Upgrade to Premium
Polaris: GEN 1 and older 1998 and older, all models in the Gen 1 Indy chassis and older chassis models
Reply
  #1
Old 10-18-2017, 10:26 PM
IndyEFI IndyEFI is offline
Currently: Not set.
Basic Member
IndyEFI is an unknown quantity at this point
Default 440 Cylinder
I have a 81 polaris 440 engine that needs a cylinder. It's a fan cooled engine. The needle bearing cage broke and stuck a needle bearing on the side of the piston and cylinder. My options are either do an over bore or get a new cylinder. They only list a .020" over piston for this engine. Does anyone know if a 650 piston would work? They go oversized up to .050" and have the same bore/stroke if not could you tell me what other years of cylinders would fit? It's a EC44-2PM-3100 engine.
Thanks.
ID:	286870   Click image for larger version
Rate this post: Yes | No
  #2
Old 10-22-2017, 07:20 AM
Merlin's Avatar
Merlin Merlin is offline
Currently: Where's the snow?
Merlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond repute
Default
Polaris's online parts catalog only goes back to '85 so you might want to contact a dealer and inquire about usage of the cylinders on other MY sleds.....
You could also contact Indy Specialties as Dan is a Polaris guru from way back & would likely know the piston options for that engine off the top of his head.....
Good luck!
  #3
Old 10-22-2017, 09:24 AM
volcano buster volcano buster is online now
Currently: Not set.
volcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond repute
Default
I wonder if you could use the cylinders, pistons and heads off a 488 that came in the later trail sleds. I see those for sale every so often.
  #4
Old 11-20-2017, 10:26 PM
XCRacer440 XCRacer440 is offline
Currently: In for a shitty winter again...
Basic Member
XCRacer440 has a reputation beyond reputeXCRacer440 has a reputation beyond reputeXCRacer440 has a reputation beyond reputeXCRacer440 has a reputation beyond reputeXCRacer440 has a reputation beyond reputeXCRacer440 has a reputation beyond reputeXCRacer440 has a reputation beyond reputeXCRacer440 has a reputation beyond reputeXCRacer440 has a reputation beyond reputeXCRacer440 has a reputation beyond reputeXCRacer440 has a reputation beyond repute
Default
Go on vintagesleds.com
They'll be able to get you some parts for it if you havent already found them.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — need a 88bm cylinder for a 2001 ZR 440 Thread Starter — scoop Forum — Engine/Engine Parts (Swapmeet) Replies — 0 Last Post — 02-26-2011 02:20 PM
Thread — 440 sno pro cylinder Thread Starter — cs1006 Forum — WTB (Swapmeet) Replies — 0 Last Post — 01-04-2009 09:28 PM
Thread — WANTED 99 ArticCat 440 SnowPro Cylinder Thread Starter — Boyko Forum — Engine/Engine Parts (Swapmeet) Replies — 1 Last Post — 12-30-2008 02:18 PM
Thread — WTB 97' ZR 440 cylinder and head! Thread Starter — bjenkins Forum — Engine/Engine Parts (Swapmeet) Replies — 0 Last Post — 11-08-2008 05:05 PM
Thread — wtb 440 prox cylinder Thread Starter — yoogebear Forum — Engine/Engine Parts (Swapmeet) Replies — 1 Last Post — 12-06-2007 10:58 PM
