Upgrade to Premium
Ski-Doo: TURBO Turbo discussion for Ski-Doo aftermarket turbo sleds
Reply
  #1
Old 01-07-2018, 11:40 PM
fredw fredw is offline
Currently: 850 blown up before Breakin over
Basic Member
fredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond repute
Default Adding timing to a turbo sled!! Good idea it bad
I am trying to find some better response with Impulse kit off the start at idle, once up in rpms, response is fine
Has anyone played with timing, seen that timing is at -.05 degrees, for the hell of it I tuned it up a degree and took it out in the low elevation test in the feild, sled felt much more responsive seat of the pants and even a different sound at idle, like a more rank sound..
Anyone else done this.. good or bad idea, I always run 100 percent av gas and 7-9kbs boost at 6-8000’
Thanks for the reply thanks
Rate this post: Yes | No
  #2
Old 01-08-2018, 07:21 AM
Turbo11T Turbo11T is offline
Currently: EVOLVING
Turbo11T has a reputation beyond reputeTurbo11T has a reputation beyond reputeTurbo11T has a reputation beyond reputeTurbo11T has a reputation beyond reputeTurbo11T has a reputation beyond reputeTurbo11T has a reputation beyond reputeTurbo11T has a reputation beyond reputeTurbo11T has a reputation beyond reputeTurbo11T has a reputation beyond reputeTurbo11T has a reputation beyond reputeTurbo11T has a reputation beyond repute
Default
Be nice to have a timing key like BD does. So we could turn the timing up at idle and then the key would pull it back as RPM increases.
  #3
Old 01-08-2018, 07:44 AM
Basic Member
Default
Talking with bj and Linderman last night both felt one degree increase should not be much a problem, as long as good fuel is being used.. Timing key would be real sweet
  #4
Old 01-08-2018, 09:53 AM
inspector01 inspector01 is offline
Currently: Not set.
inspector01 has a reputation beyond reputeinspector01 has a reputation beyond reputeinspector01 has a reputation beyond reputeinspector01 has a reputation beyond reputeinspector01 has a reputation beyond reputeinspector01 has a reputation beyond reputeinspector01 has a reputation beyond reputeinspector01 has a reputation beyond reputeinspector01 has a reputation beyond reputeinspector01 has a reputation beyond reputeinspector01 has a reputation beyond repute
Default
Proper way would be to adjust timing curves only where necessary, timing keys are a bandaid.
  #5
Old 01-08-2018, 02:12 PM
Currently: EVOLVING
Default
From my understanding the BD key pulls timing as RPM's increase. So little effect down low where we need more timing. So If we could add a couple degrees on the bottom and the key would pull 3 degrees back at 8000 rpm that would do the trick.
  #6
Old 01-09-2018, 11:16 AM
brycter's Avatar
brycter brycter is offline
Currently: Etec and axys mods all the time
brycter has a reputation beyond reputebrycter has a reputation beyond reputebrycter has a reputation beyond reputebrycter has a reputation beyond reputebrycter has a reputation beyond reputebrycter has a reputation beyond reputebrycter has a reputation beyond reputebrycter has a reputation beyond reputebrycter has a reputation beyond reputebrycter has a reputation beyond reputebrycter has a reputation beyond repute
Default
You have to remember timing effects the back pressure in the pipe. adding timing will make it flow a bit better. but will also increase you cylinder pressure. it is a tight wire walk. make sure you have good fuel. and might be good to test the rvp before playing too much with your timing
__________________
The Following User Says Thank You to brycter For This Useful Post:
Turbo11T (01-09-2018)
  #7
Old 01-09-2018, 11:33 PM
Basic Member
Default
Talking with another builder he seen some pretty decent gains advancing timing at lower rpm, said if a guy droped boost a few lbs and added some pump you will quickly see the same results.. Av gas is very safe, but burns very slow and could be the cause..
  #8
Old 01-09-2018, 11:40 PM
jackbombay jackbombay is offline
Currently: Not set.
Basic Member
jackbombay has a reputation beyond reputejackbombay has a reputation beyond reputejackbombay has a reputation beyond reputejackbombay has a reputation beyond reputejackbombay has a reputation beyond reputejackbombay has a reputation beyond reputejackbombay has a reputation beyond reputejackbombay has a reputation beyond reputejackbombay has a reputation beyond reputejackbombay has a reputation beyond reputejackbombay has a reputation beyond repute
Default
Quote:
Yep, the higher the octane the slower the flame front advances through the air/gas mixture.
  #9
Old 01-09-2018, 11:47 PM
Basic Member
Default
Reason I like using it over race gas is its avableabilty at the airport.. No barrels, jugs or mixing of race/pump..
Negative is with the impulse it pretty lazy from a dead stop till spool, and in trees it not very desirable, will try a degree or two of timing and see if it will be quicker for the lazy flame front av gas.. Maybe drop boost down a few lbs
  #10
Old 01-10-2018, 06:56 AM
Currently: EVOLVING
  #11
Old 01-10-2018, 07:55 AM
Basic Member
Click Here to Register
  #12
Old 01-10-2018, 08:53 AM
Currently: EVOLVING
  #13
Old 01-10-2018, 09:01 AM
Basic Member
  #14
Old 01-10-2018, 09:07 AM
Currently: EVOLVING
  #15
Old 01-10-2018, 09:17 AM
Basic Member
  #16
Old 01-10-2018, 09:44 AM
Currently: EVOLVING
  #17
Old 01-10-2018, 10:58 AM
Basic Member
  #18
Old 01-10-2018, 12:28 PM
Currently: EVOLVING
  #19
Old 01-11-2018, 11:39 PM
madmax's Avatar
madmax madmax is offline
Currently: Not set.
madmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond repute
  #20
Old 01-12-2018, 03:14 AM
Basic Member
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Thinking about a turboed phazer... Pros? cons? Good idea? Bad idea? Thread Starter — 600xc4me Forum — Yamaha: Boosted Sleds (Turbo or Supercharged) Replies — 10 Last Post — 01-07-2010 12:30 AM
Thread — Good or bad Idea Thread Starter — adrenaline junkey Forum — General Snowmobiling Replies — 24 Last Post — 12-04-2009 09:17 AM
Thread — m8 setup good idea or bad Thread Starter — M8CAT Forum — Arctic Cat Replies — 2 Last Post — 01-27-2009 03:31 PM
Thread — bikeman advanced timing key, good idea? Thread Starter — keeton Forum — Arctic Cat Replies — 6 Last Post — 10-10-2008 09:44 PM
Thread — Installing A Turbo On My 07 Dragon Good Or Bad Idea Thread Starter — dragon2007 Forum — Polaris Replies — 2 Last Post — 08-23-2008 09:06 PM
no new posts
