Upgrade to Premium
Arctic Cat: TURBO Turbo discussion for Arctic Cat aftermarket turbo sleds
Reply
  #1
Old 01-31-2016, 01:42 PM
Sledneck_1987 Sledneck_1987 is online now
Currently: Not set.
Sledneck_1987 has a reputation beyond reputeSledneck_1987 has a reputation beyond reputeSledneck_1987 has a reputation beyond reputeSledneck_1987 has a reputation beyond reputeSledneck_1987 has a reputation beyond reputeSledneck_1987 has a reputation beyond reputeSledneck_1987 has a reputation beyond reputeSledneck_1987 has a reputation beyond reputeSledneck_1987 has a reputation beyond reputeSledneck_1987 has a reputation beyond reputeSledneck_1987 has a reputation beyond repute
Default 2016 m8000 supercharger
any one out their have a speedwerx super on a 2016 m8000?
any thought and recommendations ?
Rate this post: Yes | No
  #2
Old 02-09-2016, 08:03 PM
ranger12's Avatar
ranger12 ranger12 is offline
Currently: Wishing I was riding some place
ranger12 has a reputation beyond reputeranger12 has a reputation beyond reputeranger12 has a reputation beyond reputeranger12 has a reputation beyond reputeranger12 has a reputation beyond reputeranger12 has a reputation beyond reputeranger12 has a reputation beyond reputeranger12 has a reputation beyond reputeranger12 has a reputation beyond reputeranger12 has a reputation beyond reputeranger12 has a reputation beyond repute
Default
I have a 2016 M8000 with a Speedwerx supercharger. This sled is the funnest sled I have ever ridden! The bottom end power and response is unbelievable and I have owned almost every Big Bore motor combination out there and have had a few turboed sleds. If I had to pick one sled out of all the sleds that I have had or ridden I would pick the supercharged sled!
I am tweaking on the perfect belt drive ratio and clutching for it yet. I think most of the sleds that Speedwerx puts together have 153" tracks. I think the clutching that they recommend would be pretty close to spot on if it was a 153. This one is a 162. The 162 just loads the motor different and is taking a few minor changes to get it right for the way I ride.
2 out of 2 members found this post helpful. Rate this post: Yes | No
  #3
Old 02-10-2016, 06:09 PM
akMcat's Avatar
akMcat akMcat is offline
Currently: Horsepower shopping
akMcat has a reputation beyond reputeakMcat has a reputation beyond reputeakMcat has a reputation beyond reputeakMcat has a reputation beyond reputeakMcat has a reputation beyond reputeakMcat has a reputation beyond reputeakMcat has a reputation beyond reputeakMcat has a reputation beyond reputeakMcat has a reputation beyond reputeakMcat has a reputation beyond reputeakMcat has a reputation beyond repute
Default
How's the fit and finish of the kit. Is the tuning from speedwerx good, have you had to change it? Are you running the same tuning that the send out to the everyday consumer or a custom tune. What head are you running. Boost, fuel, elevation?
  #4
Old 02-11-2016, 12:19 AM
ranger12's Avatar
Default
The fit and finish is above what I expected. The sled ran pretty darn good when I got it, but Speedwerx sent me a different map for it shortly after I got it. I think Cat made some changes in the ECM for the 16 sleds and they adjusted their map for that. I have the POD 300 with Auto Tune on this sled which the Auto Tune is turned "off" and I am only using the AFR readings from it. My AFR readings are pretty much spot on. I have logged some time on the POD 300 and replayed them on the Dynojet PowerCore software and everything is right where it is supposed to be. I have looked at my piston wash and that is telling me that I could lean it out. Not 100% sure if you read piston wash the same on a supercharged sled as you would a BB motor or not though. I am still old school and like EGT's better than an AFR gauge also. So I am not 100% totally confident in changing the map when it is running as good as it is and don't think it is necessary. I have used the PCV on a lot of sleds and am very comfortable using it and making my own maps, but now with the SC sled you are using it to its full extent and have pressure tables and other various configurations that are in play. This sled has the lower compression head and the 40/80 pulleys on it which is the pump gas version. When I play my passes back on the Power Core software it will run pretty consistently about 8-8.5 psi. I have been doing the majority of my riding so far from 9600' to just under 11000'. I have it clutched so it will consistently pull 8250 rpm in that elevation range.
This is the simplest most powerful sled I have ever had. Pull up to the pump and fill it up with premium and add oil to the oil tank and go have fun.
