Upgrade to Premium
Reply
  #1
Old 06-29-2008, 09:01 PM
redbull660's Avatar
redbull660 redbull660 is offline
Currently: Not set.
redbull660 has a reputation beyond reputeredbull660 has a reputation beyond reputeredbull660 has a reputation beyond reputeredbull660 has a reputation beyond reputeredbull660 has a reputation beyond reputeredbull660 has a reputation beyond reputeredbull660 has a reputation beyond reputeredbull660 has a reputation beyond reputeredbull660 has a reputation beyond reputeredbull660 has a reputation beyond reputeredbull660 has a reputation beyond repute
Default anti stab kit, is it necessary
I have a 2008 turbo nytro mtx, I have just installed a timbersled rear suspension and a challenger extreme track. Here is my question, Is an anti stab kit necessary. I dont run my track super loose, I try to keep it to factory specs. I hate ratcheting, I would rather run the track tight than super loose.
Does anyone have a pic of the slp anti stab kit installed on a nytro. I am wondering how and where to install it if I have to run one. thanks
Rate this post: Yes | No
  #2
Old 06-29-2008, 09:12 PM
modsledr modsledr is offline
Currently: Not set.
modsledr has a reputation beyond reputemodsledr has a reputation beyond reputemodsledr has a reputation beyond reputemodsledr has a reputation beyond reputemodsledr has a reputation beyond reputemodsledr has a reputation beyond reputemodsledr has a reputation beyond reputemodsledr has a reputation beyond reputemodsledr has a reputation beyond reputemodsledr has a reputation beyond reputemodsledr has a reputation beyond repute
Default
What rails do you have? I have the same track/susp as you, with Ice Age Rails, and I believe my anti-stab is from SLP (not positive...it was on it when I bought it)...but make sure you get the 4 wheel kit with the solid cross shaft, not the single wheels that bolt to each side.
Installed in the very front of the rails about 1" back from the end...the wheels overhang the front of the rails by about 1".
Sorry no pics...hope this helps.
modsledr
Edit: Just looked at the SLP kit online and that is what I have...with 2 limiter straps. Mine still has the limiter strap shaft as well, so the anti-stab shaft is not used for my L/S.
  #3
Old 06-29-2008, 09:16 PM
redbull660's Avatar
Currently: Not set.
Default
I have the stock rails, it looks like I may have to drill some big holes in the black plastic things that go over the tips of the rails.
  #4
Old 06-29-2008, 09:25 PM
Currently: Not set.
Default
Pretty sure with stock rails you remove the plastic ends, cut the rails back to the edge of the slots, and then drill holes. You only end up removing about 1" of rail.
The SLP ad says some rail modification may be necessary...
  #5
Old 06-30-2008, 09:10 AM
snowy1 snowy1 is offline
Currently: Not set.
Basic Member
snowy1 will become famous soon enoughsnowy1 will become famous soon enoughsnowy1 will become famous soon enoughsnowy1 will become famous soon enoughsnowy1 will become famous soon enoughsnowy1 will become famous soon enoughsnowy1 will become famous soon enoughsnowy1 will become famous soon enoughsnowy1 will become famous soon enoughsnowy1 will become famous soon enoughsnowy1 will become famous soon enough
Default
give me your email and I will send pic, of antistab kit installed.
  #6
Old 06-30-2008, 06:30 PM
redbull660's Avatar
Currently: Not set.
Default
My email is cb@rangeweb.net thanks, I will be looking forward to seeing the pics.
  #7
Old 06-30-2008, 07:50 PM
redbull660's Avatar
Currently: Not set.
Default
thanks for the pics, that is kind of what I had in mind. I think it will work perfect.
  #8
Old 07-19-2008, 03:18 AM
INDEEP's Avatar
INDEEP INDEEP is offline
Currently: under and over it all
INDEEP has a reputation beyond reputeINDEEP has a reputation beyond reputeINDEEP has a reputation beyond reputeINDEEP has a reputation beyond reputeINDEEP has a reputation beyond reputeINDEEP has a reputation beyond reputeINDEEP has a reputation beyond reputeINDEEP has a reputation beyond reputeINDEEP has a reputation beyond reputeINDEEP has a reputation beyond reputeINDEEP has a reputation beyond repute
Default
TTT
I know lots of 3 pitch sleds that don't run anti stab kits. What makes your sled prone to sticking one? Suspension set ups, anti ratchet's, or just too loose? I've seen some pics and they just about scare me into buying one.
__________________
"There were 1.5 million people at the inauguration and only 14 missed work."
  #9
Old 07-20-2008, 10:23 PM
rednytro rednytro is offline
Currently: Not set.
Basic Member
rednytro will become famous soon enoughrednytro will become famous soon enoughrednytro will become famous soon enoughrednytro will become famous soon enoughrednytro will become famous soon enoughrednytro will become famous soon enoughrednytro will become famous soon enoughrednytro will become famous soon enoughrednytro will become famous soon enough
Default
  #10
Old 07-21-2008, 07:44 AM
Blue Light Blue Light is offline
Currently: Done.
Basic Member
Blue Light has a reputation beyond reputeBlue Light has a reputation beyond reputeBlue Light has a reputation beyond reputeBlue Light has a reputation beyond reputeBlue Light has a reputation beyond reputeBlue Light has a reputation beyond reputeBlue Light has a reputation beyond reputeBlue Light has a reputation beyond reputeBlue Light has a reputation beyond reputeBlue Light has a reputation beyond reputeBlue Light has a reputation beyond repute
  #11
Old 07-21-2008, 04:36 PM
Currently: Not set.
Click Here to Register
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
