Upgrade to Premium
Arctic Cat: TURBO Turbo discussion for Arctic Cat aftermarket turbo sleds
Reply
  #1
Old 01-18-2018, 11:51 AM
fao1 fao1 is offline
Currently: Not set.
Basic Member
fao1 has a reputation beyond reputefao1 has a reputation beyond reputefao1 has a reputation beyond reputefao1 has a reputation beyond reputefao1 has a reputation beyond reputefao1 has a reputation beyond reputefao1 has a reputation beyond reputefao1 has a reputation beyond reputefao1 has a reputation beyond reputefao1 has a reputation beyond reputefao1 has a reputation beyond repute
Default turbo size
seen on OVS website taht they run gt30 series in their 800 etec, pro and M
what are the advantage to run with the gt30 ( less/more boost , lower/higer IaT , better/worst throttle response ,de/increased backpressure ?)
are the gt30 with turbin 0.63a/r equivalent to gt28 with turbine 0.86a/r in volume
Rate this post: Yes | No
  #2
Old 01-19-2018, 11:34 AM
Hardass's Avatar
Hardass Hardass is offline
Currently: Not set.
Hardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond repute
Default
i have a old m series the real one i use a 3071 but the 71 is a hta billit wheel suposedly it flows more. it also has the ss tial 63 on the hot side with a external gate. my tubing is all 3 inch. I have no comparisons with a smaller turbo but this one spools plenty good on the bottom i use mds weights.i have let no less than 75 strangers ride it none were disapointed at all it never has an issue and i built it my self (with two buddys)and it was not hard to do at all. Some times i would like to try a smaller turbo in there just to see but this thing runs great.. Not sure if this helps at all. And you know i thought it couldnt be true but everytime i push the flipper i really do just grin from ear to ear.
__________________
M 1000 modded but no turbo no way Uh well maybe
  #3
Old 01-19-2018, 11:37 AM
Hardass's Avatar
Currently: Not set.
Default
Because it moves more air you can run less boost and more timing and achieve what another turbo does turned up much higher. And you dont want a .86 on a 800
__________________
  #4
Old 01-19-2018, 03:21 PM
Fish10782 Fish10782 is online now
Currently: Trolling P-Hub
Basic Member
Fish10782 has a reputation beyond reputeFish10782 has a reputation beyond reputeFish10782 has a reputation beyond reputeFish10782 has a reputation beyond reputeFish10782 has a reputation beyond reputeFish10782 has a reputation beyond reputeFish10782 has a reputation beyond reputeFish10782 has a reputation beyond reputeFish10782 has a reputation beyond reputeFish10782 has a reputation beyond reputeFish10782 has a reputation beyond repute
Default
Gt28 is an old design turbo. Even the gt30 series are old.
They work well, but there are BETTER turbos.
Ovs uses comp turbos on most of their kits. It's a grease filled turbo, pretty maintenence free accept the rebuild every so often. The turbine is more efficient than the garret. Way more expensive too.
HTA turbos FLOW MORE AIR. that's fact. They spool faster, move more volume and its based on the gt series chra. Very expensive
I think anyone running a factory Garrett gt28 is only doing it for the cost because there are several other manufacturer that have the same sized turbo or even a modded gt that will out produce the factory Garrett.
Turbo technology has developed WAY beyond the gt series but yet most kits have them because of cost and its good enough. Spool time, cfm, throttle response ect can all be changed by a different turbo.
Don't expect to get the same result as he did by bolting on a garret gt3071.
The tial with the forced performance upgrades are what make that turbo run on his 800 the way it does.
  #5
Old 01-20-2018, 05:34 PM
Currently: Not set.
Basic Member
Default
Thanks for the reply
I was asking this because i’m at sea level to 2500’ so i was thinking about getting same hp than a conventional gt2860 but with less PSI
I might be wrong but More PSI = more heat and pressure in motor so dropping psi like 4psi for exemple and getting the same flow as a 2860 at 7psi would be great at sealevel. Might not need head cut or super high octan fuel.
What do yo think?
  #6
Old 01-26-2018, 12:13 PM
mk2g60's Avatar
mk2g60 mk2g60 is online now
Currently: Not set.
mk2g60 has a reputation beyond reputemk2g60 has a reputation beyond reputemk2g60 has a reputation beyond reputemk2g60 has a reputation beyond reputemk2g60 has a reputation beyond reputemk2g60 has a reputation beyond reputemk2g60 has a reputation beyond reputemk2g60 has a reputation beyond reputemk2g60 has a reputation beyond reputemk2g60 has a reputation beyond reputemk2g60 has a reputation beyond repute
Default
What do yo think?
You'll want to have the head machined and run race fuel. I've been running turbo's at sea level for a number of years and to run less than 10lbs of boost is a waste. Why spend the time and money if your not going to use the hp?
  #7
Old 02-01-2018, 08:20 AM
Currently: Not set.
Basic Member
Default
Quote:
Looking for 210-220 hp on a blend no head cut. 10psi might be awsome but i dont need it. Trees are tight here in the east!
Running a 850, was asking info since a lot of cats run bigger turbo and was wondering whats are the benefits.
  #8
Old 02-01-2018, 09:00 AM
Hardass's Avatar
Currently: Not set.
Default
well a bigger turbo moves more air so you can run less psi to get the same power also along with that it runs cooler it has enabled me to run 3 dagrees advanced timing with no top end retarder makes it snappier also i can run less fuel. im not a pro turbo builder but i did a ton of research befor i started looking for parts and built mine some things for the better like timing were discovered along the way. Your on the right path by reasearching it.
__________________
The Following User Says Thank You to Hardass For This Useful Post:
fao1 (02-20-2018)
  #9
Old 02-02-2018, 10:04 PM
mk2g60's Avatar
Currently: Not set.
Default
I'm about east as you can get and for years "turbo experts" would argue with me about having their heads machined for the fuel and boost they were running at sea level. Now after many blown up motors people are stating to listen. OVS said right from the start to machine the heads, they were dead on. Do what you want.
  #10
Old 02-04-2018, 12:48 PM
Hardass's Avatar
Currently: Not set.
  #11
Old 02-04-2018, 08:22 PM
Basic Member
Click Here to Register
  #12
Old 02-05-2018, 03:02 PM
Hardass's Avatar
Currently: Not set.
  #13
Old 02-05-2018, 08:18 PM
Basic Member
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — turbo size Thread Starter — fao1 Forum — Ski-Doo: TURBO Replies — 0 Last Post — 01-10-2018 10:02 PM
Thread — Turbo size Thread Starter — Snowedunder Forum — Arctic Cat: TURBO Replies — 1 Last Post — 08-09-2015 06:14 PM
Thread — Stinger Size in to the turbo on m8? Thread Starter — wildchild Forum — Arctic Cat: TURBO Replies — 1 Last Post — 05-07-2010 08:33 AM
Thread — Turbo size Thread Starter — Turbo11T Forum — Performance/Modified Replies — 2 Last Post — 01-11-2009 08:21 PM
no new posts