I sure don't miss those days of mixing race fuel, gas and oil or making sure I had enough AV fuel to last me for how long I was going to be up on the mountain and transporting it for hundreds of miles.
3 out of 3 members found this post helpful. Rate this post: Yes | No
The Following 4 Users Say Thank You to ranger12 For This Useful Post:
akMcat (02-11-2016), BBP (02-14-2016), Nextime (02-29-2016), thornecat (03-16-2016)
  #5
Old 02-11-2016, 11:26 AM
akMcat's Avatar
Default
Thanks so much for the response, this is the kind of info I've been looking for, there's just not too many of these supercharger setups around that you hear about. I know of 1 guy locally that just put one on his '16 about a month ago, but havent really heard how he likes it yet. I'm thinking of putting one on for next year, I just bought a '16 153 limited with a speedwerx stg 2 and BM fab skinny board. I've still got my turbo '12 but I'm ready to try something different. Thanks again for the info.
  #6
Old 03-16-2016, 07:11 PM
ranger12's Avatar
Default
I have some days off coming up and I will be heading some place where there is decent snow. Not sure where I will be heading yet, but if anybody would like to take my sled for a ride and see what these sleds will do I would be more than happy to let you ride it. I was in Cooke last weekend and it got a lot of attention.
  #7
Old 03-20-2016, 07:53 PM
Snowedunder's Avatar
Snowedunder Snowedunder is offline
Currently: Waiting for my 850 poo
Snowedunder has a reputation beyond reputeSnowedunder has a reputation beyond reputeSnowedunder has a reputation beyond reputeSnowedunder has a reputation beyond reputeSnowedunder has a reputation beyond reputeSnowedunder has a reputation beyond reputeSnowedunder has a reputation beyond reputeSnowedunder has a reputation beyond reputeSnowedunder has a reputation beyond reputeSnowedunder has a reputation beyond reputeSnowedunder has a reputation beyond repute
Default Clutching
Where you at with clutching, waights, helix ?
  #8
Old 03-21-2016, 09:26 PM
Texasnowman Texasnowman is offline
Currently: work in Texas-Play in Colorado
Texasnowman has a reputation beyond reputeTexasnowman has a reputation beyond reputeTexasnowman has a reputation beyond reputeTexasnowman has a reputation beyond reputeTexasnowman has a reputation beyond reputeTexasnowman has a reputation beyond reputeTexasnowman has a reputation beyond reputeTexasnowman has a reputation beyond reputeTexasnowman has a reputation beyond reputeTexasnowman has a reputation beyond reputeTexasnowman has a reputation beyond repute
Default
Did you do the install yourself or have it installed?? If so how bad was it to install??
  #9
Old 03-26-2016, 11:15 AM
ranger12's Avatar
Default
The sled was bought from Speedwerx as one of their packages. So they did the install of the supercharger. It does not look like it would be real difficult to install if you have installed a turbo before. In my opinion I think it would be easier to install than a turbo.
I have played around a lot with the clutching and gearing.
Gearing: I have tried a 25, 26, 27 and 28 tooth top sprocket for the TKI belt drive and I have definitely settled on the 28 tooth top gear for the belt drive. I do know of one guy that is running a 153" and he is running a 30 tooth top sprocket and he "really" likes it. From what I have heard from most of the other guys they are running a 27 tooth top sprocket.
Secondary: Speedwerx recommends the stock 48 degree helix and the stock Cat secondary spring or a secondary spring that is a little lighter. In my mind I didn't think that this would be a very good combination so I ordered a spring and some different helixes. The spring that I settled on is a 190/260. The stock spring is a 180/240. I tried a 43, 44, 46, 46/42 and the 48 degree helixes. To keep this short I am running the 48 degree helix in my sled. On certain days depending on the snow conditions and where I am riding I might switch to a different helix.
Primary: Speedwerx recommends the stock primary spring 85/255. I am running a 120/280 primary spring with as many as 3 Glide washers. With the stock primary spring the engagement is low and very smooth. I am running 72 gram clutch weight and my rpms are 8350. I am going to add another gram of weight and bring the rpms down a little bit. The recommended rpm range for this sled is 8100-8300. Speedwerx recommends 74.5 gram weights with their setup. I think most of the other guys are running 72.5 gram weights.
