports are on the outside of these seals in the case, to lube these inner crank bearings. You can also see in the second picture where these holes literally drop premix right into the bearings. In the second picture you can see where the seals ride in the case telling us that no premix can get in or out of that center section. This is why guys put the grease zerk in to lube the waterpump shaft. Honestly to me, it makes no sense at all drilling the cylinders to run premix down in this waterpump shaft section. How would the fuel part possibly get burnt? Engine heat evaporation? It sucks that it happened, but let it be a lesson to us guys that run it, to mix stronger than recommended.
  #9
Old 01-26-2010, 09:22 AM
bgreen776's Avatar
Default
The seals are a labrynth seal, they do allow for the trasfer of gas/oil to some degree. If those "seals" were an actual positive seal, then where would the oil thats injected into the cavity under the pump shaft go? The theory, as I see it, behind the milled cavity and the drilled hole is that lubrication will collect in the cavity, and the hole will create a pressure differential between the hole and the labby seal, causing gas/oil mixture to transfer.
There are many sleds out there with the bdx kit and no other modifications, that have many thousands of miles on them. Lube has got to be getting past the labbys, right? When I pulled my case apart, the cavity under the gear was just as clean as the rest of the case, indicating to me that there is some fuel going through there all the time.
__________________
Go time!
backcountryislife (02-26-2011), Deepsnowisthewaytogo (12-05-2010)
  #10
Old 01-26-2010, 02:29 PM
AaronBND's Avatar
Currently: Not set.
  #11
Old 02-26-2011, 08:21 AM
HCM HCM is offline
Currently: Not set.
HCM has a reputation beyond reputeHCM has a reputation beyond reputeHCM has a reputation beyond reputeHCM has a reputation beyond reputeHCM has a reputation beyond reputeHCM has a reputation beyond reputeHCM has a reputation beyond reputeHCM has a reputation beyond reputeHCM has a reputation beyond reputeHCM has a reputation beyond reputeHCM has a reputation beyond repute
Click Here to Register
  #12
Old 02-26-2011, 08:57 AM
backcountryislife's Avatar
backcountryislife backcountryislife is offline
Currently: almost ready for winter
backcountryislife has a reputation beyond reputebackcountryislife has a reputation beyond reputebackcountryislife has a reputation beyond reputebackcountryislife has a reputation beyond reputebackcountryislife has a reputation beyond reputebackcountryislife has a reputation beyond reputebackcountryislife has a reputation beyond reputebackcountryislife has a reputation beyond reputebackcountryislife has a reputation beyond reputebackcountryislife has a reputation beyond reputebackcountryislife has a reputation beyond repute
  #13
Old 02-26-2011, 11:19 AM
JasonAK JasonAK is offline
Currently: Not set.
JasonAK has a reputation beyond reputeJasonAK has a reputation beyond reputeJasonAK has a reputation beyond reputeJasonAK has a reputation beyond reputeJasonAK has a reputation beyond reputeJasonAK has a reputation beyond reputeJasonAK has a reputation beyond reputeJasonAK has a reputation beyond reputeJasonAK has a reputation beyond reputeJasonAK has a reputation beyond reputeJasonAK has a reputation beyond repute
The Following User Says Thank You to JasonAK For This Useful Post:
  #14
Old 02-26-2011, 11:56 AM
alexhack alexhack is offline
Currently: I'd rather be sledding!
alexhack has a reputation beyond reputealexhack has a reputation beyond reputealexhack has a reputation beyond reputealexhack has a reputation beyond reputealexhack has a reputation beyond reputealexhack has a reputation beyond reputealexhack has a reputation beyond reputealexhack has a reputation beyond reputealexhack has a reputation beyond reputealexhack has a reputation beyond reputealexhack has a reputation beyond repute
  #15
Old 03-01-2018, 08:49 AM
lasse lasse is offline
Currently: Not set.
Basic Member
lasse has much to be proud oflasse has much to be proud oflasse has much to be proud oflasse has much to be proud oflasse has much to be proud oflasse has much to be proud oflasse has much to be proud oflasse has much to be proud oflasse has much to be proud oflasse has much to be proud oflasse has much to be proud of
  #16
Old 03-01-2018, 09:54 AM
Thunder101 Thunder101 is offline
Currently: making room in the garage :)
Thunder101 has a reputation beyond reputeThunder101 has a reputation beyond reputeThunder101 has a reputation beyond reputeThunder101 has a reputation beyond reputeThunder101 has a reputation beyond reputeThunder101 has a reputation beyond reputeThunder101 has a reputation beyond reputeThunder101 has a reputation beyond reputeThunder101 has a reputation beyond reputeThunder101 has a reputation beyond reputeThunder101 has a reputation beyond repute
  #17
Old 03-01-2018, 10:59 AM
Currently: Not set.
Basic Member
  #18
Old 03-01-2018, 01:28 PM
  #19
Old 03-01-2018, 05:54 PM
Currently: Not set.
Basic Member
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
no new posts
