who here has messed with tuning VES springs?
L
Jan 29, 2010
175
50
I have a pink set of springs sitting around for my pro from a couple of years ago, I remember reading up on pink being right for my elevation, 7-9 is most my riding.
how many of you guys have played around with this? what kind of results were you able to get?
NDFARMER95
556
108
Mooreton, ND
I was having a lot of chatter from the valves last season. Put in green/white springs and we'll see how that goes. 14.1 DI, slp pipe and can, PCV riding 8k+.
G
geo
2,170
2,336
Kamloops B.C.
Theory question. For info-discussion reasons only.
I installed the green whites (thanx TRS) and like the consistency they created even at my relatively low 5 to 6 thousand ft.
Many seem to be popping these in so why?
Poo has them in stock but spec the sled with very stiff springs. Cylinder pressure is required to open the valves. Increases in elevation, worn rings, low rpm, all lower cylinder pressure.
Is there always enough pressure to overcome any spring?
Theoretically if a valve hangs closed too long it increases air flow there and may create a lean or even det condition. Worse case scenario is the valve does not open at all. We all know that would mean less power at high rpm.
In reverse if too soft a spring is selected (doesn't close maybe because of carbon build up) the worse case scenario is lost mid range or rich bog.
Why, theoretically, does Poo spec these springs? They know this stuff too and must realize the sled is headed for elevation. Doo has spec'ed stiff springs but on carbed models so there was some built in correction for air velocity (carbs work on intake velocity). No air correction factor in the Poo injection system.
If the valve opens when the solenoid dictates (theoretically) what does a spring change do? This valve opening is timed with some important engine management adjustments by the 'putor too.
What do you think is happening when you install a softer exhaust spring? What have you "felt"?
BILTIT
1,682
482
83
45
Lloydminster, SK
I know on my 03 rmk i could feel, hear and see it on my egt's with too soft of a spring (pinks at 2200'). I never played with it at higher altitudes.
I could cruise along at a steady throttle position/speed and at a certain point i would see the egt's lean out a little and feel a surge of power. I tested this a few times, change to a heavier spring and could not get it to repeat itself.
I always switched springs in my 03 as i rode it at different altitudes alot. I havent bothered changing with the '11 as i dont ride it as much down low since i bought my 04 proxr.
C
Feb 8, 2008
241
60
Just because the solenoid closes does not mean there is enough cylinder pressure to open the valves. The ecm maps the fuel with the soleniod operation. If the valves don't open, or stay open, with the solenoid the fuel mapping is off until the valves do open. At high elevation this happens quite often.
gunnerthesnowman
197
Red Deer , Alberta
I have a 2013 pro 870 BB , i was having this same thing happen , if i hold the RPM,s at 6800-7000 it sounded like the exhaust valve were chattering , put the pink springs in and also lower the valve opening point to 5000 RPM,s ( i am running the ViPec ECU ) In doing this i had to remap ( more fuel ) from 5000-7000 RPM,s and re-clutch , it pulls really hard , also the pipe temp. and pressure effects the exhaust valve operation , ran into this valve chatter again in the spring , pipe temp. got high , added timing and fuel correction to deal with this ( i hope )
G
gman086
1,347
572
Portland, OR
The valves open sooner and stay open longer. If you run an aftermarket exhaust, you darn well better be running softer springs to prevent heat build around the exhaust ports! Just read your egt's and that's all you'll need to know. Porting requires more air flow and softer springs too. Something I learned real fast with funky noises coming from my Union Bay motor (sounds like someone shuffling cards if your exhaust valves are not opening soon enough). Also the higher the altitude, the lower the spring pressure. UBR didn't run any springs in a lot of their hillclimb sleds.
Have FUN!
G MAN
K
May 10, 2009
134
25
Calgary, AB
Anyone run the green/white at lower elevation? I just want to be lazy when I am running around home. About 2500 ft. Main riding is 8000 and the green/white is a nice touch if you want the edge on your buddy.
G-Force
976
274
Kamloops BC
Have FUN!
G MAN
Have a pipe coming for my new '15. Riding elevations from 2200-7000'. Would there be a benefit from swapping out springs? If so, to the pink? Or the green/white?
TRS
Life Member
4,133
6,294
Cody, WY
Pinks have a rust issue. I don't know if it is the paint or the spring. They will fatigue rapidly when the rust sets in. You will need to replace them often.
800xtreme
589
48
TRS - what do you recommend for myself and G-Force? Different elevations but we are both curious... thanks!
TRS
Life Member
4,133
6,294
Cody, WY
I recommend the Green/White for the 800 CFI2
Blue for the 800 CFI4
I have tested a majority of the springs available from PI from 5000-11,000'.
