Upgrade to Premium
Polaris: Pro-Ride 2010 and up, all models in the Pro-Ride chassis
Reply
  #1
Old 01-01-2014, 12:05 PM
machinest660's Avatar
machinest660 machinest660 is offline
Currently: Not set.
machinest660 has a reputation beyond reputemachinest660 has a reputation beyond reputemachinest660 has a reputation beyond reputemachinest660 has a reputation beyond reputemachinest660 has a reputation beyond reputemachinest660 has a reputation beyond reputemachinest660 has a reputation beyond reputemachinest660 has a reputation beyond reputemachinest660 has a reputation beyond reputemachinest660 has a reputation beyond reputemachinest660 has a reputation beyond repute
Default Boondocker box and AFR gauge on a pro???
Just curious to see if anyone is running a boondocker box and a AFR on there pro? I am running a mntk fix kit and a 13-1 par head. I was hitting Det bad enough that it would go into limp mode so i started mixing in some race gas and so far so good. It would always happen at about half throttle so figured it was probably a bit lean in the midrange. Just wanted some feed back if there was some power to be gained with the BD box and what numbers others were running. I ride mostly in the 5000-7000'. Thanks for any info
__________________
2012 pro rmk 155, Carls Cycle 660, Fox Float Evol R, RSI Carbon Fibre Bars, C3 Belt Drive, Timberlsed Skid, 2.5 Camo Extreme Track, Z Bros A-Arms, WRP Seat,
Rate this post: Yes | No
  #2
Old 01-01-2014, 02:25 PM
tinkerjohnson tinkerjohnson is online now
Currently: Tinker till I die
tinkerjohnson has a reputation beyond reputetinkerjohnson has a reputation beyond reputetinkerjohnson has a reputation beyond reputetinkerjohnson has a reputation beyond reputetinkerjohnson has a reputation beyond reputetinkerjohnson has a reputation beyond reputetinkerjohnson has a reputation beyond reputetinkerjohnson has a reputation beyond reputetinkerjohnson has a reputation beyond reputetinkerjohnson has a reputation beyond reputetinkerjohnson has a reputation beyond repute
Default
Quote:
The pros are lean in the mid range, especially if you add compression it causes det in the mid range. but I run a boonie box and afr on my sled but run totally different setup than you so can't help you there but I would get a box for sure
  #3
Old 01-01-2014, 02:49 PM
geo geo is offline
Currently: Not set.
geo has a reputation beyond reputegeo has a reputation beyond reputegeo has a reputation beyond reputegeo has a reputation beyond reputegeo has a reputation beyond reputegeo has a reputation beyond reputegeo has a reputation beyond reputegeo has a reputation beyond reputegeo has a reputation beyond reputegeo has a reputation beyond reputegeo has a reputation beyond repute
Default
Did you check your squish?
I have a 12.8 head and set my squish to 55 (as tight as I would go) last season (stock pistons) and had slight det issues to 4000' with non eth 91. A second map for the way up was my way of dealing with it last season.
The mnkt pistons I got were 3 thou taller giving me a 52 squish (too tight), So I went to a safer 58.
  #4
Old 01-01-2014, 04:58 PM
Currently: Not set.
Default
How did you get a larger squish? use a thicker head gasket? It seems to be good now that i run some race fuel or av gas. if thats what i have to do i am ok with that. I am really happy with the throttle response and power so far. thanks
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 07 Dragon 700 Boondocker turbo help. AFR Gauge Thread Starter — ^dragon700^ Forum — Polaris: TURBO Replies — 1 Last Post — 12-30-2013 03:14 PM
Thread — Another M7 Boondocker Box with nitrous control and a KOSO egt gauge with probes Thread Starter — blackt Forum — Gauges/Instrumentation (Swapmeet) Replies — 5 Last Post — 04-13-2013 11:33 PM
Thread — Innovate AFR gauge with Boondocker Thread Starter — rmk685 Forum — Polaris: TURBO Replies — 12 Last Post — 01-02-2012 09:15 PM
Thread — Boondocker Box and gauge Thread Starter — Samurai Forum — Gauges/Instrumentation (Swapmeet) Replies — 2 Last Post — 03-27-2009 08:53 PM
Thread — 07 m1000 boondocker error and afr gauge error Thread Starter — mocflats Forum — Arctic Cat Replies — 0 Last Post — 02-09-2009 04:29 PM