Almost all of my riding is 9000 foot and above. I have played with the boost by changing out the top pulley to a smaller one and the results above 9000 foot are pretty impressive. If I ride below 9000 foot I put the stock pulley for the supercharger on it and don't change any of the clutching. If I am riding above 9000 foot I change the top pulley to the smaller one and install the correct map for it, that all. You could leave it alone and just run the larger pulley for the supercharger all the time and you wont be disappointed in the performance up to about 11000 foot also.
The Following User Says Thank You to ranger12 For This Useful Post:
Snowedunder (03-26-2016)
  #10
Old 03-27-2016, 08:48 AM
ranger12's Avatar
  #11
Old 03-27-2016, 12:22 PM
akMcat's Avatar
Click Here to Register
  #12
Old 03-27-2016, 01:42 PM
ranger12's Avatar
  #13
Old 03-27-2016, 04:49 PM
akMcat's Avatar
  #14
Old 04-01-2016, 05:26 PM
ranger12's Avatar
  #15
Old 04-20-2016, 09:34 PM
ranger12's Avatar
  #16
Old 04-27-2016, 09:54 AM
Iceman56's Avatar
Iceman56 Iceman56 is offline
Currently: Not set.
Iceman56 has a reputation beyond reputeIceman56 has a reputation beyond reputeIceman56 has a reputation beyond reputeIceman56 has a reputation beyond reputeIceman56 has a reputation beyond reputeIceman56 has a reputation beyond reputeIceman56 has a reputation beyond reputeIceman56 has a reputation beyond reputeIceman56 has a reputation beyond reputeIceman56 has a reputation beyond reputeIceman56 has a reputation beyond repute
  #17
Old 12-13-2016, 08:59 PM
ranger12's Avatar
  #18
Old 01-13-2017, 09:31 AM
Tyamama Tyamama is offline
Currently: Living the dream
Basic Member
Tyamama has a reputation beyond reputeTyamama has a reputation beyond reputeTyamama has a reputation beyond reputeTyamama has a reputation beyond reputeTyamama has a reputation beyond reputeTyamama has a reputation beyond reputeTyamama has a reputation beyond reputeTyamama has a reputation beyond reputeTyamama has a reputation beyond reputeTyamama has a reputation beyond reputeTyamama has a reputation beyond repute
  #19
Old 01-24-2017, 10:17 PM
ranger12's Avatar
Tyamama (01-27-2017)
  #20
Old 01-30-2017, 07:52 PM
TheJett29 TheJett29 is offline
Currently: Winning
TheJett29 has a reputation beyond reputeTheJett29 has a reputation beyond reputeTheJett29 has a reputation beyond reputeTheJett29 has a reputation beyond reputeTheJett29 has a reputation beyond reputeTheJett29 has a reputation beyond reputeTheJett29 has a reputation beyond reputeTheJett29 has a reputation beyond reputeTheJett29 has a reputation beyond reputeTheJett29 has a reputation beyond reputeTheJett29 has a reputation beyond repute
  #21
Old 03-01-2017, 03:00 PM
Basic Member
  #22
Old 03-06-2017, 10:18 PM
roni87's Avatar
roni87 roni87 is offline
Currently: Not set.
roni87 has a reputation beyond reputeroni87 has a reputation beyond reputeroni87 has a reputation beyond reputeroni87 has a reputation beyond reputeroni87 has a reputation beyond reputeroni87 has a reputation beyond reputeroni87 has a reputation beyond reputeroni87 has a reputation beyond reputeroni87 has a reputation beyond reputeroni87 has a reputation beyond reputeroni87 has a reputation beyond repute
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 2016 M8000 Seat on a 2014 M8000 Thread Starter — M8 Rider Forum — Arctic Cat: Proclimb M Replies — 3 Last Post — 01-30-2016 07:02 PM
Thread — 2015 vs 2016 M8000 Thread Starter — WYOAC700 Forum — Arctic Cat: Proclimb M Replies — 12 Last Post — 12-26-2015 09:42 AM
Thread — Speedwerx Supercharger Kit Cat M8000 12-15 Thread Starter — EDP Forum — Turbos/Superchargers (Swapmeet) Replies — 1 Last Post — 10-29-2015 11:10 AM
Thread — 2016 M8000 Ltd Thread Starter — DakCat Forum — Arctic Cat (Swapmeet) Replies — 4 Last Post — 10-27-2015 11:36 AM
Thread — What are your setups on 2016 M8000 Ltd? Thread Starter — Kobane Forum — Arctic Cat: Proclimb M Replies — 0 Last Post — 10-16-2015 06:15 PM
no new posts
