Upgrade to Premium
Reply
  #1
Old 01-27-2008, 06:37 PM
FriscoProx's Avatar
FriscoProx FriscoProx is offline
Currently: Not set.
FriscoProx has a reputation beyond reputeFriscoProx has a reputation beyond reputeFriscoProx has a reputation beyond reputeFriscoProx has a reputation beyond reputeFriscoProx has a reputation beyond reputeFriscoProx has a reputation beyond reputeFriscoProx has a reputation beyond reputeFriscoProx has a reputation beyond reputeFriscoProx has a reputation beyond reputeFriscoProx has a reputation beyond reputeFriscoProx has a reputation beyond repute
Default Co adjustment on the Nytro?
Just wondering how you adjust this on the Nytro. I tried the Apex sequence and it takes me to diag but no Co. What do I need to do too get into it?
Rate this post: Yes | No
  #2
Old 01-27-2008, 06:40 PM
1madbird's Avatar
1madbird 1madbird is offline
Currently: Pro engine build starting soon
1madbird has a reputation beyond repute1madbird has a reputation beyond repute1madbird has a reputation beyond repute1madbird has a reputation beyond repute1madbird has a reputation beyond repute1madbird has a reputation beyond repute1madbird has a reputation beyond repute1madbird has a reputation beyond repute1madbird has a reputation beyond repute1madbird has a reputation beyond repute1madbird has a reputation beyond repute
Default
what is co
  #3
Old 01-27-2008, 09:43 PM
robertyoke robertyoke is offline
Currently: has reached his free limit
robertyoke has a reputation beyond reputerobertyoke has a reputation beyond reputerobertyoke has a reputation beyond reputerobertyoke has a reputation beyond reputerobertyoke has a reputation beyond reputerobertyoke has a reputation beyond reputerobertyoke has a reputation beyond reputerobertyoke has a reputation beyond reputerobertyoke has a reputation beyond reputerobertyoke has a reputation beyond reputerobertyoke has a reputation beyond repute
Default
down in nose cone area you will find a wire with a white connector. remove cap and ground wire then turn on key, push both buttons on dash. navagate through till it says co then cyl 1,2,3 adjust all cylinders.
-robert
  #4
Old 01-27-2008, 10:10 PM
Bigrock33's Avatar
Bigrock33 Bigrock33 is offline
Currently: Retired!
Bigrock33 has a reputation beyond reputeBigrock33 has a reputation beyond reputeBigrock33 has a reputation beyond reputeBigrock33 has a reputation beyond reputeBigrock33 has a reputation beyond reputeBigrock33 has a reputation beyond reputeBigrock33 has a reputation beyond reputeBigrock33 has a reputation beyond reputeBigrock33 has a reputation beyond reputeBigrock33 has a reputation beyond reputeBigrock33 has a reputation beyond repute
Default CO
Quote:
Can you tell me the Apex sequence please. Thanks.
  #5
Old 01-30-2008, 01:48 PM
1madbird's Avatar
Default
If I adjust this to the max rich side and have a fuel box on it will it still increase or does the box over ride the stock ecu
  #6
Old 01-31-2008, 11:59 PM
mtnmodviper mtnmodviper is offline
Currently: Not set.
mtnmodviper has a reputation beyond reputemtnmodviper has a reputation beyond reputemtnmodviper has a reputation beyond reputemtnmodviper has a reputation beyond reputemtnmodviper has a reputation beyond reputemtnmodviper has a reputation beyond reputemtnmodviper has a reputation beyond reputemtnmodviper has a reputation beyond reputemtnmodviper has a reputation beyond reputemtnmodviper has a reputation beyond reputemtnmodviper has a reputation beyond repute
Default
Found this on another post:
Nytro:
1) Ground the pale green wire with the white connector in the nose cone area.
This wire has no mating wire in the male connector and only needs to be
grounded
2) Enter Diagnostic mode:
-Key and kill sw off, press and hold both "Select and Reset" and then
power
up the gauge (key and kill on)
*I leave the key on and just use the Kill Switch
-Wait 8 seconds and the gauge will go blank except for "DIAG" in the
display
-Press select to toggle between "DIAG" and "C0", Select "C0"
*If there is no selection, recheck your ground
-Press and hold both "Select and Reset" 3 seconds
-Gauge will display "C:01", (this is where you select which cylinder you
want to adjust)
-Press and hold "Select and reset" 3 seconds and a number will appear at the bottom of the screen, (will be 0)
-Press "Select" to increase the number (richer), "Reset" to decrease the
number (leaner)
*adjust it to read 10 for richer, -10 will be leaner
-Press both "Select and reset" and chose C:02 and adjust the same as
above,
you must do this for each cylinder
This will change your low speed fuel mixture much like the pilot circuit
on a carb model, there is little or no effect on high speed
The engine will start and run normally in C0 mode so you can change
settings with the engine running or on the trail
To reset simply turn off the key or kill switch and the gauge will return
to normal"
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
