Upgrade to Premium
Reply
  #1
Old 12-04-2017, 04:07 PM
2013 M1100 Turbo 2013 M1100 Turbo is offline
Currently: Not set.
Basic Member
2013 M1100 Turbo has a reputation beyond repute2013 M1100 Turbo has a reputation beyond repute2013 M1100 Turbo has a reputation beyond repute2013 M1100 Turbo has a reputation beyond repute2013 M1100 Turbo has a reputation beyond repute2013 M1100 Turbo has a reputation beyond repute2013 M1100 Turbo has a reputation beyond repute2013 M1100 Turbo has a reputation beyond repute2013 M1100 Turbo has a reputation beyond repute2013 M1100 Turbo has a reputation beyond repute2013 M1100 Turbo has a reputation beyond repute
Default 17 King Cat Oil Change Surprise
Not sure if this is going to hold true on all of the King Cats, but I had to drill through my belly pan to access one of the foot well torx bolts. When removing the 2 torx bolts on the bottom of the footwell insert which needs needs to be removed, I had to drill through the belly pan with about a 7/16" drill bit to access the head of the outer most bolt to remove it. My previous M1100 did not need to have this done, but my new King Cat did.
Just wanted to give people a heads up.
Rate this post: Yes | No
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Oil Change/Filter Change on the Pro-Climb 1100T Thread Starter — Hilly Forum — Arctic Cat: 1100 ProClimb Replies — 3 Last Post — 01-18-2012 01:21 PM
Thread — '05-King cat drips oil daily? Thread Starter — slednutonkingcat Forum — Arctic Cat: 1M Replies — 8 Last Post — 01-21-2011 04:23 PM
Thread — Oil injection on a King Cat Thread Starter — chevota84 Forum — Arctic Cat: 1M Replies — 3 Last Post — 01-24-2009 06:06 PM
Thread — '06 King Cat Oil Adjustment - Need Help Thread Starter — Dobber1 Forum — Arctic Cat: 1M Replies — 3 Last Post — 01-17-2009 10:06 PM
Thread — Do you have to remove the belly pan to change A arms on a 05 King CAt Thread Starter — snowmanx Forum — Arctic Cat: M Series Replies — 1 Last Post — 04-09-2008 09:36 PM
no new posts
