Upgrade to Premium
Polaris: GEN 1 and older 1998 and older, all models in the Gen 1 Indy chassis and older chassis models
Reply
  #1
Old 10-10-2017, 08:47 PM
Polaris794 Polaris794 is offline
Currently: Not set.
Basic Member
Polaris794 is an unknown quantity at this point
Default Storm engine in CRC sled. Can it be done?
Hello all, I bought a 1995 storm for $600 and has 1700 miles on it. Great engine. But everything else is in rough shape. I thought it would be cool to put the engine in a 1998 rmk 600 wedge. I have this vision to get the hood painted white and have stock syle storm graphics custom made in red and blue. I think it would be a real head turner. Ok back to business. Has anyone done this swap successfully?
Rate this post: Yes | No
  #2
Old 10-11-2017, 12:20 AM
LoudHandle LoudHandle is offline
Currently: I'd rather snowshoe than be caught on a SKIDOO! I'm not feminine / gay enough to ride SkiDoo either.
LoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond repute
Default
I did it for a couple full mod hillclimb sleds, but you / we didn't have to run a hood in those days (Pipe Clearance). From memory, the only real difference is the twins Bulkhead Mag side motor mount has to be moved over to fit the triple. Used a crucifier (carbide cordless skill saw blade on a 4 1/2" grinder, use the guard, I have a nice scar and severed a few tendons doing it without a guard) to cut the welds and re-welded it over about 2" to fit the bulkhead to the Storm's engine straps.
__________________
ALASKA
The Following User Says Thank You to LoudHandle For This Useful Post:
Dev600 (02-10-2019)
  #3
Old 10-11-2017, 05:27 AM
Currently: Not set.
Basic Member
Default
Thanks for the info. Did you try putting the hood on? Or wouldnt it clear the pipes?
  #4
Old 10-11-2017, 08:47 AM
Default
Too old to remember. Guessing that it would fit.
__________________
ALASKA
  #5
Old 10-16-2017, 09:03 AM
sled_guy's Avatar
sled_guy sled_guy is offline
Currently: In limbo
sled_guy has a reputation beyond reputesled_guy has a reputation beyond reputesled_guy has a reputation beyond reputesled_guy has a reputation beyond reputesled_guy has a reputation beyond reputesled_guy has a reputation beyond reputesled_guy has a reputation beyond reputesled_guy has a reputation beyond reputesled_guy has a reputation beyond reputesled_guy has a reputation beyond reputesled_guy has a reputation beyond repute
Default
Hood fitment is the big issue. To get the motor in above the CRC you end up with the motor being higher in the chassis. That causes the wedge hoot to hit the spark plugs. I got around it by opening up the headlight area some. And the pipes fitting also causes some issues.
We did an XCR motor in to a 1999 Gen II RMK and that was worked well because the GenII hood sits higher.
sled_guy
__________________
"Sorry, I thought you could ride"
The Following User Says Thank You to sled_guy For This Useful Post:
Polaris794 (10-23-2017)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — WTB non-CRC Xtra 10 Front End Thread Starter — VTMTcowboy Forum — Suspension/Shocks (Swapmeet) Replies — 0 Last Post — 02-05-2010 12:54 PM
Thread — Wanted - used Polaris 800 Storm crank or complete engine Thread Starter — justpinit Forum — Engine/Engine Parts (Swapmeet) Replies — 3 Last Post — 02-19-2009 11:15 AM
Thread — IFS vs. CRC Thread Starter — CONN*RIDER Forum — Polaris Replies — 3 Last Post — 12-24-2008 04:40 PM
no new posts
