Upgrade to Premium
Polaris: EDGE 2002-2005, all models in the Edge chassis
Reply
  #1
Old 09-26-2017, 08:30 PM
polcat polcat is offline
Currently: Not set.
polcat is an unknown quantity at this point
Default wtb edge magneisum chaian case
looking for edge mag chain case
Rate this post: Yes | No
  #2
Old 09-27-2017, 10:40 AM
Mark's RMK's Avatar
Mark's RMK Mark's RMK is offline
Currently: Not set.
Mark's RMK has a reputation beyond reputeMark's RMK has a reputation beyond reputeMark's RMK has a reputation beyond reputeMark's RMK has a reputation beyond reputeMark's RMK has a reputation beyond reputeMark's RMK has a reputation beyond reputeMark's RMK has a reputation beyond reputeMark's RMK has a reputation beyond reputeMark's RMK has a reputation beyond reputeMark's RMK has a reputation beyond reputeMark's RMK has a reputation beyond repute
Default Chain Case
Get one from a Pro-X and upgrade your disc brake. The later models and RMK's came with it. I changed out all of my Edge to is with no issues.
__________________
2013 800 Pro RMK 155 ES, Burandt boards, Timbersled A-arms, NXT Level WS Bag, skid plate, VE belt guard, Team Tied Clutch, MTX wts, SLP Hot Air Eliminators, Mike Taylor Footwell Vents, Powder Keg tank/pack, Rox Flex Tec II Handguards.
Wife's Sled - 2012 Yamaha Apex XTX 144" EPS, Earth X battery, Yamaha Handguards, cable scratchers
2015 600 RMK 155, ES, skid plate, MTX wts
  #3
Old 09-30-2017, 02:01 PM
whoisthatguy's Avatar
whoisthatguy whoisthatguy is online now
Currently: Not set.
whoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond repute
Default
The 02 RMK has the dipstick and oil filler hole in the chain case cover, right next to the hot silencer. The 04 RMK chain case cover has no hole to fill with oil. The 04 dipstick and oil filler hole is located in the rear housing. Even if the Polaris 04 cover fit exactly on the 02, which is unlikely, you would have no easy way to fill the chain case with oil, unless you found something in the after market.
So if for some reason you were still driven to install a magnesium chain case cover, and could not afford and after market one, you would likely have to buy and install the entire chain case, with bearings.
If you were looking to just save weight instead of having a backup magnesium fire starter, start by removing the front suspension cross bar and tighten up the springs, replace with a lightweight silencer, drill a half dozen 1" diameter holes in the track to kick out snow, and spray a deicer in the inside of the tunnel. You could lose 40 lbs by doing all of that.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — WTB extended chain case for polaris edge/iqr Thread Starter — DragonSlayer1 Forum — WTB (Swapmeet) Replies — 2 Last Post — 03-27-2014 08:47 AM
Thread — WTB extended chain case for polaris edge Thread Starter — DragonSlayer1 Forum — WTB (Swapmeet) Replies — 0 Last Post — 03-24-2014 07:48 PM
Thread — Who knows how to take apart the choke lever case on an Edge? Thread Starter — dub Forum — Polaris Replies — 5 Last Post — 12-17-2008 06:24 PM
Thread — HOLZ rolled Chain Case in Edge Thread Starter — XC700116 Forum — Polaris Replies — 10 Last Post — 02-05-2008 11:43 PM
no new posts
