Upgrade to Premium
Yamaha: 2-stroke Includes all Yamaha 2-strokes, Viper, Mountain Max, etc
Reply
  #1
Old 01-04-2015, 06:12 PM
Turblue's Avatar
Turblue Turblue is offline
Currently: Sledding soon
Turblue has a reputation beyond reputeTurblue has a reputation beyond reputeTurblue has a reputation beyond reputeTurblue has a reputation beyond reputeTurblue has a reputation beyond reputeTurblue has a reputation beyond reputeTurblue has a reputation beyond reputeTurblue has a reputation beyond reputeTurblue has a reputation beyond reputeTurblue has a reputation beyond reputeTurblue has a reputation beyond repute
Default 1993 phazer St
Looking for clutching charts...also any good plastic skis that fit this sled? Any links to service manuals?
Rate this post: Yes | No
  #2
Old 01-11-2015, 01:36 AM
snowordeath snowordeath is offline
Currently: So, you've tried it and it can't be done? Well, let's give it a try!
Basic Member
snowordeath has a reputation beyond reputesnowordeath has a reputation beyond reputesnowordeath has a reputation beyond reputesnowordeath has a reputation beyond reputesnowordeath has a reputation beyond reputesnowordeath has a reputation beyond reputesnowordeath has a reputation beyond reputesnowordeath has a reputation beyond reputesnowordeath has a reputation beyond reputesnowordeath has a reputation beyond reputesnowordeath has a reputation beyond repute
Default
I hat one that I put the plastic skis off of a '98 Polaris RMK on and they worked well. If I remem correctly, I had to trim the rubber pads a little. I trimmed them evenly and if I were to do it again, I would have trimmed more from the front of the pad than the rear because the skis tended to want to point down at the tips when in the air. It was never a problem, but it bugged me.
The Following User Says Thank You to snowordeath For This Useful Post:
Turblue (01-11-2015)
  #3
Old 01-13-2015, 03:55 PM
retiredpop retiredpop is offline
Currently: Not set
retiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond repute
Default
Here is a bit of info for you. I ran secondary in B-2 with standard Pink secondary spring and Pink-Blue-Pink primary with 89F weights if I recall with no rivet. 16-35 gearing. Definitely use the 39 degree helix which should be stock. I also ran an Aaen pipe which really worked well on this sled.
I also put on Polaris plastic skis. As mentioned you need to experiment with the rubber pads to get them right but fairly simple to do that. Also you may have to add some washers for the mounting bolt to fit tight. It is well worth the time to put plastic skis on them.
__________________
The older I get the better I was. In fact now that I think about it I'm a legend!
Haven't outgrown my 600 yet!
  #4
Old 01-13-2015, 06:55 PM
M5- M5- is online now
Currently: Planning a build
Basic Member
M5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond repute
Default
I have a set of Mods skis here for a Yamaha MM/SRX/RX1. I'm not sure if they could be made to work but I always liked those skis on my other Yamahas.
M5
  #5
Old 01-14-2015, 04:34 PM
LoneViper LoneViper is online now
Currently: Not set.
LoneViper has a reputation beyond reputeLoneViper has a reputation beyond reputeLoneViper has a reputation beyond reputeLoneViper has a reputation beyond reputeLoneViper has a reputation beyond reputeLoneViper has a reputation beyond reputeLoneViper has a reputation beyond reputeLoneViper has a reputation beyond reputeLoneViper has a reputation beyond reputeLoneViper has a reputation beyond reputeLoneViper has a reputation beyond repute
Default
I put a set of the 2000 MM skis on mine, they were a very good addition and easy to come by.
  #6
Old 01-14-2015, 06:48 PM
BigFish BC BigFish BC is offline
Currently: Time to start breaking $hit theres snow on the ground.
BigFish BC has a reputation beyond reputeBigFish BC has a reputation beyond reputeBigFish BC has a reputation beyond reputeBigFish BC has a reputation beyond reputeBigFish BC has a reputation beyond reputeBigFish BC has a reputation beyond reputeBigFish BC has a reputation beyond reputeBigFish BC has a reputation beyond reputeBigFish BC has a reputation beyond reputeBigFish BC has a reputation beyond reputeBigFish BC has a reputation beyond repute
Default
i will give you my ones off my viper if you pay shipping not a mile on them,building new sled for your kids?
