Upgrade to Premium
Ski-Doo: REV Sleds 2004.5-200, all models in the REV chassis
Reply
  #1
Old 10-20-2017, 06:39 PM
sledjockey05 sledjockey05 is offline
Currently: Not set.
Basic Member
sledjockey05 is an unknown quantity at this point
Default 2005 800 summit drive clutch
So I am having issues pulling my drive be clutch off the motor. I have the tool installed and can put my 200 pounds on it while tapping around the edge and it won't even budge. Is this normal? This is the first time I have had to pull a clutch and I am not sure what is the problem. Any help would be appreciated.
Rate this post: Yes | No
  #2
Old 10-21-2017, 12:08 AM
slednfool slednfool is offline
Currently: Chasin snow
Basic Member
slednfool has a reputation beyond reputeslednfool has a reputation beyond reputeslednfool has a reputation beyond reputeslednfool has a reputation beyond reputeslednfool has a reputation beyond reputeslednfool has a reputation beyond reputeslednfool has a reputation beyond reputeslednfool has a reputation beyond reputeslednfool has a reputation beyond reputeslednfool has a reputation beyond reputeslednfool has a reputation beyond repute
Default
They can be stuck at times,I prefer the hydrologic method. Water down the hole, plumbers tape the threads, works every time!
  #3
Old 10-21-2017, 09:42 AM
Currently: Not set.
Basic Member
Default
Thanks for the idea. I'll give it a try.
  #4
Old 11-25-2017, 12:32 AM
Currently: Not set.
Basic Member
Default
So now i have a new issue, while still trying to get my clutch pulled off the crank shaft the tool sheared off and the clutch is still on the motor. Any ideas or should i scrap it and try to find a new lower end?
  #5
Old 11-25-2017, 07:59 AM
jdrmx jdrmx is offline
Currently: Not set.
jdrmx has a reputation beyond reputejdrmx has a reputation beyond reputejdrmx has a reputation beyond reputejdrmx has a reputation beyond reputejdrmx has a reputation beyond reputejdrmx has a reputation beyond reputejdrmx has a reputation beyond reputejdrmx has a reputation beyond reputejdrmx has a reputation beyond reputejdrmx has a reputation beyond reputejdrmx has a reputation beyond repute
Default
I had that happen once. But fortunatly, the engine sat in the cold overnight and when i brought it in the shop, "pop"! It came loose. I wonder if a map gas torch around the base of the clutch would expand it enough to release?
__________________
2014 Skidoo Summit X, TMS 872, V Force3 reeds
  #6
Old 11-26-2017, 02:55 PM
eddy's Avatar
eddy eddy is offline
Currently: El Nino is over!
eddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond repute
Default Stuck Primary
We had one do that - Stuck a light bulb on it overnight and in the morning it fell off!
  #7
Old 11-26-2017, 03:00 PM
Currently: Not set.
Basic Member
Default
i have a few heat bulbs so i will try that, thanks.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread — iso- 2005 ski doo summit 800 primary clutch Thread Starter — 14mkramer Forum — Clutch/Drive Train/Belt (Swapmeet) Replies — 0 Last Post — 12-09-2014 09:42 PM
Thread — need clutch info fo 2005 summit 1000 Thread Starter — aaron31777 Forum — Ski-Doo: REV Sleds Replies — 1 Last Post — 01-27-2011 01:56 AM
Thread — 2005 Summit 800 154 Clutch setup. WinterBrew? Thread Starter — bikerjustin Forum — Ski-Doo: REV Sleds Replies — 0 Last Post — 03-01-2010 11:30 PM
Thread — 2005 summit 800 ho primary tra 3 clutch Thread Starter — glhperformance Forum — Clutch/Drive Train/Belt (Swapmeet) Replies — 1 Last Post — 02-21-2010 05:52 PM
Thread — 2005 Summit Clutch Issues Thread Starter — Rjklinge0494 Forum — Ski-Doo: REV Sleds Replies — 1 Last Post — 01-13-2010 02:58 AM
no new posts
