Upgrade to Premium
Polaris: GEN 2 1999-2001, all models in the Gen 2 chassis
Reply
  #1
Old 08-29-2016, 07:19 AM
Bcorn Bcorn is offline
Currently: currently just working
Bcorn has a reputation beyond reputeBcorn has a reputation beyond reputeBcorn has a reputation beyond reputeBcorn has a reputation beyond reputeBcorn has a reputation beyond reputeBcorn has a reputation beyond reputeBcorn has a reputation beyond reputeBcorn has a reputation beyond reputeBcorn has a reputation beyond reputeBcorn has a reputation beyond reputeBcorn has a reputation beyond repute
Default 01 700 rmk lights issue
2001 700 rmk sled runs fine but headlight and tail light flicker on and off and run really dim at times any suggestions.
Rate this post: Yes | No
  #2
Old 09-04-2016, 09:15 PM
retiredpop retiredpop is offline
Currently: Not set
retiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond repute
Default
You probably have an intermittent short to ground on the lighting circuit somewhere. Check the wiring under the seat for frayed wiring. The reason why I am not pointing at the regulator is because if it goes bad you get the opposite where the lights go really bright and then the bulbs burn out. The ignition is a separate wiring circuit from the lighting circuit so that is why it runs good.
__________________
The older I get the better I was. In fact now that I think about it I'm a legend!
Haven't outgrown my 600 yet!
The Following User Says Thank You to retiredpop For This Useful Post:
Bcorn (09-05-2016)
  #3
Old 12-09-2016, 11:01 AM
Default
Turned out to be the voltage regulator,checked wires ,replaced light switch.I did go through a couple light bulbs before they pretty much quit working totally.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 06 700 RMK Fuel Issue Thread Starter — Karlburns Forum — Polaris: 900 Replies — 19 Last Post — 10-01-2015 11:22 PM
Thread — Help. Lights and hand warmer issue Thread Starter — upfront719 Forum — Snow bikes Replies — 10 Last Post — 11-07-2013 06:01 PM
Thread — 99 RMK 700 Smoking Issue Thread Starter — Ufishifish2 Forum — Polaris: GEN 2 Replies — 3 Last Post — 01-03-2013 06:54 PM
Thread — 08 700 RMK Electrical Issue Thread Starter — crankshaft Forum — Polaris: IQ Replies — 11 Last Post — 01-03-2010 09:25 PM
Thread — 2002 RMK 700 lights don't work... Thread Starter — Brecksleder Forum — Polaris Replies — 6 Last Post — 12-11-2007 07:03 PM
