Upgrade to Premium
Polaris: Pro-Ride 2010 and up, all models in the Pro-Ride chassis
Reply
  #1
Old 12-09-2013, 05:19 PM
Daggerboat Daggerboat is offline
Currently: Not set.
Basic Member
Daggerboat has a brilliant futureDaggerboat has a brilliant futureDaggerboat has a brilliant futureDaggerboat has a brilliant futureDaggerboat has a brilliant futureDaggerboat has a brilliant futureDaggerboat has a brilliant futureDaggerboat has a brilliant futureDaggerboat has a brilliant futureDaggerboat has a brilliant futureDaggerboat has a brilliant future
Default Compression on '14 600 RMK
I read 80 on both sides when I brought it home from the dealer... I know compression will increase as the rings seat but compared to my '07 600 (4200 miles) reading 120 it seems pretty low to me. Did polaris lower compression on these newer motors, possibly for EPA reasons? I'm at 3300'. I wish I had checked compression on the '07 when I brought home.... I will check the '14 again when the breakin premix is burnt out of it. Has anyone else checked the compression on the new 600's ??
Rate this post: Yes | No
  #2
Old 12-09-2013, 08:05 PM
tinkerjohnson tinkerjohnson is offline
Currently: Tinker till I die
tinkerjohnson has a reputation beyond reputetinkerjohnson has a reputation beyond reputetinkerjohnson has a reputation beyond reputetinkerjohnson has a reputation beyond reputetinkerjohnson has a reputation beyond reputetinkerjohnson has a reputation beyond reputetinkerjohnson has a reputation beyond reputetinkerjohnson has a reputation beyond reputetinkerjohnson has a reputation beyond reputetinkerjohnson has a reputation beyond reputetinkerjohnson has a reputation beyond repute
Default
Quote:
Should at least have 120 stock. it won't even run with 80, your tester is wrong or broke hold throttle wide open and pull it over till the needle stops moving
  #3
Old 12-10-2013, 01:56 AM
aksnopro aksnopro is offline
Currently: Not set.
aksnopro has a reputation beyond reputeaksnopro has a reputation beyond reputeaksnopro has a reputation beyond reputeaksnopro has a reputation beyond reputeaksnopro has a reputation beyond reputeaksnopro has a reputation beyond reputeaksnopro has a reputation beyond reputeaksnopro has a reputation beyond reputeaksnopro has a reputation beyond reputeaksnopro has a reputation beyond reputeaksnopro has a reputation beyond repute
Default
if it starts its got more then 80 for sure...
  #4
Old 12-12-2013, 01:54 AM
iluv2fly iluv2fly is offline
Currently: Not set.
iluv2fly has a reputation beyond reputeiluv2fly has a reputation beyond reputeiluv2fly has a reputation beyond reputeiluv2fly has a reputation beyond reputeiluv2fly has a reputation beyond reputeiluv2fly has a reputation beyond reputeiluv2fly has a reputation beyond reputeiluv2fly has a reputation beyond reputeiluv2fly has a reputation beyond reputeiluv2fly has a reputation beyond reputeiluv2fly has a reputation beyond repute
Default
My 13 600 had between 110-115 brand new at 4500 ft. With the par 13.6 head it was around 125. You should be around 115 at your elevation.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — RMK 600 compression Thread Starter — max-nut Forum — Polaris: Pro-Ride Replies — 4 Last Post — 11-15-2013 06:48 PM
Thread — nitrous and 14-1 compression? Thread Starter — scrapmaster Forum — Arctic Cat: M Series Replies — 0 Last Post — 11-20-2011 11:40 AM
Thread — 2006 rmk 600 compression Thread Starter — snowrider97701 Forum — Polaris: IQR Replies — 3 Last Post — 11-14-2011 07:29 AM
Thread — 07 600 ho rmk compression Thread Starter — corpeleven Forum — Polaris Replies — 2 Last Post — 12-10-2008 05:54 PM
Thread — usable range for compression on 99 600 RMK Thread Starter — 99RMKGUY Forum — Polaris Replies — 5 Last Post — 12-09-2008 10:44 AM
