Upgrade to Premium
Arctic Cat: 1M 2001-2005, all models in the Mountain Cat / 1M chassis
Reply
  #1
Old 03-10-2016, 01:48 PM
BigRedRider BigRedRider is offline
Currently: Not set.
Basic Member
BigRedRider is an unknown quantity at this point
Default Need help tuning King cat
I'm hoping someone has a similar setup to mine so I can get some starting numbers for my boondocker box. 05 King cat, mods are intake, jawz can, v force reeds, boondocker box, egts, and power valve delete. I ride 4000 to 6500 feet. I bought this Sled as is and have no experience with tuning a boondocker box. The Sled when I started riding it would cut out in the midrange, and when full throttle would run in the mid 900 degree range. I have leaned up the top end and poured more fuel to midrange, which has helped quite a bit. The power band seems a little erratic, so if anyone has something similar that I could compare that would be a great help.
Rate this post: Yes | No
  #2
Old 03-10-2016, 02:30 PM
kidrman kidrman is offline
Currently: Not set.
kidrman has a reputation beyond reputekidrman has a reputation beyond reputekidrman has a reputation beyond reputekidrman has a reputation beyond reputekidrman has a reputation beyond reputekidrman has a reputation beyond reputekidrman has a reputation beyond reputekidrman has a reputation beyond reputekidrman has a reputation beyond reputekidrman has a reputation beyond reputekidrman has a reputation beyond repute
Default
What kind of intake? Not sure you need a box with that setup.
  #3
Old 03-10-2016, 04:37 PM
Currently: Not set.
Basic Member
Default
Not sure what kind of intake it is, it vents through the left gauge hole in the hood
  #4
Old 03-10-2016, 09:57 PM
Currently: Not set.
Default
Sounds homemade. How much fuel are you adding?
The 900 is a little leaner, especially in the midrange but I ran an 04 800 with pipe, gutted air box, v force and head with the ethanol wire connected and no box. Ripped but had to keep the throttle active.
  #5
Old 03-10-2016, 11:28 PM
Bearcat Bearcat is offline
Currently: Not set.
Basic Member
Bearcat has a reputation beyond reputeBearcat has a reputation beyond reputeBearcat has a reputation beyond reputeBearcat has a reputation beyond reputeBearcat has a reputation beyond reputeBearcat has a reputation beyond reputeBearcat has a reputation beyond reputeBearcat has a reputation beyond reputeBearcat has a reputation beyond reputeBearcat has a reputation beyond reputeBearcat has a reputation beyond repute
Default
I have ZR 800 EFI -03 engine so it can't be compared directly. But if settings are even close to that it's pig rich stock. I've added 4.5 degree advanced timing, case and cylinder porting and no air box at all. Still my PCV is -5 whole rpm range and there are points where's even more minus in the fuel map. No added fuel anywhere. Still I'm seeing only 1150F at cruising on trails and full gas is below 1100F. Going to lean it more
So, if 900 is even close to 800 in fueling - it's pig rich.
  #6
Old 03-11-2016, 09:52 AM
Idcatman3's Avatar
Idcatman3 Idcatman3 is online now
Currently: Not set.
MODERATOR: Premium Member
Idcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond repute
Garage
Default
Some of that will be caused by running no airbox. If you're pulling underhood air, that can do funny things to your fueling, especially with EFI.
__________________
Arctic Cat 1M and PS Moderator
'04 1M 1500 162" Challenger Extreme, M8 rear suspension, Custom jetting, clutching and gearing
  #7
Old 03-12-2016, 07:10 PM
Currently: Not set.
Basic Member
Default
OK sorry for the delay, but here's what I'm running.
3000rpm lo 06 MD 09 hi 10 TR 01
5000 13 11 09 00
6700 -07 -08 -09 00
7800 -10 -13 -14 00
8100 -15 -16 -18 00
So far I have leaned up the top 3 rpm ranges probably by 5 or 6, and fattened up 5000 rpm range by at least 10 and 3000 range by a few.
After doing so it cuts out less in the midrange, might have to go a bit more. Top end seems to be running good I think.
  #8
Old 03-21-2016, 08:28 PM
Currently: Not set.
Basic Member
Default
Maybe someone has some tips for tuning this thing in right?
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — ARCTIC CAT IGNITION COIL ZR ZL KING CAT POWFER SPECIAL MOUNTAIN CAT FIRECAT Thread Starter — 98woody Forum — Engine/Engine Parts (Swapmeet) Replies — 2 Last Post — 12-21-2012 05:01 AM
Thread — 2004 king cat clutch tuning advice Thread Starter — ripstavah Forum — Arctic Cat: 1M Replies — 1 Last Post — 12-18-2010 09:09 PM
Thread — 2004 King Cat Mod--Priced to Sell! (Misc king cat/1M parts for sale also) Thread Starter — Kingt8r Forum — Arctic Cat (Swapmeet) Replies — 7 Last Post — 03-23-2008 05:58 PM
Thread — 04 king cat efi 1000 cpc tuning help Thread Starter — blazer75 Forum — Arctic Cat: 1M Replies — 2 Last Post — 12-03-2007 03:01 PM
no new posts
