Upgrade to Premium
Reply
  #1
Old 01-05-2008, 03:14 AM
firecat99 firecat99 is offline
Currently: Not set.
Basic Member
firecat99 has a reputation beyond reputefirecat99 has a reputation beyond reputefirecat99 has a reputation beyond reputefirecat99 has a reputation beyond reputefirecat99 has a reputation beyond reputefirecat99 has a reputation beyond reputefirecat99 has a reputation beyond reputefirecat99 has a reputation beyond reputefirecat99 has a reputation beyond reputefirecat99 has a reputation beyond reputefirecat99 has a reputation beyond repute
Garage
Default Nytro RTX track?
ok im going to a 2" paddle but keeping it a 121" and going to extroverts introverts and not sure on what driver i should use, the other thing is that the track i got im not sure what pitch it is or does it really matter? because i was told to go to a 8tooth driver 2.52 pitch, but was told that the MTX's are running a 7tooth with a 3 pitch, so im not really sure which way to go with this soooo many different answers from everyone just need one common one lol that would be great thanks.
Rate this post: Yes | No
  #2
Old 01-05-2008, 03:47 AM
Linc Linc is offline
Currently: Not set.
Linc has a reputation beyond reputeLinc has a reputation beyond reputeLinc has a reputation beyond reputeLinc has a reputation beyond reputeLinc has a reputation beyond reputeLinc has a reputation beyond reputeLinc has a reputation beyond reputeLinc has a reputation beyond reputeLinc has a reputation beyond reputeLinc has a reputation beyond reputeLinc has a reputation beyond repute
Default
I think a 9 tooth 2.52 will work just fine,we used an 8.This thing is a howl,don't know what elev.you'll be running at but anything above 4 thou,empty the weights and it screams,die hard Ski Doo fans have been blown away.
  #3
Old 01-07-2008, 12:22 AM
Currently: Not set.
Basic Member
Garage
Default
thats what im running now is a 9tooth 2.52 with no clearence i might beable to get a 1.375 track under there and im running at 0-2000 altitude, should i change my gears? and if so how much teeth upper and lower? and for cluching?
  #4
Old 01-07-2008, 05:52 AM
Currently: Not set.
Default
Go to a 8 tooth extrovert,take one rivet out of the tip of the weight,and the gearing seems fine.
  #5
Old 01-07-2008, 02:34 PM
Currently: Not set.
Basic Member
Garage
Default
ok thanks
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
