Upgrade to Premium
Polaris: GEN 1 and older 1998 and older, all models in the Gen 1 Indy chassis and older chassis models
Reply
  #1
Old 03-28-2017, 08:44 PM
lshobie lshobie is offline
Currently: Not set.
lshobie has a reputation beyond reputelshobie has a reputation beyond reputelshobie has a reputation beyond reputelshobie has a reputation beyond reputelshobie has a reputation beyond reputelshobie has a reputation beyond reputelshobie has a reputation beyond reputelshobie has a reputation beyond reputelshobie has a reputation beyond reputelshobie has a reputation beyond reputelshobie has a reputation beyond repute
Default Polaris bogging sled fix series...DIY
Hey fellas Im just about done my bogging sled series - just about everything you have to do to find that bog short of selling your sled. Have a look if interested:
https://www.youtube.com/watch?v=ufCEy0heN9o
https://www.youtube.com/watch?v=DyHsOqpd-8Y
https://www.youtube.com/watch?v=J6dJOVWSHA4
https://www.youtube.com/watch?v=sP1MofGhBaM
https://www.youtube.com/watch?v=5WI5QJzjsXw
https://www.youtube.com/watch?v=eqx7SIIED-U
Rate this post: Yes | No
The Following User Says Thank You to lshobie For This Useful Post:
Merlin (03-29-2017)
  #2
Old 03-31-2017, 08:29 AM
Merlin's Avatar
Merlin Merlin is offline
Currently: Where's the snow?
Merlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond repute
Default
Well done on the videos! They'll help alot of DIY type people to see what can be done with the right mindset.
FWIW, I may have missed it in the videos but have you confirmed what the carbs have in them for main & pilot jets? We have an Indy Lite that had relatively poor bottom end performance that has responded well to a drop in pilot jets (35 to 30) & main jets(145 to 120). IMO, The jetting charts on those machines are ultra conservative. However you still need to use your head when making changes - I.E. read the spark plugs.
Confirming ignition timing would be a good idea as well. Speaking with a very knowledgeable forum member there's likely room to run more advanced timing on these engines as they run a very loose head / squish .125" +! Once again, you need to be careful and watch the plugs when making changes.
Lastly, confirm clutching set up / condition. If the primary spring is weak / too light or the weights are way too heavy it could be placing too much load on the engine at starting ratios. An improperly tensioned secondary spring could also have the same affect.
Just a few things to consider.
Good luck!
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — DIY Sled Deck Kit? Thread Starter — egesledder Forum — Trucks and Trailers Replies — 8 Last Post — 11-04-2012 09:34 PM
Thread — Cat clutch FIX cheap easy DIY Thread Starter — midwestmountain1 Forum — Arctic Cat: M Series Replies — 15 Last Post — 02-11-2012 04:36 PM
Thread — DIY M Series Tunnel Update Endcap Thread Starter — Schism Forum — Chassis/Tunnel (Swapmeet) Replies — 3 Last Post — 02-01-2012 12:50 PM
Thread — DIY Sled Seat or Cover Re-color Thread Starter — snowcougar Forum — Misc. Sled Parts (product reviews) Replies — 1 Last Post — 05-10-2011 07:56 PM
Thread — what to do polaris cant fix my sled Thread Starter — 440dart Forum — Polaris: IQ Replies — 20 Last Post — 03-10-2010 07:08 PM
no new posts
