Upgrade to Premium
Polaris: GEN 1 and older 1998 and older, all models in the Gen 1 Indy chassis and older chassis models
Reply
  #1
Old 12-25-2016, 02:49 PM
Merlin's Avatar
Merlin Merlin is offline
Currently: Where's the snow?
Merlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond repute
Default Gearing Options?
Hello & Merry Xmas,
I'm currently running the stock, 2.44:1(16/39), gearing in our long tracked(136" X 1.75") Indy Lite.
Being my son(9yrs / 100lbs) is riding this machine in the mountains, it is no surprise that we are finding the "big" track puts a pretty good load on the lil' 340.
According to the service manual 2.56:1(16/41) is lowest recommended combo for the 6.625" chain case. That said, the service manual lists P/Ns for 13, 14, & 15 tooth top sprockets.
Anyone have any experience running lower gearing combos such as 15/41, 14/41, 13/41?
IMO, being geared for anything over 45MPH in this application is too much.
Thoughts?
TIA
Glen
Rate this post: Yes | No
  #2
Old 12-28-2016, 01:18 PM
volcano buster volcano buster is online now
Currently: Not set.
volcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond repute
Default
Have you added more tension on the secondary clutch spring to keep it effectively in a lower gear (higher rpm's)?
  #3
Old 12-28-2016, 03:58 PM
Merlin's Avatar
Default
VB, I've been running it on the factory recommended setting(B2).
This year I rebuilt the primary & installed the Gold spring with Thunder Products Glide Washers & 10M Blue weights(47.5g). The factory calibrations were the Gold/Silver spring & 10 weights(51.5g). I also replaced the ramp buttons in the secondary with the newer 5450873 buttons that have a different profile which will add to the initial spring preload.
I'm going to test this set-up to see how it works. If not satisfactory, I plan on cranking up the secondary spring to B1 or even B0 before dropping the weights to the 10M White(46g).
That said, I think that even if I can get the machine to run good with clutch tuning, it'd even do that much better with lower gearing. A good example of that is the proven lower re-gearing of the Pro chassis that TRS and many others have advocated.
FWIW
Quote:
Name:	Factory Clutching.PNG
ID:	277951   Click image for larger version
Name:	Clutching Recommendations.PNG
ID:	277952   Click image for larger version
Name:	Rebuilt Clutches.jpg
Name:	Ramp Button Comparison.jpg
  #4
Old 12-31-2016, 07:30 PM
cowboy181d cowboy181d is offline
Currently: BOOSTED 2 STROKES RUINED ME
cowboy181d has a reputation beyond reputecowboy181d has a reputation beyond reputecowboy181d has a reputation beyond reputecowboy181d has a reputation beyond reputecowboy181d has a reputation beyond reputecowboy181d has a reputation beyond reputecowboy181d has a reputation beyond reputecowboy181d has a reputation beyond reputecowboy181d has a reputation beyond reputecowboy181d has a reputation beyond reputecowboy181d has a reputation beyond repute
Default
I am running the 15/41 combo in my 79 txl 340 long track (133) seems to pull it around great top speed is about 40mph with untouched clutching. I cannot remember the chain I ended up running I know it was a bit funky to get together though.... funny i seen this on here today as I am getting ready to go out and dig my old txl out of its 6 year slumber for my daughter to ride this season!
The Following User Says Thank You to cowboy181d For This Useful Post:
Merlin (12-31-2016)
  #5
Old 12-31-2016, 11:38 PM
Merlin's Avatar
Default
Thanks for the info.!
Do you recall what size drivers you are running?
  #6
Old 01-02-2017, 10:46 PM
Default
7 tooth I think..... I will have it in the shop this week I will roll it over and see....
Merlin (01-03-2017)
  #7
Old 01-03-2017, 09:19 AM
Merlin's Avatar
Default
Thanks!
I'm running 7 tooth drivers & found them to be a significant improvement over the factory 9 tooth.
After looking a little closer at the gearing chart, I could swap out my 16T top sprocket with a 14T & be at 2.79:1 which is pretty much the same as you're running. The bonus would be keeping my factory bottom sprocket(39T) & chain(64P).
Name:	Jackshaft Speed vs MPH Chart.jpg
  #8
Old 01-05-2017, 11:02 AM
retiredpop retiredpop is offline
Currently: Not set
retiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond repute
Default
Don't forget the effective increase in ratio because of the smaller track sprockets when you are figuring your gearing out. Reducing from 9T sprockets to 7T sprockets gives the same effect as changing the gear ratio from 2.44 to 3.13 because of the smaller diameter. Keep that in mind when you go even lower on the top gear. 15T top gear would be 3.34 with the 7T sprockets. 14T top gear would be 3.58. You do need to maintain a reasonable amount of track speed in the mountains.
__________________
The older I get the better I was. In fact now that I think about it I'm a legend!
Haven't outgrown my 600 yet!
2 out of 2 members found this post helpful. Rate this post: Yes | No
The Following User Says Thank You to retiredpop For This Useful Post:
Merlin (01-06-2017)
  #9
Old 01-05-2017, 12:04 PM
Merlin's Avatar
Default
Thanks,
I think I have taken the effect of the smaller drivers into account.
With stock gearing & factory 9 tooth drivers theoretical top end is 60 MPH +/- at 7000 RPM according to the chart in the service manual.
Top end drops to 47 MPH +/- with the 7 tooth drivers.
If I go with the 14 tooth top gear to end should drop to 40 MPH +/-.
40 MPH top end is pretty darn slow but I think it's asking a lot of 35 - 38 HP engine to pull a 136" X 1.75" track through deep snow with anything even close to that for track speeds. I'm thinking it's better to be geared for the power & traction I've got to work with.
Thoughts?
  #10
Old 01-06-2017, 08:28 AM
Currently: Not set.
The Following User Says Thank You to volcano buster For This Useful Post:
Merlin (01-06-2017)
  #11
Old 01-06-2017, 11:30 AM
Merlin's Avatar
Click Here to Register
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Quick Drive Gearing Options Thread Starter — xmk1080 Forum — Polaris: AXYS Replies — 25 Last Post — 12-19-2016 09:30 PM
Thread — 16' Clutching and Gearing Options Thread Starter — j.janke Forum — Arctic Cat: Proclimb M Replies — 13 Last Post — 04-14-2016 03:56 PM
Thread — Gearing options Thread Starter — wreckmaster Forum — Ski-Doo: REV Sleds Replies — 7 Last Post — 11-16-2012 07:07 AM
Thread — wanted: clutch and gearing options. Thread Starter — olymon Forum — Polaris: GEN 1 and older Replies — 0 Last Post — 10-06-2009 11:30 AM
Thread — I need Gearing options, please help ! Thread Starter — IQR Forum — Polaris Replies — 3 Last Post — 08-03-2009 02:59 PM
