Upgrade to Premium
Ski-Doo: ZX Sleds 99-2005, all models in the ZX chassis
Reply
  #1
Old 09-14-2017, 08:01 PM
ZX Guy's Avatar
ZX Guy ZX Guy is offline
Currently: Not set.
ZX Guy has a reputation beyond reputeZX Guy has a reputation beyond reputeZX Guy has a reputation beyond reputeZX Guy has a reputation beyond reputeZX Guy has a reputation beyond reputeZX Guy has a reputation beyond reputeZX Guy has a reputation beyond reputeZX Guy has a reputation beyond reputeZX Guy has a reputation beyond reputeZX Guy has a reputation beyond reputeZX Guy has a reputation beyond repute
Default 01 800 summit
Ok guys.......got a 01 800 summit and oil is coming out of y pipe and stinger......... any thoughts
Rate this post: Yes | No
  #2
Old 09-15-2017, 10:37 AM
cubby's Avatar
cubby cubby is offline
Currently: Riding Atv's till the snow comes back
cubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond repute
Default
Could be a couple of things. First do a compression check on both the cylinders you should be above 125psi. Some times if the motor is started and shut off a bunch of times without letting it warm up to temp that kind of thing happens also.
__________________
2016 T3 154"
2007 XRS 800 151" engine built by SHR
2013 Polaris 850xp
2015 Polaris 1000xp
2016 Polaris 170 RZR
Hold it pinned till you feel bad
  #3
Old 09-18-2017, 12:33 PM
winter brew's Avatar
winter brew winter brew is offline
Currently: Not set.
winter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond repute
Default
If it sat all summer and this is the first start, that is normal for most sleds.
Get it up to temp, run and it will go away.
  #4
Old 09-27-2017, 06:42 PM
TreewellDweller's Avatar
TreewellDweller TreewellDweller is offline
Currently: Not set.
TreewellDweller has a reputation beyond reputeTreewellDweller has a reputation beyond reputeTreewellDweller has a reputation beyond reputeTreewellDweller has a reputation beyond reputeTreewellDweller has a reputation beyond reputeTreewellDweller has a reputation beyond reputeTreewellDweller has a reputation beyond reputeTreewellDweller has a reputation beyond reputeTreewellDweller has a reputation beyond reputeTreewellDweller has a reputation beyond reputeTreewellDweller has a reputation beyond repute
You might want to check the bolts that attach the y-pipe to the cylinders and the doughnut between the y-pipe and exhaust pipe. With the issues that were mentioned in the other replies this is where the oil/fuel will leak out and make a mess. Once it is warmed up and ridden it should burn most of this off but there will still be some residue.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread — 2005 Skidoo Summit 800 Adreleline, 2004 Skidoo Summit 800 Thread Starter — routbound Forum — Ski-Doo (Swapmeet) Replies — 1 Last Post — 09-16-2010 08:16 AM
Thread — 2008 Summit 800 X 154" & 2007 Summit 800 X 144" Thread Starter — chevelle Forum — Ski-Doo (Swapmeet) Replies — 1 Last Post — 04-19-2009 09:22 PM
Thread — 2003 Summit 800 / 1999 Summit 600 / Feather Light trailer Thread Starter — Calhoon Forum — Ski-Doo (Swapmeet) Replies — 8 Last Post — 10-31-2008 09:48 AM
no new posts
