Upgrade to Premium
Ski-Doo: S-2000 and older 1998 and older, all models in the S-2000 chassis and older chassis models
Reply
  #1
Old 12-10-2016, 09:45 PM
MSP381 MSP381 is offline
Currently: Not set.
Basic Member
MSP381 is an unknown quantity at this point
Default 99 summit x 670 idle problems help
I purchased a 99x with 2800 miles and when I loaded it in it ran great other than when hitting throttle it dies but not stall completely. Seemed like the dess was loose. Once I jiggled it it seemed to run great. Sat for a month and tried running today in fresh powder.
Started today no issues when it started and when I went to take off same thing...wants to bog down. Tried adjusting key and no luck. Seems to run at high idle. It also seems like it wants to run good at maybe half throttle.
I'm new to doo and the dess key. Any ideas?
Also noticed the plug going into airbox was unplugged. Did not notice it when I bought it. What's it for...dpm??
What adjustments are made when running at seal level?
Rate this post: Yes | No
  #2
Old 12-10-2016, 10:21 PM
Skidoox's Avatar
Skidoox Skidoox is online now
Currently: Not set.
Skidoox has a reputation beyond reputeSkidoox has a reputation beyond reputeSkidoox has a reputation beyond reputeSkidoox has a reputation beyond reputeSkidoox has a reputation beyond reputeSkidoox has a reputation beyond reputeSkidoox has a reputation beyond reputeSkidoox has a reputation beyond reputeSkidoox has a reputation beyond reputeSkidoox has a reputation beyond reputeSkidoox has a reputation beyond repute
Default
I would bet your computer is bad.
We had to replace 3 of them on 3 different 99 summits.
  #3
Old 12-11-2016, 08:33 AM
Currently: Not set.
Basic Member
Default
Any other ideas and how would I check to see if it's the computer
  #4
Old 12-11-2016, 12:24 PM
Currently: Not set.
Basic Member
Default
What is this plug for. Supposed to be plugged in? Still waiting for some feedback
  #5
Old 12-11-2016, 02:01 PM
Currently: Not set.
Basic Member
Default
It runs fine above 4K rpm and when letting off throttle wants to die flat below 4K. Also seems to idle at 3000. Initial start up idles fine until I start to crack throttle.
Any help??!
  #6
Old 12-11-2016, 10:06 PM
nuttyn01 nuttyn01 is online now
Currently: Not set.
nuttyn01 has a reputation beyond reputenuttyn01 has a reputation beyond reputenuttyn01 has a reputation beyond reputenuttyn01 has a reputation beyond reputenuttyn01 has a reputation beyond reputenuttyn01 has a reputation beyond reputenuttyn01 has a reputation beyond reputenuttyn01 has a reputation beyond reputenuttyn01 has a reputation beyond reputenuttyn01 has a reputation beyond reputenuttyn01 has a reputation beyond repute
Default
That sensor is the air box air temp sensor and yes it needs to be plugged in. The plug for it is laying above your DPM manifold in the picture.
  #7
Old 12-12-2016, 07:45 AM
Currently: Not set.
Basic Member
Default
It's plugged in but still runs the same. Any other thoughts?? Come on guys I know there is some thoughts from the field..
  #8
Old 12-12-2016, 10:36 AM
Skidoox's Avatar
Currently: Not set.
Default
You need to find another 99 that you can swap the computer with to see if it is the problem.
  #9
Old 12-12-2016, 11:15 AM
olymon's Avatar
olymon olymon is offline
Currently: project parts searching
olymon has a reputation beyond reputeolymon has a reputation beyond reputeolymon has a reputation beyond reputeolymon has a reputation beyond reputeolymon has a reputation beyond reputeolymon has a reputation beyond reputeolymon has a reputation beyond reputeolymon has a reputation beyond reputeolymon has a reputation beyond reputeolymon has a reputation beyond reputeolymon has a reputation beyond repute
Default
You mentioned sea level. Was this set up for the mountains and now you are using it at sea level? Have you put in sea level jetting and clutching? Sounds like a pilot jet that is too small with a 3000 rpm idle.
Making JIS screws into junk
  #10
Old 12-12-2016, 02:36 PM
Currently: Not set.
Basic Member
  #11
Old 12-12-2016, 05:22 PM
Currently: Not set.
Basic Member
Click Here to Register
  #12
Old 12-13-2016, 12:09 PM
summit800 summit800 is offline
Currently: premium member
summit800 has a reputation beyond reputesummit800 has a reputation beyond reputesummit800 has a reputation beyond reputesummit800 has a reputation beyond reputesummit800 has a reputation beyond reputesummit800 has a reputation beyond reputesummit800 has a reputation beyond reputesummit800 has a reputation beyond reputesummit800 has a reputation beyond reputesummit800 has a reputation beyond reputesummit800 has a reputation beyond repute
  #13
Old 12-13-2016, 12:56 PM
eddy's Avatar
eddy eddy is offline
Currently: Dirt Bike Season!
eddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond repute
  #14
Old 12-13-2016, 04:29 PM
Currently: Not set.
Basic Member
  #15
Old 12-13-2016, 04:31 PM
Currently: Not set.
Basic Member
  #16
Old 12-13-2016, 06:27 PM
  #17
Old 12-14-2016, 07:38 AM
  #18
Old 12-14-2016, 07:40 AM
  #19
Old 12-14-2016, 09:23 AM
Currently: Not set.
Basic Member
  #20
Old 12-14-2016, 03:58 PM
eddy's Avatar
  #21
Old 12-14-2016, 05:32 PM
  #22
Old 12-17-2016, 12:51 PM
Currently: Not set.
Basic Member
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread — 98' Summit 670 Problems Thread Starter — Boulderbronco Forum — Ski-Doo: S-2000 and older Replies — 4 Last Post — 12-11-2015 03:01 PM
Thread — 1999 Summit X 670 air/ fuel problems Thread Starter — wags19 Forum — Ski-Doo: S-2000 and older Replies — 0 Last Post — 01-02-2013 11:05 PM
Thread — Idle Problems Thread Starter — Corndiddly Forum — Ski-Doo: REV Sleds Replies — 2 Last Post — 01-28-2011 04:14 PM
Thread — Idle Problems Thread Starter — cowill2 Forum — Polaris: IQ Replies — 3 Last Post — 03-12-2010 09:59 AM
Thread — 670 idle issues Thread Starter — prairieguy Forum — Ski-Doo: S-2000 and older Replies — 0 Last Post — 12-29-2009 09:48 PM
no new posts
