2004 Bearcat Enclosed Aluminum Trailer 2 Place
recreationist
60
124
33
Laramie, WY
SOLD -- 2004 Bearcat Enclosed Aluminum Trailer 2 Place
--!!! TRAILER IS SOLD, THANKS SNOWEST !!!---
2004 Bearcat Enclosed All Aluminum Snowmobile / ATV Trailer
White in color with aluminum diamond plate (ATP) on corners and front.
2-place, fits two 163" sleds and a cargo sled in the box area, plus gear and a mini-120 in the 'V' :)
Box is 12' long and 97" wide the 'V' is an additional 4' long
Overall it is 100" wide, 96" tall and 18'4" overall including tongue
Interior is 6' tall -- I can stand with helmet on
There are switched 12V lights on each side of the interior
Font ramp on driver side is 62"W x 68"T
Rear ramp is 92"W x 68"T and has spring assist
Frame is structural aluminum tube with floor 24" OC
Walls/Roof are 16" OC square aluminum tube (joists exposed on inside)
3000lbs GVWR -- Single Torsion Axle, trailer is ~1380lbs (can be moved around with hand dolly)
2" coupler with wheel jack and safety chains, std. 7-pin plug
Pulls well with 1/2 ton pickup, small SUV or truck . . .
Ski guides/runners on ramps and floor for both sides
One roof vent and sidewall vents
Two spares plus additional tire
I have a heater, propane tank and folding shelf that I acquired for the trailer but never installed. These can go with the trailer if desired.
Tires are good, grease/bearings done last season.
One ~2' long thin scratch on bottom driver side (parking lot rash) and 2 small dents ~1" diameter in the front from an overhanging branch and a suicidal bird :(
Will add interior pictures when I get a chance.
Overall very good shape and well maintained. I am the original owner, selling so I can eventually buy a 4-place. $xxxx.xx
Trailer is located in Laramie, WY. Delivery could be arranged (within a reasonable distance).
PM for more info. Thanks.