  #7
Old 02-01-2015, 10:51 AM
Turblue's Avatar
Default
Quote:
Yeah finished the snosport for my daughter And got a phazer with 1600miles for my son. Yeah if you have them skis I'll take them. I'll give you some cash for them though.
3 out of 3 members found this post helpful. Rate this post: Yes | No
  #8
Old 10-16-2015, 12:12 AM
Escmanaze's Avatar
Escmanaze Escmanaze is offline
Currently: Hooray for Snow!
Escmanaze has a reputation beyond reputeEscmanaze has a reputation beyond reputeEscmanaze has a reputation beyond reputeEscmanaze has a reputation beyond reputeEscmanaze has a reputation beyond reputeEscmanaze has a reputation beyond reputeEscmanaze has a reputation beyond reputeEscmanaze has a reputation beyond reputeEscmanaze has a reputation beyond reputeEscmanaze has a reputation beyond reputeEscmanaze has a reputation beyond repute
Default
Oh my goodness where in the world did you come across a phazer that clean? That's a dream!!!
  #9
Old 10-22-2015, 07:32 AM
Currently: Not set.
Default
If you haven't figured it out by now, that track on the Phazer has to go. Nice sleds.
  #10
Old 10-22-2015, 05:26 PM
couch couch is offline
Currently: waiting for snow
Basic Member
couch has a reputation beyond reputecouch has a reputation beyond reputecouch has a reputation beyond reputecouch has a reputation beyond reputecouch has a reputation beyond reputecouch has a reputation beyond reputecouch has a reputation beyond reputecouch has a reputation beyond reputecouch has a reputation beyond reputecouch has a reputation beyond reputecouch has a reputation beyond repute
  #11
Old 12-23-2015, 02:41 PM
Turblue's Avatar
Click Here to Register
  #12
Old 12-26-2015, 07:10 AM
Currently: Not set.
  #13
Old 12-28-2015, 08:53 AM
mckinney's Avatar
mckinney mckinney is offline
Currently: Modding sled
mckinney has a reputation beyond reputemckinney has a reputation beyond reputemckinney has a reputation beyond reputemckinney has a reputation beyond reputemckinney has a reputation beyond reputemckinney has a reputation beyond reputemckinney has a reputation beyond reputemckinney has a reputation beyond reputemckinney has a reputation beyond reputemckinney has a reputation beyond reputemckinney has a reputation beyond repute
  #14
Old 03-06-2016, 08:55 AM
Turblue's Avatar
  #15
Old 03-06-2016, 09:17 AM
volcano buster volcano buster is online now
Currently: Not set.
volcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond repute
  #16
Old 03-06-2016, 09:20 AM
Turblue's Avatar
  #17
Old 10-01-2016, 07:22 AM
MDEVO's Avatar
MDEVO MDEVO is offline
Currently: waiting for Mother Nature to work her magic...!
MDEVO has a reputation beyond reputeMDEVO has a reputation beyond reputeMDEVO has a reputation beyond reputeMDEVO has a reputation beyond reputeMDEVO has a reputation beyond reputeMDEVO has a reputation beyond reputeMDEVO has a reputation beyond reputeMDEVO has a reputation beyond reputeMDEVO has a reputation beyond reputeMDEVO has a reputation beyond reputeMDEVO has a reputation beyond repute
Garage
  #18
Old 10-01-2016, 07:35 AM
Turblue's Avatar
The Following User Says Thank You to Turblue For This Useful Post:
MDEVO (10-03-2016)
  #19
Old 10-03-2016, 07:33 PM
MDEVO's Avatar
Garage
  #20
Old 10-03-2016, 08:06 PM
Turblue's Avatar
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread — Looking for psi single pipe for 1993 phazer Thread Starter — Turblue Forum — Pipes/Cans (Swapmeet) Replies — 0 Last Post — 12-30-2014 12:45 PM
Thread — 1993 Yamaha Phazer 11 Thread Starter — GBaker Forum — Yamaha (Swapmeet) Replies — 2 Last Post — 09-19-2009 06:01 PM
Thread — 1993 Yamaha Phazer II ST Longtrack CHEAP!!!!!!!!!!!!! Thread Starter — Skidor Forum — Yamaha (Swapmeet) Replies — 6 Last Post — 07-29-2008 08:26 AM
Thread — 1993 Phazer II Thread Starter — markoo Forum — Yamaha (Swapmeet) Replies — 1 Last Post — 02-23-2008 10:10 AM
no new posts
