Upgrade to Premium
Reply
  #1
Old 08-24-2008, 07:33 PM
Rixster's Avatar
Rixster Rixster is offline
Currently: I love you El Nino
Rixster has a reputation beyond reputeRixster has a reputation beyond reputeRixster has a reputation beyond reputeRixster has a reputation beyond reputeRixster has a reputation beyond reputeRixster has a reputation beyond reputeRixster has a reputation beyond reputeRixster has a reputation beyond reputeRixster has a reputation beyond reputeRixster has a reputation beyond reputeRixster has a reputation beyond repute
Garage
Default summit 800 oil pump adjustment ??
One of my buddies bought a 2001 summit 800 at the end of the year last year. he rode it 3 times last year. It smokes terrible!!! The oil pump needs to be adjusted. Is that a simple thing to do? How do you go about it? It must be injecting about 24:1 right now.
__________________
Custom built sled decks contact me for details
A.K.A."Seth"
06 M7 CPC Dragoncat 1000 162
F350 crewcab
Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways, body thoroughly used up, totally worn out and Screaming "WOO" What a ride!
KCCO
Rate this post: Yes | No
  #2
Old 08-24-2008, 11:22 PM
Ancient Sledder Ancient Sledder is offline
Currently: It's not the destination, it's the journey.
Ancient Sledder has a brilliant futureAncient Sledder has a brilliant futureAncient Sledder has a brilliant futureAncient Sledder has a brilliant futureAncient Sledder has a brilliant futureAncient Sledder has a brilliant futureAncient Sledder has a brilliant futureAncient Sledder has a brilliant futureAncient Sledder has a brilliant futureAncient Sledder has a brilliant futureAncient Sledder has a brilliant future
Default
It might be the oil pump itself.Mine lever was staying open when I came off the throttle and it took forever to come back to the idle position.I tried spraying the arm and cable with no luck.I found a bag of springs at an auto parts store. One of the springs was like a ballpoint pen spring about 2 inches long.I threaded the spring over my oil pump cable at the pump end and the problem is gone.
  #3
Old 08-24-2008, 11:50 PM
onlyrotax onlyrotax is offline
Currently: weighing my options
Basic Member
onlyrotax has a reputation beyond reputeonlyrotax has a reputation beyond reputeonlyrotax has a reputation beyond reputeonlyrotax has a reputation beyond reputeonlyrotax has a reputation beyond reputeonlyrotax has a reputation beyond reputeonlyrotax has a reputation beyond reputeonlyrotax has a reputation beyond reputeonlyrotax has a reputation beyond reputeonlyrotax has a reputation beyond reputeonlyrotax has a reputation beyond repute
Default
Quote:
Two ways to check pump calibration, remove airbox, take up slack in throttle lever and check that the index marks on the pump lever and on the pump housing line up or find the adjuster on the oil cable, roll back the rubber boot, gently pull the cable apart at that point and measure how much cable is exposed and adjust to factory spec, I prefer the first method for accuracy.
  #4
Old 08-25-2008, 09:50 AM
Rixster's Avatar
Garage
Default
Its just like anything else then? sounds good thanks guys
__________________
A.K.A."Seth"
F350 crewcab
KCCO
  #5
Old 08-25-2008, 06:21 PM
Wheel House Motorsports's Avatar
Wheel House Motorsports Wheel House Motorsports is offline
Currently: snowbike mania
Wheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond repute
Default
i just bend my mounting bracket for the spring slightley to make the cable not pull quite as far, and the spring trick is really helpful, as those sleds and the revs are notorious for having stick cables.
__________________
Wheelhousemotorsports@gmail.com
406-871-0955 Bozeman, MT
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
