2015 Pro front shocks
W
Feb 22, 2021
3
UTAH
I learned about the common a-arm glue failure on my last ride... I hit something and the lower front a arm came unglued; so I think the force of the hit went to the next piece which was the shock - it bent about 60 degrees at the lower mount.
2015 rmk pro 155".
What front shocks are interchangeable with my sled? I see lots for sale used, but not any that are an exact match to my year and model. What is the length of the shock - eye to eye? Or stroke?
Thanks
05rmksteve
2,486
1,626
Brainerd, MN
Well I ended up with a set of walkers off a 16 axys. Fit like a glove, good to be riding again
The axys shocks are a little shorter than the 13-15 pro shocks. You'll loose a little ground clearance with the axys shocks. But now if you get some narrower a arms like zbroz 36" the axys shocks will work good because they should be ran with shorter shocks.
