Upgrade to Premium
Clutching Discuss all things related to Clutching for your sled.
Closed Thread
  #1
Old 09-25-2010, 11:42 AM
milehighassassin's Avatar
milehighassassin milehighassassin is offline
Currently: Motor is complete!!!
Moderator: Premium Member
milehighassassin has a reputation beyond reputemilehighassassin has a reputation beyond reputemilehighassassin has a reputation beyond reputemilehighassassin has a reputation beyond reputemilehighassassin has a reputation beyond reputemilehighassassin has a reputation beyond reputemilehighassassin has a reputation beyond reputemilehighassassin has a reputation beyond reputemilehighassassin has a reputation beyond reputemilehighassassin has a reputation beyond reputemilehighassassin has a reputation beyond repute
Garage
Exclamation Polaris Clutching Info/Links
Below you will find threads that will be usefull to those looking for clutching info for Polaris. It is broke down into each generation. Most of these threads are links to leave the original thread where it was started (usually in the brand/generation forum). (This is a work in progress this thread will grow as I find more links)
Polaris Pro-Ride
Info coming soon!
Polaris IQ
General Threads:
Polaris P-85 Thread
Large word file with pics to P-85 Thread
Drive Clutch Balancing Differences
Increasing your IQ Not clutch specific but has some clutching tips
D8 Free Clutch Mods
Question for Those Who Clutched Their D-8's, (also Setup)
TEAM Tied Clutch Conversion Spreadsheet,
Clutch Alignment..CFI Small Blocks in IQ's,
Clutch Grenaded/Replacement
D8 Clutch hitting, case replace/fix
Clutch Fitment and Taper
Secondary Helix Talk
Polaris Spring Chart
Team Secondary Help
D8 Broken Primary Spring
Clutch Broke in Half
Another Broken Clutch
Clutch Removal
Dragon/RMK Belt Talk
Set-up threads:
Setup
700 Setup
Clutching Basics
D8 163" Setup
D8 setup & Part Numbers (Sea-6k')
Getting More Track Speed/D8
600/700/800 Clutching Differences
800 Setup
D8 Aggressive Engagement
D7 Setup and Gearing
Gearing:
19/42 Part Numbers
19/44 Gearing and Pitch chart
Gearing Combos
D8 Gearing
Assault Top Speed
Plastic Chaincase Help/Repair
Polaris 900 (also Big Block 700 info (755))
Pre-Season Primary Bolt Check
Problems getting the Primary Off
Another Primary Stuck
Reverse and Helix Issues
Blowing Belts
900 New Crank and Clutch Talk
Not holding RPM's
900 SETUP Thread
P85 onto Big Block 700
900 Gearing Talk
Gearing Talk with Part #'s
IQ Gearing Sticky
Even More Gearing
Polaris IQR
(not a LOT of IQR info)
General
Jetting and Clutching 600 Twins (not much info but a start)
600HO Helix talk
600 to 800 conversion, Clutch talk
What drive clutches work on the 600
800 VES Clutching setup
600 Clutching and Gearing
Polaris EDGE
Polaris GEN 2
Polaris Gen 1 and Older
Polaris Turbo Sleds
__________________
Need to get rid of a STRAIGHT IQ 163" tunnel and tub. Cheap!!
Rate this post: Yes | No
The Following 19 Users Say Thank You to milehighassassin For This Useful Post:
827revdog (06-08-2012), AKSNOWRIDER (09-25-2010), donbrown (07-05-2012), Franz (09-25-2010), Gmiller (10-09-2011), Goinboardin (10-06-2010), green_denali (09-30-2010), Jeevesso (01-27-2014), lognomore (09-25-2010), mfarmboy95 (11-19-2010), MORSNO (09-25-2010), MountainTrashCat (12-07-2010), Nooby (08-14-2014), black swan (07-26-2011), rmk2112 (09-25-2010), Scott (05-13-2011), scubba steve (10-07-2012), Shaydyl 19 (10-07-2018), shelbwyo (09-05-2013)
Closed Thread
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread — Avy info links....please add yours here. Thread Starter — CatWoman Forum — Avalanche and Survival Replies — 51 Last Post — 12-05-2016 01:47 PM
Thread — M7 Clutching and Clutching Related Info Thread Starter — Stack Forum — Arctic Cat: M Series Replies — 4 Last Post — 03-25-2015 09:22 AM
Thread — Iowa Snowmobile Club Links / Info Thread Starter — Steelman Forum — Iowa Replies — 33 Last Post — 08-03-2012 02:05 PM
Thread — Free avalanche education classes/info, web cams, and weather links. Thread Starter — m1ke Forum — Alaska Replies — 0 Last Post — 11-17-2009 03:49 PM
Thread — Snotel Links & Weather Info Thread Starter — TheFlyingFynn Forum — Arizona/New Mexico Replies — 5 Last Post — 09-29-2009 08:24 AM
no new posts
