Upgrade to Premium
Yamaha: Boosted Sleds (Turbo or Supercharged) Turbo discussion for Yamaha aftermarket Turbo or Super Charged sleds.
Reply
  #1
Old 01-16-2018, 11:08 PM
quadtrac quadtrac is offline
Currently: Burning AV-GAS!
quadtrac quadtrac quadtrac quadtrac quadtrac quadtrac quadtrac quadtrac quadtrac quadtrac quadtrac
Default Turbo Nytro oil vent issues?
I have a 2011 Nytro with the MPI rear mount turbo on it. Have ran into a few issues with the vent line that comes off the top of the oil tank freezing up. It has only done this after a day of riding deep powder and then starting it up the next morning when its been very cold. The last time it did this I could not find where it was pushing the oil out of.... Brought it in my shop to unthaw for a day, topped off the oil and ran it for a few minutes. Nothing shows any signs of a leak?! What would you recommend I did to avoid having this issue? Right now there is just a small breather/filter inside the end of that rubber hose. Thanks
Rate this post: Yes | No
  #2
Old 01-17-2018, 04:13 PM
1madbird's Avatar
1madbird 1madbird is offline
Currently: Pro engine build starting soon
1madbird has a reputation beyond repute1madbird has a reputation beyond repute1madbird has a reputation beyond repute1madbird has a reputation beyond repute1madbird has a reputation beyond repute1madbird has a reputation beyond repute1madbird has a reputation beyond repute1madbird has a reputation beyond repute1madbird has a reputation beyond repute1madbird has a reputation beyond repute1madbird has a reputation beyond repute
Default
If the oil line from the top of the oil tank has some sort of breather filter i would bet that this filter is absorbing water and then freezing. I have ran with my breather hose open going down below the tank and have never had it freeze up.
  #3
Old 01-17-2018, 07:02 PM
MTN_VIPER's Avatar
MTN_VIPER MTN_VIPER is online now
Currently: Making roll-over valve kits since 2008
MTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond repute
Default
Yeah it does sound like it is getting water logged and freezing like 1madbird suggested. Some boosted sleds just run an open hose on the end, while others will have a filter.
If you want to keep the filter, then I would route it up and to the driest place you can find under the hood. The idea is to prevent melting snow from getting it wet and allowing it to freeze.
Or you can just run without a filter and have the hose routed towards the belly pan. Don't allow the hose to lay in the belly pan though, otherwise it can ingest water.
__________________
Four Stroke Solutions LLC
Patented Roll-Over Valve Systems
ROV kits for M/XF7000/Viper, Sidewinder and King Cat with Quick-prime!
For Arctic Cat and Yamaha Sleds
Patents 8,225,766 8,528,516 9,303,537
http://fourstrokesolutionsllc.webs.com/
e-mail fourstrokesolutionsllc@hotmail.com
  #4
Old 01-17-2018, 11:57 PM
Default
Ok. So if I wanted to run with just the open hose routed near the belly pan, Is a roll over valve absolutely needed to prevent loosing a bunch of oil?
  #5
Old 01-18-2018, 12:10 AM
Default
Here is the little vent filter that was inside the end of that hose from the oil tank. Seems kinda small to me..
ID:	291608   Click image for larger version
  #6
Old 01-18-2018, 01:28 AM
cbouton cbouton is offline
Currently: Waiting for more snow
cbouton has a reputation beyond reputecbouton has a reputation beyond reputecbouton has a reputation beyond reputecbouton has a reputation beyond reputecbouton has a reputation beyond reputecbouton has a reputation beyond reputecbouton has a reputation beyond reputecbouton has a reputation beyond reputecbouton has a reputation beyond reputecbouton has a reputation beyond reputecbouton has a reputation beyond repute
Default
Mine has done that twice to me and it doesn't take long to lose all your oil I ended up cutting all the material out of the center of that filter. The hose that pops off is in the front/side middle of the oil tank. The pressure from the frozen filter pops the hose off but when you kill the motor the hose semi slips back on.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Turbo oil out vent Thread Starter — Maul Forum — Polaris: TURBO Replies — 7 Last Post — 11-14-2013 08:50 AM
Thread — M8 cutler turbo oil tank vent Thread Starter — Duraslut Forum — Arctic Cat: TURBO Replies — 10 Last Post — 10-15-2013 10:43 PM
Thread — nytro oil tank vent line Thread Starter — White Whale Forum — Yamaha: 4-Stroke Replies — 6 Last Post — 03-28-2011 05:05 PM
Thread — any issues putting a shock tower vent in front of the boondocker turbo intake? Thread Starter — TIM Forum — Polaris: TURBO Replies — 8 Last Post — 01-30-2010 09:10 AM
Thread — Nytro oil drain issues Thread Starter — ttabs Forum — Yamaha Replies — 40 Last Post — 12-23-2008 07:16 PM
no new posts
